Old 09-23-2007, 11:41 PM   #1
WrxRick
Member#: 85761
2005 05' STi
Default STi rev safe to 7500rpm?
I am purposely building my block to withstand the power for a FP RED. I am currently bone stock right now and I plan to go with an Axis Stage 2 shortblock.
I have tried searching to find out an answer, but it seems I can only find part of the answer I'm looking for.
So here it is, What modifications should I do to ensure the safety of revving to 7900rpm in terms of head work? I'd like to keep stock cams for lower torque. I just want to rev a bit more than the stock parameter, since the FP RED will love to rev past 7k.
Thanks for your expertise.
WrxRick is offline   Reply With Quote
Old 09-23-2007, 11:55 PM   #2
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
Springs, block work and oil system upgrade but IMO if you are going to use the stock cams then their is no point in spinning to 7900. The cams will limit the top end power, TQ going to be plumeting by that rpm
mick_the_ginge is offline   Reply With Quote
Old 09-23-2007, 11:58 PM   #3
flycaster
Member#: 60142
2011 WRX
Grey
Are we talking 7.9 or 7.5K here - I'm confused.
flycaster is offline   Reply With Quote
Old 09-24-2007, 12:01 AM   #4
WrxRick
Member#: 85761
2005 05' STi
Sorry for the confusion.
I'll most likely shift right before 8,000rpm each shift. So about 7.9k.
So perhaps 264/264 cams will keep some torque at slightly higher rpms vs. the stock cams.
mick_the_ginge:
by "block work" do you mean porting the heads? Or something else?
Old 09-24-2007, 12:18 AM   #5
WrxRick
Member#: 85761
2005 05' STi
Here would be my latest up to date question.
What would I need to rev happy to 7900 (no more) besides a Brian Crower spring/retainer kit, and a brian crower camshaft set?
I will have a local shop install this machinery.
Side Note: A big concern I have involves the lack of knowledge that I have as far as aftermarket cams goes. Does adding Brian Crower cams change the power band at all (horsepower) before peak horsepower? Or does it just free up top end horsepower without affecting lower rpm horsepower curve?
Old 09-24-2007, 12:37 AM   #6
modaddict
Member#: 95840
sold to a good bud
awaiting next car
cams shift your powerband to the right. period. Depending on the size of the cams depends on the shift. Port work can also do the same thing.
check this thread out:
http://forums.nasioc.com/forums/show...highlight=past
FWIW my completely stock long block is at 7550. There are people who have gone higher, and there are people who think *I'm* nuts.
modaddict is offline   Reply With Quote
Old 09-24-2007, 12:41 AM   #7
WrxRick
Member#: 85761
2005 05' STi
Fantastic thread find.
Thanks for the info
Old 09-24-2007, 10:50 AM   #8
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
i wouldn't be as worried with the cams, you should be worried with what rod/main bearings you use!!! and everyone can back me up with that
blowbyu24 is offline   Reply With Quote
Old 09-24-2007, 01:02 PM   #9
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I wouldn't spin to 7900 on factory rods...(axis stage 2)...also wouldn't do it on the factory bearings or factory oiling system.
rods stretch and metal fatigues...not to mention now with heavier forged pistons exerting more force on the bearings and rods
It would be a shame to do the work to just flush it down the drain
Old 09-24-2007, 01:08 PM   #10
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
7500 on stock block here running a green.
DoctorNick is offline   Reply With Quote
Old 09-24-2007, 03:22 PM   #11
charliew
Member#: 125304
Default 7900
7900, blinking 8200, using a rev limiter at 7500, your still on borrowed time. There is nothing in a wrx or sti that was meant to live past 7000. Just study the threads and use your own judgement it's your money. Who's to say what some stock motors will do. Stock tolerances were not meant to be pushed past 7000. Do you think subaru put an extra 2 grand in the motor just so the folks could play or do you think they tried to hold the cost down and make a neat street car to be used by 40 year olds that want it to last till it's paid for. If you go to bigger cams you are going to spend more time past 6000 and a stock motor wasn't meant to stay there very long. Nice dreams and good luck. I hope you check the oil regularly cause some will dissapear at higher rpms.
Charlie
charliew is offline   Reply With Quote
FS : Thread Moved. Swifty Cactus Wheels/Tires 16 06-20-2010 04:29 AM
Safe to rev to 7k? sts2689 Newbies & FAQs 18 04-08-2008 06:21 PM
Safe or not safe to put on: Intake issue subywrxdude Newbies & FAQs 11 02-12-2007 09:35 AM
Safe to use febreze auto on sti seats? StiRiDaZ Interior & Exterior Modification 12 10-28-2005 10:31 AM
Is the AP safe to run with stock injectors and fuel pump on an STi? Irishman Engine Management & Tuning 5 08-30-2004 01:10 AM
