Old 09-24-2007, 07:19 AM   #1
mcrawford
Member#: 142601
2006 STI
Rally Blue
Default 06 STI stuttering in 2nd gear when accelerating
I was driving the car for a while *3hours* yesterday when it started stuttering (about 5 stutters) while rolling through stop signs.
I didn't come to a complete stop at the sign and put the car in 2nd gear to continue through the intersection.
As I accelerated lightly the car made a rapid stuttering sound which came from the rear of the car. I wasn't turning; I was going straight. Doesn't do this in any other gear. No CEL.
Any thoughts?
mcrawford is offline   Reply With Quote
Old 09-24-2007, 07:25 AM   #2
ekw
Member#: 92141
2004 STi-WRB on gold
Street prepped by TiC !
try making a full stop at the red octagon.
ekw is offline   Reply With Quote
Old 09-24-2007, 08:32 AM   #3
TheSilverFox
Member#: 142520
2006 STI - Protuned
308whp - SilverFox
make the full stop (i do the same as you half the time ; ) )
what rpm's were you at in 2nd gear??? like 1000??? my guess is that you needed to be in first, OR, give the car more gas b4 letting off the clutch. i highly doubt something is wrong with your car. just sounds like it was bogging b/c of low rpms
--J
TheSilverFox is offline   Reply With Quote
Old 09-24-2007, 08:46 AM   #4
mcrawford
Member#: 142601
2006 STI
Rally Blue
no cop | no stop...
SilverFox... yeah the rpm's were low but the balance of clutch depression to gas acceleration is typical of all my slow-down-and-roll-throughs....
It was a distinct "choppy" stutter and not the usual "rumble" of the car struggling to pull through low rpm's...
I wasn't able to reproduce the problem on my morning comute today...
meh... maybe im crazy...
Old 09-24-2007, 09:28 AM   #5
drivin blind
Member#: 73043
2011 STI/2010 370Z
Black/Black Cherry
Sounds like maybe you are "lugging" engine. To little info. Is there a reason you don't down shift into 1st? RP
drivin blind is offline   Reply With Quote
Old 09-24-2007, 09:38 AM   #6
ErasureWRX
Member#: 106408
'14 Mystery Machine
01 Kat600
Originally Posted by mcrawford View Post
no cop | no stop...
Do you take the same approach to every law?
DIAF.
ErasureWRX is offline   Reply With Quote
Old 09-24-2007, 09:49 AM   #7
mcrawford
Member#: 142601
2006 STI
Rally Blue
I never down-shift into first because the engine revs sooo high... perhaps i'll start doing that...
Old 09-24-2007, 09:49 AM   #8
mcrawford
Member#: 142601
2006 STI
Rally Blue
Originally Posted by ErasureWRX View Post
DIAF.
what's DIAF?
Old 09-24-2007, 10:28 AM   #9
SilverSubaab
Member#: 88288
.... At this point,
even I have lost track.
Die In A Fire......While I think that was a bit harsh, you really need to actually stop at Stop signs. You never know when you might miss seeing a car or little kid, and I'm sure you don't want to hurt anyone for no reason.....
SilverSubaab is offline   Reply With Quote
Old 09-24-2007, 10:34 AM   #10
mcrawford
Member#: 142601
2006 STI
Rally Blue
Thank-you. I shall from now on stop, complete and fully, at every stop sign just like everyone else in the world does.
I'm stuttering on low rpms in 2nd gear... if I'm going 2-4 miles per hour I would be surprised as I "roll" the stop signs.
Old 09-24-2007, 10:38 AM   #11
conker69
Member#: 59692
2005 Impreza WRX STi
WRB-Gold
DIAF.
Jesus...****. Your post has nothing to do with the topic.
Either help or leave the thread.
Sounds normal IMO. That low of RPM and in second gear is not easy to get moving. I've done the same thing but have to ride the clutch a bit.
conker69 is offline   Reply With Quote
Old 09-24-2007, 10:39 AM   #12
Derbagger
Member#: 32113
05 Saabaru
Satin Grey
There is a definite change in stutter from a lugging engine to one that is about to stall. That change can happen in a 100 RPM change. If it revs ok, I'd chalk it up to being too slow for 2nd gear.
There's a definite difference to doing 3 MPH through a stop with your foot over the brake and cruising through at 30 MPH. (The former is typical and not likely to do any real damage, while the latter will kill people.) It's like people who complain about people speeding. everyone does it, and everyone has thier own line where it goes from innocent to insane.
Derbagger is offline   Reply With Quote
Old 09-24-2007, 11:26 AM   #13
Checkered24
Member#: 153974
2007 WRX Ltd
Urban Grey
I felt what sounds like a similar thing in my WRX on occasion, usually upshifting 1st to second. I am not sure exactly why it does it, but it has something to do with not getting the rpm's up for the shift (if I let them fall to idle, doing a slow shift). It's like a clutch stutter for whatever reason. In my case, it is nothing more than opperator error with the clutch, and I can easily avoid it. I did it a lot when the car was new, but now only occasionally when I am not paying as good attention as I should to what I am doing.
Checkered24 is offline   Reply With Quote
Old 09-24-2007, 11:29 AM   #14
mcrawford
Member#: 142601
2006 STI
Rally Blue
The only reason I made this post was because I'm not driving any different and the car is acting different....
I'll just do as Checkered24 says and keep the revs up to avoid clutch st..st..stutter..
Old 09-24-2007, 11:41 AM   #15
Checkered24
Member#: 153974
2007 WRX Ltd
Urban Grey
It may not be the same issue since I am accelerating when shifting, and you are going from decelerating to accelerating. Also, different gearboxes. It just sounds kind of similar in how you describe the sensation.
Old 09-24-2007, 12:31 PM   #16
GuiltySparc
Member#: 151003
2007 STi
DIAF.
...wow, ****...
For the OP, my guess is that you were going too slow for 2nd. With my 07 i generally break to about 10ish mph, then roll through the sign as i shift into first (still braking lightly) so by the time i'm releasing the clutch i'm barely moving.
GuiltySparc is offline   Reply With Quote
Old 09-24-2007, 12:36 PM   #17
teesutt
Member#: 127940
Evil shenanigans
pwnt.
teesutt is offline   Reply With Quote
clicking in 5th gear when accelerating 06SilverWRX Newbies & FAQs 7 11-23-2010 06:32 AM
Bad bucking/stuttering WOT 2nd gear moby4dick Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-28-2009 01:46 PM
06 STi 1st and 2nd gears are hard to shift when cold? 06slvrsti Transmission (AT/MT) & Driveline 6 02-22-2007 01:13 AM
Jerking acceleration in 2nd gear WimpWgn Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-01-2004 01:51 PM
Why does my WRX accelerate so roughly in 2nd gear? sajohnson Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 43 01-19-2003 12:30 PM
