Old 09-25-2007, 02:43 AM   #1
calsonic65
Member#: 93815
2003 WRX
Default Question about VF34 !!!!
hi
I have an 03 wrx and was turned by harman motive over the past month.
Set up:
-VF34
-APS D/R 525 front mount
-APS 65 cold air intake
-Sti Pinks
-Walbro fuel pump
-Cobb Access Port
-Turbo back exhaust
-up-pipe
-down-pipe
-BOV
Right now my car is making 255hp at the wheels and 225tq. To me the number seem to be lower than i expected, but they told me that it is correct because they are using a "Mustang Dyno".
My question is:
Is the number correct or should it be higher or am just being stupid? Cuz i have read about wrx making 280-300hp at the wheels with the VF34 on the forum before so plz help me out.
Thanks
calsonic65 is offline   Reply With Quote
Old 09-25-2007, 02:48 AM   #2
TheShad0w
Member#: 91925
2015 WRX STi
AWDTuning.com
at what PSI?
TheShad0w is offline   Reply With Quote
Old 09-25-2007, 02:52 AM   #3
calsonic65
Member#: 93815
2003 WRX
at 19psi
Old 09-25-2007, 05:22 AM   #4
JMK508
Member#: 115420
Its like a STI.....
but it doesn't break
Your running Cali 91 octane. Your numbers sound about right. Throw some meth on there and your tuner will be able to advance your timing a little.
JMK508 is offline   Reply With Quote
Old 09-25-2007, 07:22 AM   #5
rexman2002
Member#: 140244
02 bugeye
"stare ale jare"
Thanks
Dynojet....?!
Mustang dyno is a lower reading dyno.
How much does a stock WRX make on that dyno?
rexman2002 is offline   Reply With Quote
Old 09-25-2007, 08:33 AM   #6
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
I make 286-290 on a mustang dyno with my vf22. I would think you would be higher as well but maybe that 91 oct is a bigger factor.
breathinez is offline   Reply With Quote
Old 09-25-2007, 09:24 AM   #7
djdimensions
Member#: 95204
2007 Toyota Prius
hmm sounds just a bit low ive seen VF34 make more than that even on cali 91 oct.
djdimensions is offline   Reply With Quote
Old 09-25-2007, 09:37 AM   #8
BBaller018
Member#: 100465
08' legacy
quartz silver
That actually sounds about right. On their old dyno that would probably be around 285 whp. More importantly how does the car drive?? I'm thinking about going with the same setup shortly.
BBaller018 is offline   Reply With Quote
Old 09-25-2007, 10:27 AM   #9
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Comparing dyno numbers is worthless. If anything you can somewhat compare time slips. Other than that how does it feel?
Old 09-25-2007, 12:32 PM   #10
calsonic65
Member#: 93815
2003 WRX
The car feels much faster than stock i can really tell.
Old 09-25-2007, 12:46 PM   #11
STiBottom
Member#: 127041
02 WRX
Midnight Blue Pearl
Well throw some more info. out there.... what was the temp in the shop? What was the humidity that day? Were there fans blowing into your front mount? What was your elevation. All of which can sway the results. If your happy with the way the car drives then let it go. Numbers don't mean anything unless they are in seconds.
STiBottom is offline   Reply With Quote
Old 09-25-2007, 12:55 PM   #12
calsonic65
Member#: 93815
2003 WRX
yeah that's what i was thinking but there is nothing i can do now.
Old 09-25-2007, 12:58 PM   #13
calsonic65
Member#: 93815
2003 WRX
I didn't know what was the temp on that day also the humidity and the elevation. All i know is that "YES" there was blowing into my front mount.
Old 09-25-2007, 01:00 PM   #14
calsonic65
Member#: 93815
2003 WRX
Originally Posted by rexman2002 View Post
Dynojet....?!
Does anyone know how much stock WRX make on Mustang dyno, if anyone know plz share.
Old 09-25-2007, 01:01 PM   #15
calsonic65
Member#: 93815
2003 WRX
What psi are you running and what kind of gas are u using?
Old 09-25-2007, 01:03 PM   #16
ScoobySnacker
Member#: 105303
2003 WRX
I made 240/240 with a stock turbo on a mustang dyno. It does seem low to me..16psi
ScoobySnacker is offline   Reply With Quote
Old 09-25-2007, 02:52 PM   #17
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
My question is:
Your # is completely wrong. I cant believe you left the shop with that #. I wouldnt have let them take my car off the dyno until it said i had 300 whp.
You should take it back to them and tell them they need to learn how to tune and that you read on nasioc that you should have 300whp.
Go read this http://forums.nasioc.com/forums/show...k+mustang+dyno
Thats a weird way to quote your #'s. Not just 290whp or 285 whp, but 286-290whp 4hp range. sorry im tired, but thats funny.
Old 09-26-2007, 12:19 AM   #18
calsonic65
Member#: 93815
2003 WRX
Any recomendation shops other than Harman Motive. I lived in torrance and i dont mind driving as long as it stil in LA area.
Old 09-26-2007, 01:00 AM   #19
schneid
Member#: 105704
05 WRX Cobb Stg. 2
white
isnt that torque still ridiculously low, all things considered?
schneid is offline   Reply With Quote
Old 09-26-2007, 01:51 AM   #20
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Just made me crack up!!!
Equilibrium Tuning is offline   Reply With Quote
Old 09-26-2007, 01:53 AM   #21
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
oh noes... the random number generator gave a low number!
there is no right or wrong number... every dyno reads a little differently. take it to the track and see what kind of times you run... if your times (traps) are similar to other guys at the track with similar setups then you're where you should be.
TROLL is offline   Reply With Quote
Old 09-26-2007, 05:35 AM   #22
calsonic65
Member#: 93815
2003 WRX
thanks for the answers everyone
Old 09-26-2007, 12:29 PM   #23
Phatron
Member#: 36033
CEO PhatBottiTuning
cal, i hope you know i was joking.
I had my car tuned at harman too.
I'd suggest getting an 16g, 18g, or 20g. My neighbor actually has a 16g that he had on his 02 WRX that he'd probably sell you. He put down 300/300 on harmans old dyno with it. Just PM me if you are interested and I'll get a hold of him.
I would think your FMIC might be hurting you. Most people dont run them with the VF series turbos.
And a alky injection kit would do wonders too. My neighbor picked up 50whp and 75 ft*lbs with his alky on harmans old dyno.
Old 09-26-2007, 01:46 PM   #24
The Blue Pilot
Member#: 101880
2012 Mustang GT
BS....
The Blue Pilot is offline   Reply With Quote
Old 09-26-2007, 01:50 PM   #25
capamerica
Member#: 105056
2005 WRX
WR BLUE
I made 284WHP/262WTQ on a mustang dyno, 93oct fuel. 17.1psi
capamerica is offline   Reply With Quote
Question about open source tuning Chasey Newbies & FAQs 8 06-05-2010 09:02 AM
Question about vf34 set-up anthonyrod1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-15-2009 02:09 PM
Question about VF34 turbo gopsu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 09-15-2006 01:06 AM
question about vf34 WrXwaBBit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-22-2004 09:18 AM
Two questions about the VF30 and VF34 Corn-Picker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 04-23-2002 07:43 PM
