Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 09-25-2007, 01:37 PM   #1
STi5ubie
Member#: 89527
2005 STi
Default Anyone with the Perrin EBCS and GT35r?
I have the ebcs and have port 1 connected to the wg, but i dont know where to plug the other line to see as i dont have an intake or anything like that. I searched on google for instructions and found stock setup instructions. Any help would be greatly appreciated.
thanks again,
-albert
STi5ubie is offline   Reply With Quote
Old 09-25-2007, 01:55 PM   #2
cnstman
Member#: 9548
2004 WRX STi
10.154 @139 @ 7,000'DA
cnstman is offline   Reply With Quote
Old 09-25-2007, 04:14 PM   #3
bigmike25rs
Member#: 83924
2005 HTA 86 STi
10.66 @ 136 mph
Just as a side note: I believe the EBCS can only tune to 24psi.. That will be fine on pump, but race gas will require some better boost controll.. I had the same setup last year (EBCS + 30R) and Tim Bailey recommended a DTEC or AVCR for better controll.
bigmike25rs is offline   Reply With Quote
Old 09-25-2007, 05:30 PM   #4
x99percent
Member#: 27108
2004 STi
2004 A4
The EBCS, when controlled by the factory ECU, can only control boost up to ~22-24psi, unless you use a different MAP sensor. With a new MAP sensor, the ECU actually understands higher boost levels... but it won't report them in a datalog. You have to tune your WG maps using the "turbo dynamics" feedback data from a log.
Info: http://www.cobbforums.com/forums/showthread.php?t=36714
x99percent is offline   Reply With Quote
Old 09-26-2007, 12:40 AM   #5
bboy
Member#: 56468
04 Improved STI
Dirty White
How is this a built motor forum issue.
Anyone with the Perrin kit have this problem? 03clipsegts Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 08-19-2007 01:06 PM
what is your WGDC % with the Perrin EBCS? mogrl840 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 08-01-2007 08:51 PM
Anyone with the Perrin TBE 3" Exhaust BriGuy Newbies & FAQs 25 06-15-2006 10:41 AM
Fitment issues with the Perrin GT35R kit?? dream Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 67 05-10-2006 09:33 AM
Anyone with the Perrin rotated kit chime in! SupraScooby Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 05-09-2006 01:23 PM
