Welcome to the North American Subaru Impreza Owners Club Thursday December 18, 2014
Old 01-14-2002, 08:25 PM   #1
MporTluvR
Member#: 14095
2007 07' Sti
Urban Grey Metallic
Unhappy Check engine light after CAI install
i just installed a AEM CAI on my 02 Wrx.....i have only had the car for a week......the car now sounds incredible......but just doesnt pull nearly as hard as it did before the install....i am sure it has something to do with the CEL ..it seems to bawg a lil bit when i shift at a higher rpm..........not sure how to read the CEL code....any kinda help would be much appreciated.....thank you very much
MporTluvR is offline   Reply With Quote
Old 01-14-2002, 10:16 PM   #2
MagicMT
Member#: 4042
2001 Magic Mobile
Old School Style
Did you reset your ecu?
Mike
MagicMT is offline   Reply With Quote
Old 01-14-2002, 10:36 PM   #3
MporTluvR
Member#: 14095
2007 07' Sti
Urban Grey Metallic
how do i reset the ecu? MporTluvR<------------ =Newbie
Thanks
Old 01-14-2002, 11:47 PM   #4
Austin
Member#: 7089
To reset the ecu pull the negative battery cable and let the car sit for 1/2 hour, or pull the negative cable and step on the brake pedal. You really should have the code read, though. Post in your local forum and try to find someone local to you with an OBD2 scanner.
Austin is offline   Reply With Quote
Old 01-15-2002, 12:01 AM   #5
Ronin2121
Member#: 13798
02 Wrx
Thumbs down Air Intake
I also installed a Blitz Sus intake (stainless steel) and it kept popping up a cel. Reset the ecu three times. Been trying to get ahold of Blitz to find out if they have a fix. NO RESPONSE!!!
Anyone who reads this.....STAY AWAY FROM BLITZ!!!
Ronin
Ronin2121 is offline   Reply With Quote
Old 01-15-2002, 09:19 AM   #6
Jarrod Li
Member#: 521
2000 Impreza GT
RBP
MporTluvR, which direction do you have the harness wires facing when they come out of the sensor? Are they point towards the front of the car, or the rear? They should be pointed towards the front, and then the cables run to the rear. If they are pointing to the rear then you have the first pipe in backwards which usually causes a CEL right away because the sensor is essentially in backwards. The sensor has different size openings on either side and is only supposed to receive direct air flow into one of the sides. If it gets more air than it is expecting from the other side you'll get a CEL.
As a side note I've had my cel come on and go off 2x now since I've installed the AEM intake. The car didn't go into limp mode either time and the light shut off before I got a chance to scan for the code.
Jay
Jarrod Li is offline   Reply With Quote
Old 01-15-2002, 10:15 AM   #7
wrx182
Member#: 9531
2002 WRX Sport Wagon
I've had the AEM on for months now with no problems what-so-ever. Go back and be sure everything is on tight, especially the MAF sensor...
I have heard of people having problems with the Blitz though...
Jim
www.wrx182.net
wrx182 is offline   Reply With Quote
Old 01-15-2002, 10:45 AM   #8
Jarrod Li
Member#: 521
2000 Impreza GT
RBP
I'm pretty sure that my CEL was unrelated to the intake. In both cases I was heading towards the exit in the same parking lot, going very slowly.
Jay
Old 01-15-2002, 08:37 PM   #9
MporTluvR
Member#: 14095
2007 07' Sti
Urban Grey Metallic
thanks guys for the help....i appreciate it alot......i reset the ecu.....and so far......the power feels stronger(like stock) and no CEL......soooooooo i hope everything is ok.......it turns out.....originally....i had the inner intake piece....facing the wrong direction.....which made the sensor face the wrong direction....and in turn would not let my car start....i was pretty pissed before i realized what mistake i had committed......and at one point......before i fixed that situation......i had my ignition turned completely forward with my MAF not plugged in at all....which threw the CEL........all in all im happy now....thanks to you guys oh yeah.....the turbo sounds soooooo kewl now.
thanks
Old 01-16-2002, 05:16 PM   #10
Snowphun
Member#: 1800
WRX /WRX/Cooper S
awd/awd/fwd
Originally posted by MporTluvR
Are you trying to make your posts as difficult to read as possible?
Snowphun is offline   Reply With Quote
Old 01-16-2002, 11:18 PM   #11
MporTluvR
Member#: 14095
2007 07' Sti
Urban Grey Metallic
yes
check engine light after exhaust install bwilke34 Engine Management & Tuning 10 04-10-2009 06:28 PM
04 STi - Check Engine light after Short Ram Intake install STinewbie Interior & Exterior Modification 10 05-31-2005 08:19 PM
Check Engine Light After Catless Dp Install Subie123Poot Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 08-08-2004 10:54 AM
check engine light after installing injen cai RuCKuS Normally Aspirated Powertrain 12 09-29-2002 11:16 PM
Check Engine Light after crank pulley install RebelINS Normally Aspirated Powertrain 10 06-11-2002 08:56 PM
