Old 01-14-2002, 08:36 PM   #1
RDJ8o
Member#: 8682
Platinum Silver
Default Will these rims fit my car??
I want to get a set of rims from ADR they are called the Version II and 2 rims in the set com in at 18x8--225/40/18 and the second one come in at 18x9--245/40/18 my question is if i get a set of rims with 2 being different width will that be bad for my car in terms of the differential and will it hurt it in terms of performance cause its 2 different size rims on a awd system. oh by the way adr sends the rim out like that with 2 being different size from the other i gues so the rear wheel has more weight i gues for when you drop the clutch you don;t spin your tires and if you want to see what the rims look like go to wheelmax.com and go to adr and it should be the first set of wheels on the left called "Version II"... ANd can some one send me a site were they have a good set of rims and why does the offsetting have to be more the 50 why can;t they be 4o like these???
RDJ8o is offline   Reply With Quote
Old 01-14-2002, 08:38 PM   #2
RDJ8o
Member#: 8682
Platinum Silver
Oh by the way i have a wrx still all stock and now i'm plan on going for looks then performance and i want to get the M2 DMS coilovers with whatever rims i get if that helps
Old 01-14-2002, 08:39 PM   #3
WagonMonster
Member#: 3781
2002 Legacy GT Wagon
2009 Forester X Limited
NO!
On an AWD car all tires MUST be the exact same size, period.
WagonMonster is offline   Reply With Quote
Old 01-14-2002, 08:46 PM   #4
Paul Sakai
Member#: 2513
2000 RS Coupe
Silverthorne
No they won't fit. The offset is too low and you will have rubbing issues, along with probably killing your AWD system. The offset is how your wheel is centered and you should try to stay within 48-52 or something like that.
Paul Sakai is offline   Reply With Quote
Old 01-14-2002, 09:14 PM   #5
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Um, offset was not noted in the post... the 40 in 225/40/18 is the aspect ratio of the sidewall of the tire to the the width of the tire. Offsets are either + and an integer, - and an integer, or zero . What you have there is tire dimensions . Get the offset of the rims and then we can better let you know if they will fit. However, as noted above, you cannot have two different sized sets of tires or rims on the car- all 4 must match.
Brian
http://www.northursalia.com
http://www.imprezamods.com
http://www.scoobymods.com
Old 01-15-2002, 12:08 AM   #6
Dolphin Overton
Member#: 1925
01 A4 89 944s2
13 Speed 3R 99 Sprint
or last year or decade... no they will not fit. They will stick out of the fenders. Like they said all tires must be the same size or your diffs will go boom!!!
Dolphin Overton is offline   Reply With Quote
Help: Will these rims fit my '02 WRX? Beowulf Tri-State Area Forum 6 06-09-2006 11:59 PM
will these volks fit my car sti subaru222 Tire & Wheel 4 02-14-2006 12:18 PM
will these rims fit my STI RonBang Tire & Wheel 5 01-19-2004 04:27 PM
Will these rims fit my car?? SilverGhost Tire & Wheel 3 11-06-2003 02:42 PM
Will these rims fit my car? brat Technical Forum Archive 1 09-28-2000 10:41 AM
