Old 09-25-2007, 11:20 PM   #1
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
03 R1 09 Raptor 700R
Default where the F does this line run to?
I'm swapping an 06 block into my car and I can't figure out where this line goes. I posted it up in "Conversions" but no one seems sure.
[IMG][/IMG]
domestic_abuser is offline   Reply With Quote
Old 09-25-2007, 11:52 PM   #2
ovedrivex
Member#: 116774
1997 Project GC8
all i can tell you is its the water bypass pipe
ovedrivex is offline   Reply With Quote
Old 09-26-2007, 12:56 AM   #3
ovedrivex
Member#: 116774
1997 Project GC8
ok i tried finding it for you in the manual so could just load the diagram. but for some reason the whole assembly does not exist in mmy manual.but i went out and looked at the table of parts i have. but it connects to a pip under your intake manafold right behind the the thing that connect the radiator to the block. its a pipe that is bolted directly onto you block it runs from the bottom of the water tank to the pipe in question. and to help identify it even more it runs parallel to another black pipe that has a rubber hose right in the center of the pipe that plugs right into your block. also this should be the same set of pipes that your engine harness are bolted onto.
Old 09-26-2007, 01:12 AM   #4
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
thanks for the help, I really appreciate it!
Old 09-26-2007, 01:29 AM   #5
ovedrivex
Member#: 116774
1997 Project GC8
np let me know if you have anymore questions.
Old 09-26-2007, 05:53 PM   #6
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
Are you saying there is another hard pipe running across the block? If so I'm in a world of hurt!
Old 09-26-2007, 06:13 PM   #7
dan avoN7
Top Scoob 002
Member#: 32771
03 Black WRX
04 White M3
the hard black line that has the arrow pointing at it is a coolant line. usually there is a 4" section of rubber hose that then connects to another hard black line that leads to your coolant tank that is mounted on the intake manifold. You can simply run a long coolant hose from this line to the tank to bypass the hard line that you might not have.
dan avoN7 is offline   Reply With Quote
Where does this line go? acurarsx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-22-2009 03:27 PM
Ice on the inside of the windows, does this happen to anyone else? msingell Newbies & FAQs 11 02-25-2008 10:26 AM
What in the hell does this sound like to you? White 2.5rs Normally Aspirated with bolt-on Forced Induction Powertrain 24 11-11-2006 12:10 PM
Where does this hose go to? Inprogress Texas Impreza Club Forum -- TXIC 17 12-01-2005 11:22 AM
Where the heck does this thing go? RokketRide Brakes, Steering & Suspension 1 03-28-2003 03:16 PM
