Old 09-26-2007, 11:43 AM   #1
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
Default WRX 2.0L 20G Dyno w/ Ecuedit
To some this may not seem "official" but supposedly ecuedit does a fairly good job of plotting power/torque within 5% of what a typical load bearing dyno would report. But hey, all these tuners are using correction factors anyways to skew results.
The numbers seem to be on-par with my datalogs and what boost pressure I'm running so here it is:
^- 335whp & 298wtq
Details:
'02 WRX
Stock block and stock 5mt
Blouch td05-20G 7cm^2
STI tmic
Silicone inlet
3in tbe
modded stock injectors
Perrin drop-in filter w/ stock airbox
A/F is 10.8:1 at peak boost and 11.2:1 at redline.
Boost is 22.5psi.
Running 93oct pump gas.
Enjoy
akira02rex is offline   Reply With Quote
Old 09-26-2007, 12:12 PM   #2
crazymikie
Member#: 56321
2006 Honda El Camino
Green
Would you mind sharing a log with your boost and engine load numbers?
I'm curious to see how well they correlate to the torque curve.
Thanks!
Mike
crazymikie is offline   Reply With Quote
Old 09-26-2007, 12:57 PM   #3
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
Thanks!
Mike
There is a log posted in Enginuity. But I must warn you, do not compare to your own vehicle's logs because my MAF table is scaled to 400g/sec.
The boost curve is also posted there. I can sum it up by saying it hits 22.5psi by 3800rpm and tapers to 20.5psi by 6500rpm.
Old 09-26-2007, 01:02 PM   #4
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Why does it taper? A 18G could hold 23 psi until about 6800 rpm and put down identical numbers. Maybe a pressure drop across the intercooler?
Old 09-26-2007, 01:14 PM   #5
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 551/441
Cam roll off no need to push more boost when it doesnt want it. Most people drop the boost towards redline
robbieshonda is offline   Reply With Quote
Old 09-26-2007, 01:24 PM   #6
Master2192
Member#: 83254
98 2.5 RS
04 WRX
Most of the time the boost drops off toward redline because the turbo can't keep up. In this case I believe the intercooler is showing some amount of restriction possibly from its small size. Other reason to drop boost toward redline, excessive back pressure causing detonation (too small exhaust side on turbo, needs external wastegate).
Old 09-26-2007, 02:06 PM   #7
lawn boy
Member#: 16345
2003 WRX- Sold
E60 BMW 545i
stock clutch too? hows it holding up?
lawn boy is offline   Reply With Quote
Old 09-26-2007, 03:48 PM   #8
SnoCoWRX
Member#: 126499
2004 Dodge Ram 2500
Cummins Turbo Diesel
Ehhh, nevermind.
SnoCoWRX is offline   Reply With Quote
Old 09-26-2007, 04:12 PM   #9
Master2192
Member#: 83254
98 2.5 RS
04 WRX
Originally Posted by SnoCoWRX
Ehhh, nevermind.
Old 09-27-2007, 10:32 AM   #10
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
It is the intercooler holding me back and possibly because the stock headers as well. But, the numbers are pretty good considering it's an sti tmic, if you will.
I have never seen an 18g hold 23psi past 6000rpm either. It is tapered because of the limits of the entire system. I did not taper it myself because I'm using an mbc if that proves anything.
Testes is running very similar numbers, actually almost identical, to mine using a big tmic.
Old 09-27-2007, 10:36 AM   #11
saab-on-the-cobb
Member#: 116330
2005 Saabaru 9-2x
desert sand metallic
NEAT!
Time to take it to the track!
SOTC
saab-on-the-cobb is offline   Reply With Quote
Old 09-27-2007, 10:57 AM   #12
drewwrxrogers
Member#: 132574
04 Aspen White Sti
GT35r, axis motor,280cams
EWG!!!! It will make a world of dif. Hope your savin money for a new tranny, it wont hold long!
drewwrxrogers is offline   Reply With Quote
Old 09-27-2007, 12:17 PM   #13
Master2192
Member#: 83254
98 2.5 RS
04 WRX
Ohh I wasn't saying the numbers were bad Its just you have a restriction and untapped power. You've got the car tuned very good, I would have gone a bit leaner with less timing but thats personal preference.
Old 09-27-2007, 01:16 PM   #14
eqlized_aero
Member#: 88699
2015 TS EFR7163 818S
V9 Spec C Type RA 92x
My 18G will hold 24 PSI to 7K RPM.
eqlized_aero is offline   Reply With Quote
Old 09-27-2007, 01:19 PM   #15
TheShad0w
Member#: 91925
2015 WRX STi
AWDTuning.com
still running a stock motor?
TheShad0w is offline   Reply With Quote
Old 09-27-2007, 01:25 PM   #16
eqlized_aero
Member#: 88699
Yep, stock 2.0L block, stock heads. Everything else is not stock.
Boost gauge reads 24 PSI all the way to redline.
Old 09-27-2007, 01:26 PM   #17
eqlized_aero
Member#: 88699
Nice 20g setup btw.
Bringing it to the shootout on Saturday?
Old 09-27-2007, 01:29 PM   #18
testes1010
Member#: 47145
2012 Gas Saver
very similar numbers, I am running a Hyperflow TMIC, Crucial P&P&C'd Manifolds & an UR/Tial 38mm EWG setup, Hallman PRO for boost control. I hold 23psi to redline, no problem.
this was last dyno I have on file.
testes1010 is offline   Reply With Quote
Old 09-27-2007, 02:53 PM   #19
TheShad0w
Member#: 91925
2015 WRX STi
AWDTuning.com
Not to go OT or anything - but I'm interested in what type of MAF housing and what type of measurements (if any) you have had as far as g/s and engine load.
Pretty impressive that these engines are holding up so well considering the design and all.
Old 09-28-2007, 02:05 AM   #20
eqlized_aero
Member#: 88699
I'm using a perrin blow thru maf, which is 3" in diameter where the maf sits. Not sure what I'm scaled to, so whatever g/s I get wouldn't mean much.
Old 09-28-2007, 02:34 AM   #21
turb04
Member#: 61386
04 PSM WRX R.I.P.
05 Snow White Camry
great #'s..
turb04 is offline   Reply With Quote
Old 09-28-2007, 03:07 AM   #22
Suberman
Member#: 82487
2007 WRX STI Spec C
what gear did it hit 22.5psi by 3800rpm? That seems really early as compared to my crap tuned 18g only hitting 22psi by 4500+rpm in 3rd with my STI RA ratios with 4.444 final drive. Its probably not loading the engine enough.
Suberman is offline   Reply With Quote
Old 09-28-2007, 03:11 AM   #23
Master2192
Member#: 83254
98 2.5 RS
04 WRX
^^^That also depends on your boost control. He is using a MBC which usually has the fastest spool up possible.
Old 09-28-2007, 03:22 AM   #24
Suberman
Member#: 82487
2007 WRX STI Spec C
I'm running AVCR
Old 09-28-2007, 09:29 AM   #25
testes1010
Member#: 47145
2012 Gas Saver
Originally Posted by Suberman View Post
I'm running AVCR
you need to retune it OR get a different BC.
2.0L 20g 100 octane RexFTW Proven Power Bragging 46 02-12-2010 02:09 AM
2004 2.0l GT28RS - dyno test and pictures Built Industries Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 07-22-2009 08:27 PM
2004 WRX 2.0L - VF39 / TMIC / TBE / Injectors / Up-pipe - DYNO PLOT!!!! AMR Proven Power Bragging 21 09-26-2008 02:47 PM
Wrx 2.0l Td06h-20g Weedy Proven Power Bragging 29 11-13-2007 12:06 AM
20G on a WRX 2.0L wrx904 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 46 09-27-2006 01:04 AM
