Old 09-26-2007, 08:00 PM   #1
spoolinred
Member#: 117017
03 2.0fpred wrx!!
blue
Default perrin 3" intake, is this normal?
i was putting the power steering pump back on my motor today and the intake tube was not letting it go back far enough. finally i got it pushed back, but the pump is pushing in on the intake, is this the way it works or did i not do something right?
spoolinred is offline   Reply With Quote
Old 09-26-2007, 10:06 PM   #2
spoolinred
Member#: 117017
03 2.0fpred wrx!!
blue
come on guys i know someone can anwser this question for me...
Old 09-26-2007, 10:14 PM   #3
bigmike25rs
Member#: 83924
2005 HTA 86 STi
10.66 @ 136 mph
That's how I've seen it on a few cars..
bigmike25rs is offline   Reply With Quote
Old 09-27-2007, 10:10 PM   #4
nsucdm_wrx
Member#: 39771
02 FPRed 2.5l WGN
Built heads ;)
I had the same issue...that inlet is a PITA
nsucdm_wrx is offline   Reply With Quote
Old 09-27-2007, 10:22 PM   #5
spoolinred
Member#: 117017
03 2.0fpred wrx!!
blue
yeah i know what you mean, it is super tight against my pump, i hope it doesn't eventually rub a hole in it....plus that takes away from some of the airflow...or so i would think
Old 09-28-2007, 10:44 AM   #6
noisycricket
Member#: 148043
The turbo couldn't flow enough for the little kink to cause a noticeable restriction. I wouldn't worry about it.
noisycricket is offline   Reply With Quote
Old 09-28-2007, 12:17 PM   #7
Freon
Member#: 88322
2009 BMW 135i
This seems typical. One of the local just installed one on his FP Green and it is loose on the intake manifold side and pushing again the PS pump. It looks like the whole piece should sit farther back, but it was fully seated on the turbo inlet.
Freon is offline   Reply With Quote
My first TURBO car. Is this normal? Carartist Newbies & FAQs 6 06-03-2010 06:50 PM
FS-> FP Green 3", perrin 3" intake, 70mm APS CAI, APv1 silvergrey05 Engine/Power/Exhaust 9 10-14-2008 11:36 AM
is this normal for the normal headlight sequence for an 07 outback? jawwadh Electrical & Lighting 6 08-08-2008 11:34 PM
Perrin FSB - is this normal? runwrxrun Brakes, Steering & Suspension 7 11-05-2006 01:08 PM
Reserve is hard to engage 3 out of 5 times... Is this normal? MrP0nch0 Technical Forum Archive 23 08-29-2000 05:28 PM
