Welcome to the North American Subaru Impreza Owners Club Friday March 27, 2015
Old 09-27-2007, 03:14 PM   #1
singincanary
Will mod for Guinness
Member#: 77921
'02 Foz
'07 'beca, '08 OBXT
Default Engine swap, '06 2.5i into '00 2.5RS--Direct swap?
I imagine that the wiring harnesses might be a little different, but how hard is the swap of an '06 2.5i (RS) into a 2000 RS. Current engine has pretty high miles, so looking for cheap alternatives.
Hopefully not to hard. I know that the '06 doesn't have AVCS (or so I've been told).
Any help is appreciated.
singincanary is offline   Reply With Quote
Old 09-27-2007, 03:34 PM   #2
ovedrivex
Member#: 116774
1997 Project GC8
whether or not it has avcs wiring will be the hardest part.you will have to merge the engine harness with you rs chaise/dash harness. so you will need a complete wiring diagram from both cars. but as far as mechanics go it drops right in. if you ask me if your gonna do all that you would be better off wiring in a wrx engine(more options and actually worth the pita wiring)
ovedrivex is offline   Reply With Quote
Old 09-27-2007, 05:02 PM   #3
jamesfacts
Member#: 51282
98 RS
black & blue from parking
This isn't exactly true. I'm pretty confident the 06 does have AVCS but you don't need to hook that up. You won't have to worry about wiring either as both motors are phase II, so you can just toss the old intake mani on the new motor.
jamesfacts is offline   Reply With Quote
Old 09-27-2007, 05:12 PM   #4
singincanary
Member#: 77921
'02 Foz
'07 'beca, '08 OBXT
Great news. Thanks a bunch.
Old 09-27-2007, 05:19 PM   #5
ALaDDiN
Member#: 98294
2004 Honda Civic
2006 Acura TL
So it would just be using the old Intake Manifold, with the new heads and block (the long block)?
ALaDDiN is offline   Reply With Quote
Old 09-27-2007, 09:49 PM   #6
kwh29
Member#: 22100
Yes. Randy Zimmer is apparently doing this now on one of his street car beaters.
Another option is to have the old heads rebuild and use the '06 short block. As best as I've seen the short block is completely interchangable.
--Kevin H.
kwh29 is offline   Reply With Quote
Old 09-27-2007, 11:44 PM   #7
singincanary
Member#: 77921
'02 Foz
'07 'beca, '08 OBXT
is the trany interchangeable as well, 5 speed to 5 speed?
Old 09-28-2007, 12:49 AM   #8
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
It may have AVLS or i-AVLS, but only the turbo 2.5Ls and the EZ30R have AVCS. I've never figured out what the difference was (if any) between the EZ30R's AVLS and the EJ25's i-AVLS. On the EZ30R, AVLS is basically just controlled by an on/off solenoid, so you could easily wire in an RPM switch to "turn on" the higher lift cam profile at, say, 4000rpm. I don't know if it's that easy with the EJ25's i-AVLS.
Concur - assuming, of course, that the old manifold bolts up to the newer heads. (Edit: When I posted this initially, I was thinking the new heads had a different bolt pattern, but I think I was wrong. I think the '00 manifold will bolt up to the '06 heads without issue.)
Should be. AFAIK Subaru 5-speeds are interchangeable all the way back through the mid-90s.
Pat Olsen
Old 09-28-2007, 01:36 AM   #9
ovedrivex
Member#: 116774
1997 Project GC8
well if all hes really doing is changing blocks and heads/possible just rebuild. would it be better to buy a new ej257block and just rebuild the heads?
Old 09-28-2007, 11:23 AM   #10
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
Only if he's planning to use forced induction. The EJ257 is the STi block with a low compression ratio. EJ251 or something is what you're looking for in an NA application.
jey is offline   Reply With Quote
Old 09-28-2007, 12:19 PM   #11
singincanary
Member#: 77921
'02 Foz
'07 'beca, '08 OBXT
Planning on swapping an '06 n/a into my '00 n/a. found a good deal on a low milage '06 engine and want to replace my aging (200k) engine.
Old 09-28-2007, 02:34 PM   #12
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
does the 05+ na 2.5 have high density crank and cam
if thats the case then no just swapping the manifold won't work at all
Old 10-01-2007, 09:53 AM   #13
singincanary
Member#: 77921
'02 Foz
'07 'beca, '08 OBXT
I have no idea. Anyone else know?
Old 10-01-2007, 09:47 PM   #14
neko
Member#: 46500
Now with 100% more
room 4 girl-on-girl fun.
not sure about the 06 motor, but i know my son's mother's '00 RS has a '03 2.5L in it and runs great. doesn't look like they hacked any wires at all. just the new motor, trans, and ecu from the 03.
The 2 major external differences i know of in the engine bay are the A/C (need to bolt the older compressor onto the newer block), and the PS pump setup needs to be the older one too. ALT doesn't matter i don't think.
neko is offline   Reply With Quote
2.5i - Borla headers - 2.5rs Catpipe - Catless midpipe - stromung Axleback Un0RiGiNaL Engine/Power/Exhaust 14 01-27-2010 02:03 PM
FS: Ingalls camber bolts and '00 2.5rs rear seats Cyclops NWIC Private Classifieds 24 04-30-2009 03:01 PM
2005 2.5RS or 2006 2.5i or 2006 2.5 wagon Prelude Canada Region Forum 16 09-21-2005 04:10 PM
'02 2.5RS TRANNY into '00 2.5RS?????? 4WDRFT 74 Transmission (AT/MT) & Driveline 1 09-26-2004 11:25 PM
