Old 09-27-2007, 07:58 PM   #1
ec2k1gt
Member#: 129631
06 Obp Sti
back to slow lolz
Default CYL 4 Bad Piston Ring?
I pulled my motor out recently due to my Compression test results which were 120psi on cyl 123 and 60psi on cyl compression test was done on a cold motor.
I finally cracked it apart last night and took pics, I noticed that cyl 4 has some carbon buildup on the intake side of the piston. Which none of the other pistons show signs of? Ive attached pics you can see some slight scoring in the 2nd pic is it safe to assume that its a broken ring?
ec2k1gt is offline   Reply With Quote
Old 09-27-2007, 08:36 PM   #2
TAPOUT
Member#: 127670
2007 HTA GT3794
Darton Sleeved
Looks like you need some new pistons....
TAPOUT is offline   Reply With Quote
Old 09-27-2007, 10:15 PM   #3
STi_Guy04
Member#: 69461
2004 WRB/Sti
11.41 @ 123mph
very interesting... I had the same cylinder go bad as well my compression test results where cyl1-137 cyl2-135 cyl3-135 cyl4-110 and it smokes out the tali pipe...
Its funny Number 4 seems like the cylinder that always lets go! I have had another motor with the same issue Broken ring land #4 cyl..
Good luck with the project, I guess get some good pistons
STi_Guy04 is offline   Reply With Quote
FS: CP Piston Ring Set for 99.75mm Pistons alcoolaid Engine/Power/Exhaust 0 05-29-2010 07:58 AM
ej22t piston rings for stock pistons gto7419 Pre-2002 Factory Turbo Powertrain 6 04-06-2009 09:29 PM
Ring Failure... what piston rings to get? exekious Built Motor Discussion 24 06-04-2007 01:05 PM
FS WRX EJ205 shortblock, low compression cyl 4. Probable rings Davenow New England Impreza Club Forum -- NESIC 0 06-16-2005 11:49 AM
Please Help! Misfire Cyl #2, badly running, bad smell bobgrice Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 06-06-2003 04:09 PM
