Old 09-26-2007, 04:25 PM   #1
superg
Member#: 3385
Default Experience with "simple" Ej205/257 hybrids?
I am considering an EJ257 shortblock but otherwise not changing anything on my stage 3 VF34 WRX motor.
There are lots of reports here on built motors here with pistons, cams, etc...
What outcomes, troubles, etc. have folks had with simple EJ257 shortblock swaps on stage 2-3 Ej205s?
superg is offline   Reply With Quote
Old 09-26-2007, 04:40 PM   #2
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
id say lots of torque
mxpunk is offline   Reply With Quote
Old 09-26-2007, 05:22 PM   #3
superg
Member#: 3385
Yeah, torque for sure. I should have been more specific:
What longevity/durability/headaches can I expect compared to the original engine, which has been bulletproof for 130,000 miles.
Superg
Old 09-27-2007, 12:20 AM   #4
wrxed04
Member#: 67115
2005 STi
Same question I have - blew my engine, considering a hybrid w/reworked stock wrx heads and sti short block. Any recommendations on related mods and likely cost?
wrxed04 is offline   Reply With Quote
Old 09-27-2007, 12:52 AM   #5
Living Weapon
Member#: 147857
2002 Weapon WRX
'02 Wagon WR Blue
Would love to hear from those who have done this with a stock or mildly prepped bottom end.
Subscribed.
Living Weapon is offline   Reply With Quote
Old 09-27-2007, 01:37 AM   #6
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
As long as the compression ratio is worked out properly (ie, no 12-1, or valves tapping pistons), longevity, durability should be 100% on a new ej25 shortblock. Why? Cause its new.
reddevil is offline   Reply With Quote
Old 09-27-2007, 02:05 AM   #7
Living Weapon
Member#: 147857
2002 Weapon WRX
'02 Wagon WR Blue
Duh, I finally figured out the right search terms: 2.5 hybrid
Turned up a bunch of good info regarding possible headaches, and how to avoid them
Old 09-27-2007, 03:27 PM   #8
superg
Member#: 3385
Default My hope
I've done the 2.5 hybrid search, too.
What I am hoping for:
Assuming my WRX heads are in good condition; newish VF34, new EJ257 shortblock; replaced "wear items" like water and oil pump, timing belt; well and conservatively tuned Ecutek without pushing boost levels; UP, DP...
... should last as long as a fresh EJ205 similarly set up, say at least 50,000-75,000 miles.
That is, assuming its assembled well, driven respectfully and well maintained.
Anyone have evidence for or against this scenario?
The heads being the oldest part of the hybrid, will they be the "weak link" going forward?
Superg
Old 09-27-2007, 07:30 PM   #9
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
Detonation is the only thing you need to worry about with the standard hybrid swap - the pistons crack ring ring lands easily. How does that happen? Not enough fuel/too much boost/timing. If the tune is conservative and you're not pushing things your setup will last just as long as a USDM STi - 'cause that's pretty much what you've got (minus the AVCS and STi cams).
PeteDucati is offline   Reply With Quote
Old 09-28-2007, 12:28 AM   #10
Twiztidunreal
Member#: 63249
2004 2.5 STI Wagon
05 FXT Black
i am running a hybrid
ej257 SB(stock) with 04 wrx heads(only 30* backcut valves) other wise stock, fmic, headers, lightened crank pulley, and a 18g to boot..... as long as the tune is good, the 9:1 compression helps off boost power as well as spool up, and u make the same/more power with less boost
Twiztidunreal is offline   Reply With Quote
Old 09-28-2007, 12:34 AM   #11
Twiztidunreal
Member#: 63249
2004 2.5 STI Wagon
05 FXT Black
ive heard this, but(flame suit on) my mbc is set at 16 psi right now, my real time map is for 18psi, my base map 13psi... 2 twice now when my battery cable came lose, it reset my ecu, there for bye bye real time map.
i didnt think anything of it, took off, got on the freeway, got up on it, car hits 16 psi, cell flashs, car pulls timing(i assume from knock sensor detecting det.)
this has happened twice now(i hope never again), and also why i will get a real base map made for my psi instead of a OTS map.
Car still runs fine, compression fine across the board
mind you this is at lower power(16psi) at higher power, i can see det. killing the pistons
C.N.
its all in the tune..
Old 09-28-2007, 11:45 AM   #12
Le Saboteur
Member#: 142244
2007 SWP STi
WFC #243
stock block (2.5) stock headssss (2.0) VF39 17psi
replaced all necessary stuff
injectors
fuel pump
oil pump
belts etc
i think thats it...can't really go past 17psi w/o alc or headwork
timing pulled back a good bit...
torque is really fun i run all over my girlfriends evo...for now...
Le Saboteur is offline   Reply With Quote
Old 09-28-2007, 09:28 PM   #13
Redscoob
Member#: 96662
2002 hybrid wrx
sedona red
i have a 2.5sb with 2.0 heads from my wrx running 12lbs with timing pulled to be safe. i ran a 13.01 with the stock wrx intercooler. tons of low end power and no waiting for boost on the vf39.
Redscoob is offline   Reply With Quote
2000 rs with ej205/257 hybrid swap vf39 jardine Private Vehicle 'For Sale' Classifieds 47 09-03-2010 05:41 PM
Running EJ205/257 short/longblock kromHASaWRX Private 'Wanted' Classifieds 3 04-12-2010 09:40 AM
Ej205/257 ARP Head studs CoolRex Engine/Power/Exhaust 2 01-09-2010 09:35 AM
ej257 short block with ej205 heads - Hybrid Setup 007WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 01-27-2009 02:53 PM
Any experience with the JDM EJ205??? skiblur Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 10-03-2005 09:00 AM
