South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 09-28-2007, 11:28 AM   #1
SkiWrex
Member#: 142559
05 Fozz XT VF39'd
04 Broyota 4runner
Default CEL is KILLING Me...HELP!
I have re-occuring misfire codes that are plaguing me, any suggestions, help, advice would be highly appreciated. I've owned my '03 WRX since March of '07. Bought it in San Diego and drove it home to Salt Lake, after a few weeks of owning it, got my first CEL, it was a misfire on 3 of the cylinders, so I replaced all four plugs with NGK Iridium's. It was fine for two months, no problems. In June I moved to Phoenix and after a few weeks of living here it came on again, but on two of the cylinders, I replaced those plugs again and it was fine for a week or two, and came on again, different cylinder, it has been doing this since then, different cylinders each time (I think I'm on my 9th CEL routine). I've had the lower O2 sensor replaced, I had FAT take a look at it and clean my coil packs, I've cleaned the MAF sensor and air filter. It's always the same thing, I do something that I think will fix it and the CEL stays off for a week or so and them comes on with misfire on diff. cylinder. I use Chevron Premium gas, my only Mods are Snorkus removal with K&N panel filter, and a 3" Cat Back exhaust, (stock D.P. and U.P.) It drives fine, occasionally I'll notice a little erratic idle, but it's so subtle and it lasts only a second or two, any comments or suggestion would be valued.
SkiWrex is offline   Reply With Quote
Old 09-28-2007, 01:07 PM   #2
dozer54321
Member#: 116437
you might wanna contact treefrogaz here on the site, im sure he could help you
dozer54321 is offline   Reply With Quote
Old 09-28-2007, 01:10 PM   #3
shemoves
Member#: 80663
2005 STi
I'd just replace it all at once just to avoid the guessing game. You'll spend more money trying to find it in the long run. So, new plugs, wires, coil pack, and maybe even the battery. The car prolly has a bit of miles on it, so it'd be good to do any way just as a part of maintenance, and you can get upgraded stuff.
Do to the lack of mods, get OEM spark plugs. If after doing all that, then it could be something with the fuel system like a clog/partial malfunction that causes random fuel flow issues.
When replacing things (individually or in groups), try to do so in a manner that allows you to 'check something off the list' without adding a different one on. That may actually be a good starting point...just writing a list on a piece of paper of everything it could possibly be.
Then number items in groups. The groups should be confined to things that affect eachother. For example, the injectors and the fuel filter would be in the same group, but the spark plugs and the fuel pump would be in different groups.
shemoves is offline   Reply With Quote
Old 09-28-2007, 01:17 PM   #4
Caliente Auto
Member#: 59051
2004 WRX Sedan
Replace the coil packs and get a fuel injection flush would be my suggestion.
Caliente Auto is offline   Reply With Quote
Old 09-28-2007, 01:23 PM   #5
racingfish
Member#: 60976
1969 LGT
FATURBO
or take it to a dealership and have it diag'd
ohh its def not the spark plug wires <))><
racingfish is offline   Reply With Quote
Old 09-28-2007, 01:27 PM   #6
r0bman
Member#: 87015
Nah, and I'm pretty sure it's not the distributor either
r0bman is offline   Reply With Quote
Old 09-28-2007, 01:57 PM   #7
LegacyGt05
Member#: 80074
2007 BMW 335i
Sapphire Black Metallic
It could be a bad fuel injector, I know, I have had 4 go bad on my car ... so I'd check that too. Switch them out and see if you get a CEL on a different cylinder.
LegacyGt05 is offline   Reply With Quote
Old 09-28-2007, 02:59 PM   #8
SkiWrex
Member#: 142559
05 Fozz XT VF39'd
04 Broyota 4runner
thanks for the advice, I'm gonna run some Lucas Injector cleaner/lub. through and see if that helps, if not, I might have to just replace the injectors I guess
Old 09-28-2007, 03:01 PM   #9
racingfish
Member#: 60976
1969 LGT
FATURBO
he doesnt have a lgt....
and its common for leggys f.i. to go out. or so ive been told. thats why they switched to the diff feed system.
Old 09-28-2007, 03:16 PM   #10
Member#: 137146
2003 370whp 2.0L wrx
or a fuel filter... in tank filter
Todd@Goodspeed is offline   Reply With Quote
CEL is KILLING me! SkiWrex Service & Maintenance 7 10-05-2007 01:16 AM
Help! This Decision Is Killing Me!!! Red Rexx Mid West Subaru Owners Club Forum -- MWSOC 14 12-12-2004 08:27 PM
Help !!! Popping noise is killing me !!! Chris Cuevas Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 12-03-2004 09:58 PM
Amazon is killing me! Help Fach find an album! Fach Off-Topic 6 08-27-2004 11:14 AM
Ugh, my stomach is killing me... little help? rogue Off-Topic 9 12-24-2003 10:42 AM
