Old 09-28-2007, 08:57 PM   #1
moss
Member#: 10197
Default Coolant temp gauge on cluster not working - JDM STi V7 Swap
Ok, let's see if anyone can figure this out.
On my V7 Swap, my coolant gauge on the cluster is not working at all, It doesn't read at all. However, when I plug into my OBDII and use Enginuity (think Delta Dash) to check coolant temps, it reads out on the computer just fine. So, it doesn't seem like its a bad sensor.
Also, I know the cluster is NOT bad. I swapped my cluster with another cluster and the same scenario came about, the coolant gauge didn't work. So, that rules out the cluster.
Where could the wiring issue be?
moss is offline   Reply With Quote
Old 09-29-2007, 10:17 AM   #2
sidewayz
Member#: 5810
2001 S366 2.5RS
check the wiring coming OUT of the ecu to the cluster. I believe its a green with white stripe
sidewayz is offline   Reply With Quote
Old 09-29-2007, 10:25 AM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
yes its a second sensor white-green wire
but depending on the car may come directly from the sensor
Old 09-29-2007, 10:49 AM   #4
moss
Member#: 10197
01 2.5RS with V7 swap....
Old 09-29-2007, 01:58 PM   #5
sidewayz
Member#: 5810
2001 S366 2.5RS
Moss, most likely when your swap was done, that wire coming out of the ecu was overlooked. Just trace it from the ecu and see if its going to the ecu
Old 09-29-2007, 02:09 PM   #6
moss
Member#: 10197
you mean trace from ECU to cluster or vice versa?
anyone got a wiring diagram handy? 01 RS? I have the V7 one.
from the diagram, it looks like it comes directly from the sensor. One wire goes to the ECU(BY) and one to the cluster (WG)... so I guess that would be the reason why I can read temp from the OBDII port but not on the cluster... something is up with the WG wire?
Old 10-14-2007, 01:21 AM   #7
Deadchip
Member#: 102788
2000 V7 RSTi Coupe
I have a similar thing going on. The dash temperature is erratic, but my Ecutek delta dash (connected to the OBII) monitor reads out correctly. I read somewhere that there were different sensors for each system.
Deadchip is offline   Reply With Quote
Old 10-14-2007, 02:15 AM   #8
moss
Member#: 10197
I had a loose pin on my main harness connectors inside the engine bay. Wasn't connecting to the other end...thus no signal. easy fix.
Stock Coolant temp gauge in 04' STi cluster not working bugeyesubie Electrical & Lighting 3 05-19-2009 06:19 PM
Coolant temp gauge on the fritz?!?! Help nismo4life Normally Aspirated Powertrain 5 02-08-2008 03:08 AM
Temp gauge on cluster... is that oil or engine temp? gopsu Newbies & FAQs 1 10-02-2005 10:45 PM
JDM sti v7 swap times. Soon2Bgreat Proven Power Bragging 15 08-25-2003 03:44 PM
oem coolant temp gauge not working... czo79 Legacy Forum 0 08-01-2003 01:11 PM
