Old 09-29-2007, 12:31 PM   #1
sleeperrex
Member#: 19466
2002 wrx/hybrid
Default ECUExplorer?
This has been a pretty bad day. Nothing is going right.
Got a flashing CEL for the 1st time on my 100k 02 WRX. In the past i have been able to check the darn thing with my scanmaster or ECUExplorer.
Ever since i tried installing ECUExplorer on another laptop i have not been able to get it to work (was previously using my work computer which i don't have anymore). Enginuity does but from what i have read, i'm not sure i can read trouble codes with it. I can data log but it seems like most people use ecuexplorer to read/reset trouble codes
I've lost my username for openecu.org and they require it to reset your password. And for some reason they cannot reset my account with just my email. Tried opening a new email and there is no instant activation.
Help!!!!!!!!!
Finally got the right combination of drivers and ecuexplorer working. Dug through some folders and found older version of ecuexplorer and ftdi drivers. For some reason i can't get the drivers that come with enginuity to work.
Got missfires on cylinder 4.
sleeperrex is offline   Reply With Quote
Old 09-29-2007, 09:07 PM   #2
Freon
Member#: 88322
2009 BMW 135i
You should read codes with a real code reader. ECUexplorer is not a real OBD2 code reader and tends to not be 100% accurate.
Freon is offline   Reply With Quote
Old 09-29-2007, 09:43 PM   #3
nwindyz
Member#: 120644
2004 Faux STI
JBP, Cobb Staged
Flashing CEL light usually means Catalyst. Your dumping raw fuel down stream and burning up the Cat.
nwindyz is offline   Reply With Quote
Old 09-29-2007, 09:57 PM   #4
sleeperrex
Member#: 19466
2002 wrx/hybrid
Luckily don't need to worry about that.
Old 09-29-2007, 09:59 PM   #5
sleeperrex
Member#: 19466
2002 wrx/hybrid
It's the best i've got and in the past it has been pretty good in diagnosing issues . For the rough idle i'm seeing i'm guessing its right. Just need to pull the plugs and check it out. Little worried. Have had solid CEL's but have never had the flashing CEL.
Old 09-30-2007, 06:56 AM   #6
JMS77
Member#: 136833
R U looking for help on how to reset the codes? You could go to an Autozone and they pull/reset the codes for you for free.
Do you need help installing Enginuity? I recommend downloading the newest version, with the appropriate def. files. First, make sure you have no other copies of the software on your computer. If you could, reloading the OS would be great, but that is not a realistic option sometimes. Try and install the new 0.41b Enginuity... if it does not work, post what type of errors you are getting so we can help you out better.
This may be old news for you, but at least it gives us a good starting point.
JMS77 is offline   Reply With Quote
ECUExplorer Datalogger 3.0.25 released today for 2006 WRX.. riggs Engine Management & Tuning 22 02-17-2006 08:00 PM
ECU addressfor ECUExplorer mars636 Engine Management & Tuning 12 02-08-2006 10:01 AM
Realtime display in Tari DL1/ecuexplorer?? michaelpatrick Engine Management & Tuning 5 02-03-2006 12:51 AM
ECUExplorer Datalogging on the 06 WRX? riggs Engine Management & Tuning 7 01-27-2006 08:43 PM
ecuExplorer Engine Load address for 2002 USDM WRX? IndyRacer Engine Management & Tuning 23 12-15-2005 11:54 PM
