Old 10-09-2007, 04:29 AM   #1
orangerexi
Member#: 105327
1999 my99 wrx
orange
Default GC8 my99 wrx, 300kw/400hp out of a 2.0
Engine was built buy perfourmance motorsport
all tuning is dun by mathew spry
factory closed decked 2.0 block with standard crank
cp pistons 92.5mm
eagle rods with 3/8ths arp 2000 rod bolts
ported and polished my99 heads , standard valves
PMS grind 280 billit cams
HD valve springs
sti head gaskits
acl race bearings
jun adjusterble cam gears
sard 850cc injectors
areomotive fuel reg and speed flow fittings and adapters
custom catch can with speed flow fittings
surge tank
twin bosch 044 pumps
gt3040r turbo with .63 rear
tial 38mm gate
custom 3.5inch dump into 3inch exhaust
stock inlet manifold
ported stock throttle body to suit xf throttle body butterfly 65mm
PWR core 600x300x75 with custom end tanks, 3 inch piping from turbo to throttle body
greaddy type r bov
gtspec headers and custom up pipe
stock ignition, with custom 9mm leads
microtech lt8
greaddy profect b spec 2 boost controller
gear box
version 5&6 sti ra box with 3.9 final drive
ppg 1st -4th syncro set with standard wrx ratios
04 sti clutch kit
suspension and brakes
apexi World sport coil overs
front and rear strut braces
whiteline 22mm front swaybar
whiteline 24mm rear sway bar
whiteline heavy dutey links front and back
nolthane bushes in the rear
nolthane steering rack bushes
dba4000 slotted rotors front
****ty bendix pads
02-04sti wrx rims
250kw atw in 4 gear on 21 psi
274kw on 23psi
301w atw on 25-26psi on 98 pump juice
old rims
new rims
250kw with stock exhaust manifold on 25psi
291kw with gtspec 4 into 1 headers and 25psi, on this tune the fuel pump was maxed out
final tune with 2 bosch 044 pumps
orangerexi is offline   Reply With Quote
Old 10-09-2007, 04:51 AM   #2
EBWRC#1
Member#: 86843
Io Sono
a 500 Driver !
Do you have pictures?
EBWRC#1 is offline   Reply With Quote
Old 10-09-2007, 05:19 AM   #3
orangerexi
Member#: 105327
1999 my99 wrx
orange
i do, but becuase im new to the forum it wont let me as of yet, why is this
Old 10-09-2007, 06:11 AM   #4
orangerexi
Member#: 105327
1999 my99 wrx
orange
i do but coz im new to the forum it wont let me post any yet
Old 10-09-2007, 09:31 AM   #5
WRX4eva
Member#: 103343
2004 2.5 Hybrid 6spd
Rotated Manifold/35R
probably because you have less than 10 posts. (That is if you want to attach a picture)
You can use photobucket. Upload your pictures there and write the code here. I did a kind of diy on how to post pictures. Let me find it for you.
WRX4eva is offline   Reply With Quote
Old 10-09-2007, 10:40 AM   #6
dmross
Member#: 2818
2000 2.5RS
For the lazy kids:
250kW = 335hp
274kW = 367hp
301kW = 404hp
dmross is offline   Reply With Quote
Old 10-09-2007, 04:21 PM   #7
Sko
Member#: 90396
2005 Legacy 2.5i
Brilliant Silver Metallic
Hope we can see a dyno sheet pretty soon, ^_^
Sko is offline   Reply With Quote
Old 10-09-2007, 04:48 PM   #8
orangerexi
Member#: 105327
1999 my99 wrx
orange
ive been using photobucket but the forum wont let me post any pics as of yet, i also have a before and after of wen i put on 4 into1 gtspec headers, where i picked up 50kw gain at the same boost and also got quicker spool
Old 10-09-2007, 05:49 PM   #9
jason.g
Member#: 88467
2005 WRX
All black everything.
"For the lazy kids:
250kW = 335hp
274kW = 367hp
301kW = 404hp"
flywheel hp?
jason.g is offline   Reply With Quote
Old 10-10-2007, 12:45 AM   #10
rxw
Member#: 43669
2006 STi
wheel hp
rxw is offline   Reply With Quote
Old 10-10-2007, 12:49 AM   #11
MJU1983
Member#: 14364
2003 WRX, '06 Armada
05 Vette & 05 STi (sold)
Wow, and I love how solid the boost is.
MJU1983 is offline   Reply With Quote
Old 10-10-2007, 01:08 AM   #12
BlockerImp
Member#: 66480
2001 Wrx wagon
What kind of lip is that?? looks kinda cool, but makes a fake looking brake duct
BlockerImp is offline   Reply With Quote
Old 10-10-2007, 01:51 AM   #13
orangerexi
Member#: 105327
1999 my99 wrx
orange
thanks champ for doing that for me, all 400hp is at the wheels and if your after that solid boost to redline then u cant beat an external wate gate for boost controll, the front bar i had made from a local body kit shop where i live , the vent in the side it realy just for show
Old 10-10-2007, 01:52 AM   #14
orangerexi
Member#: 105327
1999 my99 wrx
orange
thanks champ for doing that for me, all 400hp is at the wheels and if your after that solid boost to redline then u cant beat an external wate gate for boost controll, the front bar i had made from a local body kit shop where i live , the vent in the side it realy just for show , nd u would be on the money for a stock sti on this dyno for that power 200hp
Old 10-10-2007, 02:51 AM   #15
DMP RUN
Member#: 149494
Nice car & power.
I'm from Australia too and I think I saw this car on the Gold Coast around new years a couple years ago. Do you know the guy in "30 PND"?
DMP RUN is offline   Reply With Quote
Old 10-10-2007, 05:12 AM   #16
orangerexi
Member#: 105327
1999 my99 wrx
orange
Originally Posted by DMP RUN View Post
Nice car & power.
thanks dude yeah im from the goldcoast, yeah i no him hes a good mate of mine
Old 10-10-2007, 08:08 AM   #17
DMP RUN
Member#: 149494
Yeah he's a mate of a mate, we were with him and he pointed your car out.
Nice car anyway dude, good work for sticking with the 2L.
Old 10-10-2007, 09:01 AM   #18
orangerexi
Member#: 105327
1999 my99 wrx
orange
thanks dude, i stuck with the 2.0l coz no one had realy built a decent 2.0l with decent power and i love how the engine revs but with mine ive moved the cams so it brings the power in early so its alot nicer to drive but u sacrifice alot of top end power, whitch i dont no if its a good thing maybe i should just let it rev but in the end i want the engine to last so maybe a good thing its making power to 7 grand at the moment
Old 10-11-2007, 12:08 AM   #19
jason.g
Member#: 88467
2005 WRX
nice setup & thanks for clarifying the whp#'s. any dragstrip runs?
i didn't see one subie my whole aussie trip (Jan 06) - so disappointing. I was on the gold coast too.
Old 10-11-2007, 04:30 AM   #20
orangerexi
Member#: 105327
1999 my99 wrx
orange
are u serious there are thousands here on the goldcoast , did u have your eyes open lol there is like very model here as we get all of them
Old 10-11-2007, 02:36 PM   #21
jason.g
Member#: 88467
2005 WRX
yep...saw tons of zenki's, kouki's, and skylines. holden's too. I was on tour w/ my group so i was very busy but i definitely had my eyes open LOL.
Old 10-11-2007, 03:04 PM   #22
Jaylyons1
Member#: 113884
1989 Skyline GT-R
nice, have you tracked it yet? Im puttin down about 30hp less then what your gettin, best run so far is 12.1 @ 114. That was while leaking boost though, was running 25 psi on the stocker, didnt like it so much. I'm going to try again once I get down to the states with no boost leak and see how I do!
Jaylyons1 is offline   Reply With Quote
Old 10-12-2007, 02:56 AM   #23
outlwstr
Member#: 102201
man that car is sick!
outlwstr is offline   Reply With Quote
Old 10-12-2007, 03:07 AM   #24
orangerexi
Member#: 105327
1999 my99 wrx
orange
im planning on running very soon, but from what ive seen other people run in the same car with similar power 125-130mph is on the cards so low 11s maybe a high 10 but im more interested in wat mph i will run 130 would be nice
Yes you too can make fun of my 2.0L stock turbo jmlaser Proven Power Bragging 48 05-03-2008 10:23 PM
Limits of the 2.0L V3rdug0 Newbies & FAQs 14 08-19-2006 02:50 AM
Lack a fuel under acceleration out of a turn??? JonzFaSTi Warranty Issues & SOA Problems 7 12-23-2005 11:53 PM
What would I need to get 250hp out of a 2.2 Legacy Turbo? wrxlvr Legacy Forum 17 10-21-2004 03:33 PM
Best way to get power out of a 2.2?? legacyej22 Normally Aspirated Powertrain 44 11-21-2002 01:53 AM
