South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 09-29-2007, 06:10 PM   #1
Chiefin27
Member#: 158682
Default Having trouble installing HID's
pretty much ive been looking at it for the last 2 hours and am still at step one. Ive searched around, but havent really found anything to really help me. If anyone could run me through the procedure, ill buy you some beers.
Chiefin27 is offline   Reply With Quote
Old 09-29-2007, 06:38 PM   #2
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
hmmm.
model year of car and type of hid kit would def help out anyone attempting to help.
v8eaterWRX is offline   Reply With Quote
Old 09-29-2007, 06:49 PM   #3
Chiefin27
Member#: 158682
the car is a 2006 WRX TR...and the hid kit is the xantec i believe
Old 09-29-2007, 06:53 PM   #4
racingfish
Member#: 60976
1969 LGT
FATURBO
remember to disconnect your drl's
racingfish is offline   Reply With Quote
Old 09-29-2007, 07:56 PM   #5
06AZREX
Member#: 132244
2006 OBP WRX
2006 BMW 325i
kinda hard to explain on the here man. guess you could call me and i could walk you through it. check your pm
06AZREX is offline   Reply With Quote
Old 09-29-2007, 08:11 PM   #6
szeny
Member#: 81383
07 335i e90
TiAG/Dakota Black
usually the HID kit will have a 12v and a ground wire.. So you need to cut the low beam harness (or tap into it) and one of the wires will produce 12v when the lights are on.. you tap that into your hidkit 12v and ground the other wire to the fender. cap off the other wire in the harness you dont use
szeny is offline   Reply With Quote
Old 09-29-2007, 08:12 PM   #7
Hazmat
Member#: 94803
I would recommend you to mount the ballast underneath the headlights.
Go search the instructions on how to take it out using the from the darkenend headlight threads, and from then on strap on ballast in the open space and everything should become more clear.
Hazmat is offline   Reply With Quote
Anyone else have trouble installing Whiteline Rear Subframe Bolts? EarlQHan Brakes, Steering & Suspension 12 11-13-2008 01:19 AM
Having trouble installing STi corner bumper splitters TheBaumer Interior & Exterior Modification 19 04-19-2006 07:07 PM
I'm having trouble installing a Walbro fuel pump, need help. porque Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 01-14-2006 10:54 PM
having trouble installing up pipe I3oostedScooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 07-07-2005 09:16 AM
Anyone have directions installing WRX JDM lights with HID's in them? samwY Interior & Exterior Modification 2 01-08-2004 02:22 AM
