Old 09-29-2007, 07:57 PM   #1
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Default Wastegate Arm
Hey. I tried turning the WG arm today, and I turned it maybe 6 full turns, and it now will boost 15-15.5psi now. Also, in 5th, when it spools it'll hit around 15, then drop off real quick down to like 12-13psi. Is this normal?
I'm afraid to crank it anymore in fear of breaking something.
Forgot to mention I've got a Stage 2 ECU reflash It's tuned to 18psi. Target boost is 17.2psi.
Superorb is offline   Reply With Quote
Old 09-30-2007, 09:19 AM   #2
quazimoto
Member#: 70395
What/who's map exactly are you running?It's normal for the boost to taper down towards redline around 5500-6K.Is there still threads left on the wastegate arm?Just trying to see how far you have adjusted it.
quazimoto is offline   Reply With Quote
Old 09-30-2007, 05:22 PM   #3
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
The free XPT map. There were a few threads left on the arm, but I put it back to stock now though.
How do I detect a boost leak while the car is standing still? I hear a whistle at around 10psi and goes away at 12psi.
Old 10-04-2007, 12:21 PM   #4
Not-EWRX
Member#: 158043
2013 Wrx Hatch
There are no free XPT maps. There are stage two base maps.
Not-EWRX is offline   Reply With Quote
Old 10-04-2007, 11:19 PM   #5
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
I know the XPT are all paid, I just couldn't think of the name of the free ones, mostly b/c there isn't really a name
Old 10-12-2007, 07:30 PM   #6
mixmastermatt
Member#: 137506
Make a boost leak detector and pressurize the system with an air compressor.
mixmastermatt is offline   Reply With Quote
Old 10-12-2007, 07:33 PM   #7
Noeladams
Member#: 121517
2003 Subaru WRX
World Rally Blue
also do some data logging before you go flooring it to make sure you aren't causing more problems!!!!!!!!!!
Noeladams is offline   Reply With Quote
Old 10-12-2007, 07:58 PM   #8
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
I don't have a compressor.
Old 10-12-2007, 10:40 PM   #9
Broxma
Member#: 158006
2003 WRX IdleWagon
1992 GVR4 379/1000
You can do it with a bicycle pump if you are creative.
I found the stage 2 base map from XPT the boost did fall off alot at high RPM and tended to wander a bit.
I should be wrapping up the first version of my 93 octane map this weekend. I don't know if I am going to post it for open DL, but I may email to certain folks if they want something to compare or test with.
/Brox
Broxma is offline   Reply With Quote
Old 10-13-2007, 08:50 AM   #10
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
What's the difference in your map vs the XPT map?
Old 10-13-2007, 01:28 PM   #11
Nuke209
Member#: 108089
2003 WRX
NF Performance
well, your boost will taper down no matter what, especially with that snail, the td04 lol, u won't be able to hold much boost with that thing.
the gmboost version is much better, helps to hold a bit more than the stock
Nuke209 is offline   Reply With Quote
Old 10-13-2007, 01:49 PM   #12
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
I actually just finished the plug/play wiring for the GM and stock wiring earlier. I'm ordering some tmic gaskets to help find the boost leak before I really up the boost to target 17psi.
Quick question: Wastegate arm C clip size Ceyvme Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-04-2006 04:56 PM
Having Trouble with Wastegate arm. Sevaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 10-17-2005 08:53 PM
Wastegate Arm Need BB Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-02-2005 10:19 PM
How can you adjust the wastegate arm? waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-19-2004 02:36 AM
Anyone's wastegate arm ever pop off? peterex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-26-2004 01:54 AM
