Old 09-30-2007, 02:03 AM   #1
The_Prodigy
Member#: 116467
2004 STi
Default BlackStone oil report with M1 5W-30 (MY04STi)
Just wanted to share my oil report to everyone who have concern about using Mobile 1 5W-30 motor oil on STi's.
The sample was pulled from 3k miles of Boston's summer 50 stop n' go, 50 HW usage. I usually start up the engine and let it idle at least a minute before I take off. Shift below 3k rpm before it fully warmed up. I barely redline the engine, probably no more than 3 times, I mostly shift at 6k rpm when I'm in the mind.
Anyway, here it is........
The_Prodigy is offline   Reply With Quote
Old 09-30-2007, 02:14 AM   #2
The_Prodigy
Member#: 116467
2004 STi
for some reason I couldnt resize this pic. For those of you who cant see it clearly, just d/l the pic and zoom in.
Old 09-30-2007, 02:16 AM   #3
kingtut12
Member#: 81123
2002 2.5 WRX BY
RIP 02' 2.5WRX PSM
Does the last line in the evaluation say "your Saturn is doing just fine" ? Lol..
kingtut12 is offline   Reply With Quote
Old 09-30-2007, 02:16 AM   #4
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
The oil report is not the problem people have with M1 5W-30, my reports also showed just as clean after 5000+ miles. Some have had problems with the oil being too thin and spinning rod bearings, this isn't a huge widespread issue though.
Old 09-30-2007, 02:18 AM   #5
NorCal06STi
Member#: 115553
2006 STi
Blue/gold
What the **** did you buy an STi for if you dont mind me asking?
NorCal06STi is offline   Reply With Quote
Old 09-30-2007, 02:20 AM   #6
04 Slo Sti
Member#: 156478
06 330i
i drive an STi and i don't really go past 6 ethier and some days the car never see's boost...
i'm 21 too...people can't believe it...haha
i just like my stuff to last
btw i bought an STi cause its the car i've always wanted....i don't care if it had 100hp...
04 Slo Sti is offline   Reply With Quote
Old 09-30-2007, 02:23 AM   #7
Master2192
Member#: 83254
98 2.5 RS
04 WRX
I redline my car every single day....
and it has 187,000 miles on it!
The only problem with it now is the valve seals are starting to leak a little bit, which is to be expected at that many miles.
Old 09-30-2007, 02:25 AM   #8
The_Prodigy
Member#: 116467
2004 STi
Yep, that's a missprint
If the oil is in fact too thin for the engine and there's some wear on the rod bearings, it should show on the report on either LEAD, TIN or COPPER. Isnt it?
Old 09-30-2007, 02:26 AM   #9
medrad_man
Member#: 142673
2006 STI
I've created a monster
im 21 too, i bought it b/c im gonna mod the MF'in daylights out of it and probaly end up crashing in some auto X tryin to take a turn at 120mph, lol. Gotta love it.
that oil report is good news cause i just switched to M1 thanks for the info.
medrad_man is offline   Reply With Quote
Old 09-30-2007, 02:33 AM   #10
The_Prodigy
Member#: 116467
2004 STi
Simply because I think going fast on a straight line isnt too much fun for me. I pick up the speed I need and going twice or sometimes triple the speed limit in a corner, that's where I'm having fun with and the reason why I buy the STi for.
Old 09-30-2007, 02:38 AM   #11
medrad_man
Member#: 142673
2006 STI
good reason
Old 09-30-2007, 03:33 AM   #12
Master2192
Member#: 83254
98 2.5 RS
04 WRX
If the bearings were going bad yes, but this too thin thing happens once and your engine starts making a knocking sound from the spun bearing. I am not sure all of the variables that cause it, my guess would be excessive lugging at low rpm with this oil. Not too many drivers run their cars like that which could be why not everyone is spinning bearings on Mobile 1.
Old 09-30-2007, 02:21 PM   #13
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
this thread is one of those that make those of us that have been around for a while just go
Old 09-30-2007, 02:53 PM   #14
italy wrx
Member#: 36450
2003 WRX
Agreed.. Sometimes people have to learn from experience. Personally, I'd never use Mobil 1 in any weight.
italy wrx is offline   Reply With Quote
Old 10-01-2007, 12:29 AM   #15
RuskeR
Member#: 5824
2005 STi Aspen White
1990 240sx "SR20"
looks good.. I'm still awaiting for my test kit to arrive.
RuskeR is offline   Reply With Quote
Old 10-01-2007, 12:37 AM   #16
The_Prodigy
Member#: 116467
2004 STi
What makes you avoid using Mobile1 motor oils? Sure I've seen some bad stories about spun bearing but are they directly related to the mobile 1 oil? Prove it, educate me.
Old 10-01-2007, 12:39 AM   #17
The_Prodigy
Member#: 116467
2004 STi
And Uncle Scotty, you are telling me that the Blackstone oil analyze doesn't mean jack???
Again, please educate me.
Old 10-01-2007, 12:40 AM   #18
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
(the following is not factual info, just an example to make a point...)
90% of people with spun bearings have mobil 1 in their engines at the time.
90% of people use mobil 1 in general.
hmmmmm. i've heard the stories, but i'm just saying... gotta look at things in perspective.
TROLL is offline   Reply With Quote
Old 10-01-2007, 12:49 AM   #19
04 Slo Sti
Member#: 156478
06 330i
90% of people clearly beat the **** out of there vehicles...
i dont think they make an oil to cure that problem..only slow the process
so how is mobile 1 singled out..
b/c 90% of people use it?
Old 10-01-2007, 02:50 AM   #20
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
it's not about beating the crap out of one's car. The stuff really is thin for its rated viscosity. I would be extremely careful using the stuff.
jigga is offline   Reply With Quote
Old 10-01-2007, 03:06 AM   #21
joe-6STi
Member#: 141590
2010 Silverado
2007 CRF250R
your car is so much more capable than you realise bone stock ! tighten the nut behind the wheel before dumping that cash on it if autoX is really what you want to do... that means learn to drive. just my advice.
Oh and BTW - you'll never see 120 on an autocross course - but you will meet the rev limiter in 2nd
joe-6STi is offline   Reply With Quote
Old 10-01-2007, 09:08 AM   #22
Uncle Scotty
Member#: 16200
OK buy Nates beans
....d0000000000000000000d......just like everything else....people---the VAST MAJORITY OF THEM.... just do NOT want to read anything or learn anything about anything....and they don't do their homework and so they listen to wives tales and the "...i heard....' jizz and all that garbage
hence....these idiots think they HAVE to use 5w30 oil----NOT
and they think M1 great---some IS---some NOT....if ya know which is which, ya get the good jizz, if ya don't, ya get the WRONG jizz.
and engines...Subaru engines, anyway......are NOT 'broken in' at 1k mikes....or 2k...or 3k.....but I could go on all day here exposing just a portion of the cement between the ears of the majority of the board members.....alas, I have given up on trying to do too much here as I get points for being properly contrary to the mindset of the masses----the lemming masses....
have fun blowing them up, boiz....I sure have over the years---but I stopped doing that as I learned what you boiz are beating yourselves up with
Old 10-01-2007, 10:16 AM   #23
bluesubie
Member#: 767
04 FXT
An excellent oil report! For a Saturn! I think there was a mix-up at the lab!
Seriously, the report looks very good although wouldn't run this much past 3,000 miles. The viscosity converts to 9.6 cst's and the minimum to be considered a 30 weight is 9.3 cst's. I wouldn't bother with synthetic if I changed my oil every 3k.
You can tell that your driving style is conservative (or the report is from a Saturn).
-Dennis
Old 10-01-2007, 11:51 AM   #24
WRXSTi0487
Member#: 112167
2004 WRX STi
Main problem I presonally have seen with the M1 when I was using it was my oil consumption was very high (1qt every 1k miles) then I switched to GC 0W-30 and the consumption went to about half a quart every 3k. I don't like having to add a quart of oil every 1k miles so I stick with other brands that don't give me that problem.
That is all I have...
WRXSTi0487 is offline   Reply With Quote
Old 10-01-2007, 03:12 PM   #25
04 Slo Sti
Member#: 156478
06 330i
i know i know this..but what is GC?
Any experience with Neo 5W-30? recommended transmission oil? eraser535 Service & Maintenance 9 10-21-2009 10:44 PM
Used oil analysis: Mobil 1 5w-30 on 2004 STi with 67k miles Bullhonkie Service & Maintenance 4 08-28-2009 11:29 PM
My oil analysis - '05 RS, 5W-30 Pennz. Platinum ScottyB Normally Aspirated Powertrain 16 12-19-2008 09:25 AM
Used Oil Analysis: M1 5W-30 in '04 WRX (possible fuel to the debate) Asinine Service & Maintenance 25 10-15-2008 10:50 PM
Used Oil Analysis - Pennzoil Platinum 5W-30 - 2005 Subaru WRX STi AndyH Service & Maintenance 16 03-10-2008 10:30 PM
