Welcome to the North American Subaru Impreza Owners Club Sunday April 19, 2015
Old 01-15-2002, 02:20 PM   #1
wrx182
Member#: 9531
2002 WRX Sport Wagon
Default oil change - put it up on ramps or no?
just like the subject says.
thanks.
wrx182 is offline   Reply With Quote
Old 01-15-2002, 02:28 PM   #2
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
I can easily change oil without lifting the car. The filter is close to the bumper, and drain bolt is not too far away either.
tmat3 is offline   Reply With Quote
Old 01-15-2002, 02:32 PM   #3
hotrod
Member#: 14141
2002 Impreza WRX
Default on the ground works for me
You can change oil in the drive way just fine as long as you have a couple things.
You need a low profile pan to drain it in.
You will probably need a suitable oil filter wrench because you won't have much leverage if the car is not raised up.
By the way, the stock subaru oil filter has an anti-drain back valve, and it _will_ have quite a bit of oil run out when you first break the oil filter free. Expect to get someoil on your hand and arm from the filter.
Just did it in the driveway yesterday, so fresh memories !!
See - Ya
Larry
hotrod is offline   Reply With Quote
Old 01-15-2002, 03:36 PM   #4
TheWRX
Member#: 10279
2005 Lotus Elise
Yellow, #94 SS
Default jack up
I put it on jack stands. My drain pan is quite large, and it would get really tight without raising the car. Jacking up the car doesn't take very long, and it gives me plenty of room to conveniently access everything. If you have ramps, that would be even quicker.
TheWRX is offline   Reply With Quote
Old 01-15-2002, 03:52 PM   #5
topcover
Member#: 8999
2002 EJ25 FXT Wagon
Platinum Silver, Stage2
My car was lowered about an inch and I can still get underneath. Do yourself a big favor and buy yourself a Fumotovalve. It makes changing your oil a breeze and drip free (except your filter).
The lo-profile oil catch is a good idea.
Buy it online direct HERE!
topcover is offline   Reply With Quote
Old 01-15-2002, 03:53 PM   #6
kensington
Member#: 9113
2k4 WRB STi
RIP#92 Fred"G-Money"Zippy
I use ramps, probably don't need to but I think it makes it easier. And I'm all about easy. If you don't have one order a Fumato valve, sooooooo much easier and less mess. Have fun.
Arnold
kensington is offline   Reply With Quote
Old 01-15-2002, 05:31 PM   #7
wrx182
Member#: 9531
i would order a fumoto valve - only problem being is that it won't fit because of my skidplate
Old 01-16-2002, 03:00 PM   #8
Whit
Member#: 11548
'02 OBS
I don't have ramps, I just drive one wheel onto a piece of wood or the yellow pages
Whit is offline   Reply With Quote
Old 01-16-2002, 04:37 PM   #9
Coati
Member#: 9106
2015 FXT - DGM
2008 STI - Aspen White
What skidplate do you have?
Coati is online now   Reply With Quote
Old 01-17-2002, 09:43 AM   #10
wrx182
Member#: 9531
Primitive
Old 01-17-2002, 10:05 AM   #11
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
I just don't trust those Fumoto valves, what if the spring fails?
What's the big deal with having to undo a bolt once every few months?
Glenn
ANZAC_1915 is offline   Reply With Quote
Old 01-17-2002, 10:35 AM   #12
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
Not a single failure has been reported yet. I don't see how the spring could fail. If the spring does fail, it's no biggie since the valve will still be closed. You will still need to turn the lever 90 in order to open the valve.
Richard
Richard L. is offline   Reply With Quote
Old 01-17-2002, 11:45 AM   #13
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
The Fumoto valve is fairly stiff even when you've lifted the lever against the spring - so it won't move by itself. If installed in the correct position, even hitting something won't open it.
It's a very well designed item. I was impressed when I got mine. Whether it's worth $20 to not have to use a wrench, remove and replace the crush washer and so forth is another story.
Alan is offline   Reply With Quote
Old 01-17-2002, 12:05 PM   #14
SubEd
Member#: 717
Another vote for Fumoto valve and ramps. The ramps give you a little more "breathing room" when you crawl underneath!
SubEd is offline   Reply With Quote
Old 01-17-2002, 12:40 PM   #15
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
I was very skeptical about the Fumoto drain valve at first, but after using mine for the past five months, I don't think I will ever go back to the stock drain bolt and crush washer again. The spring in the valve is there to exert pressure on the lever. The valve is not held closed by spring pressure. If the spring or the lever happens to break (very unlikely), the valve will still be closed and no oil will drain out.
Here is the FAQ on the Fumoto valve: http://www.fumotovalve.com/about.cfm
Here are some interesting excerpts from the FAQ:
The Engine Oil Drain Valve has been tested and granted "Genuine Part" status by six major motor vehicle manufacturers in Japan. These approvals were not granted easily and gaining them was a testimony to the quality and durability of the Engine Oil Drain Valve.
Q. Does my Engine Oil Drain Valve protrude into the interior of the oil pan and prevent full drainage of my engine oil?
A. No. The threaded oil drain plug hole is always reinforced to accept the threaded bolt of the drain plug. Your Engine Oil Drain Valve will not extend past this threaded portion of the drain hole and will allow the oil to be properly drained.
I don't use ramps when changing my oil and oil filter.
Richard
Old 01-23-2002, 10:01 PM   #16
Bear
Member#: 10147
02 WRX Wagon
Since ramps take less than a minute to deploy I use them. With the Fumoto valve life is good, I don't see how the valve can open by accident.
Bear is offline   Reply With Quote
Old 01-24-2002, 02:32 PM   #17
vicster
Member#: 952
14 Audi R8
I've got a Fumoto valve, and I think it's a marvelous little thing. I don't use ramps when I change my oil, but I have noticed that it's a lot tighter underneath my WRX than it was underneath my MY01 RS (due to all the extra plumbing, no doubt).
vicster is offline   Reply With Quote
Old 01-24-2002, 04:08 PM   #18
jhonas
Member#: 9015
2002 Impreza 2.5RS
Platinum Silver Metallic
The oil can be changed just fine without using ramps. However, if you do use ramps, you can slide around and tinker with other things on the underside of your car as you change your oil.
jhonas is offline   Reply With Quote
Old 01-24-2002, 05:14 PM   #19
andywrx
Member#: 10355
2008 Honda Element
i changed the oil in the wrx for the first time (myself doing it, i
mean) a couple weeks ago, and i just jacked the car on both
sides, not even enough to get the wheels off the ground.
i found that you can slide under the car pretty easy, but it sure
helps if you've got a little extra room...
andywrx is offline   Reply With Quote
Old 01-27-2002, 03:49 AM   #20
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
To avoid oil on your arm when changing the filter poke a hole in the bottom of it with a screwdriver. Let it all drain out that way, then just unscrew it. Much less messy. I had a fumoto valve on my montero and went through all kinds of offroad situations. Never had any problem with it. Although, it does drain VERY slowly.
Drac9 is offline   Reply With Quote
Old 01-27-2002, 04:06 AM   #21
Clegg
Member#: 7761
2008 VW R32 #3858
hehe I can just see me jabing around with a screw driver under my car:
<Ping> <Pong> Mis a few times <*cus words*> Try again < Donk> glance off... try it again <Dink - Thud - gush.....> glanced off again and Hit the radiator...
Clegg is offline   Reply With Quote
Old 01-31-2002, 02:01 PM   #22
savka
Member#: 12737
MY02 wagon 325/300
MBP
do I need a new crush washer to put in with the Fumoto valve?
thanks
savka is offline   Reply With Quote
Old 01-31-2002, 02:07 PM   #23
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
The Fumoto valve comes with its own washer, so you do not need to use a new crush washer with it.
Richard
Old 01-31-2002, 05:03 PM   #24
WRX34
Member#: 13364
1996 GM8 caged,
99 V8 RSTi, 11' FXT
I jack up one side and then put a stand under it in case it loses pressure for some reason. Plenty of room...BUT I've noticed that I've chipped a tiny bit of paint off after awhile. Oh well. Plenty of room and takes a few seconds....I was going to get ramps but I've seen some that would just take off the bottom of my bumper!!!
Ramps should be LONG(not too long), especially if it's lower than stock.
^ Finally another good use for the Yellow pages!
-JR
WRX34 is offline   Reply With Quote
Old 02-01-2002, 09:59 PM   #25
Jademonkey
Member#: 9213
2000 RS
Red
I slightly jack up the driver side of the car, just a few notches, because that allows all the oil to come out of the pan....
Jademonkey is offline   Reply With Quote
Too fast for love or I give it up on the first date Dizmal Off-Topic 139 12-09-2009 09:58 PM
Back up on ramps OK for changing tranny fluid? STI05 Service & Maintenance 12 08-18-2005 12:28 AM
STi oil change procedure question - Car's on the ramps now! fastwrx Service & Maintenance 9 08-09-2004 06:03 PM
Gear oil change. Put in 3.7 qt. Why is my dipstick reading high? thrdeye Transmission (AT/MT) & Driveline 9 03-14-2004 10:13 PM
Oil Change Question/Mix-Up xfactor834 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 07-18-2002 05:18 PM
