Old 01-15-2002, 02:33 PM   #1
zsurfrin
Member#: 11034
Platinum Silver
Default Camshaft Position Sensor
This has happened to me 2 times thus far. The other day i was with my dad and was his first time riding in my car. He wanted me to punch it, and i did. When i got too about 6300 rpm my cel light came on. Then after a few minutes it went off. The next day it did the same thing. Anyway i took it to the dealer to have the gusset replaced and asked him too run it for a code. PO340, camshaft position sensor, asked him what could cause this and he said the engine rpm was too high. I told him he was crazy and that my car had never seen 7000rpm, which is the redline, and i said to him that even if i did red line it that the cel should not come on. Last time i changed the oil, i put a little too much oil in where it was just above the line on the dipstick. Nothing major! I thought that when i revved it high the oil pressure was getting too high, causing the cel. Could the oil being a bit over cause this code? Is it just the sensor? Someone with knowledge in this area please help.
zsurfrin is offline   Reply With Quote
Old 01-15-2002, 02:57 PM   #2
Tuning Factory Inc.
Vendor
Member#: 3600
Some people havbe reported this code at random, myself included. Folks have mentioned that unplugging the sensor and replugging it in seemed to help.
Tuning Factory Inc. is offline   Reply With Quote
Old 01-15-2002, 04:56 PM   #3
tdman77
Member#: 9832
2004 STI
I have only gotten this code once, when I banged the rev limiter. But there have been other times that I have hit the limiter with out the CEL. Are you running underdrive pullies? This has been known to cause this CEL.
tdman77 is offline   Reply With Quote
Old 01-15-2002, 05:56 PM   #4
Jon [in CT]
Member#: 2992
02 WRX Sedan
If you scan the WRX CEL log thread (200+ posts at http://www.i-club.com/forums/showthr...postid=1367000), you'll find a fistful of P0340 reports. This is one of the codes that usually gets your ECU re-flashed (see http://www.i-club.com/forums/showthr...hreadid=110622). You should not receive this code just because you bumped into the rev-limiter, and you certainly shouldn't see it at only 6300RPM. The person you talked to at your dealership is an idiot. Don't let him/her work on your car.
Jon [in CT] is offline   Reply With Quote
Old 01-15-2002, 08:36 PM   #5
Austin
Member#: 7089
2016 STi
Default Re: Camshaft Position Sensor
No.
Austin is offline   Reply With Quote
Old 01-15-2002, 10:41 PM   #6
tdman77
Member#: 9832
2004 STI
I have also gotten the emission code "gas cap off/fail", this is also another ECU flash code. I refuse to have the dealer reflash my ECU due to the negative feedbacks of some people here. I am not too worried about either codes since they were both one time accurances. I have put around 7K since the last code and have not had any problems.
Old 01-15-2002, 10:49 PM   #7
Jon [in CT]
Member#: 2992
02 WRX Sedan
tdman77, please cite the "negative feedbacks of some people here" to the re-flash. I'm not aware of ANY adverse reactions.
Old 01-16-2002, 10:00 PM   #8
zsurfrin
Member#: 11034
Platinum Silver
So all I need to do is have the ecu re-flashed. Will the dealer do this for me?
Camshaft Position Sensor Issue (Car won't start) Hola Service & Maintenance 2 02-06-2005 12:12 AM
Camshaft position sensor shaneswrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-14-2004 04:39 AM
Camshaft position sensor dead AntonioS Normally Aspirated with bolt-on Forced Induction Powertrain 3 01-16-2004 05:30 AM
Camshaft Position Sensor ehabs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-31-2003 03:06 PM
CEL code: 0340 / Camshaft position sensor BluJay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-06-2001 05:07 PM
