Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 09-30-2007, 02:57 PM   #1
PumpinIron
Member#: 156544
Default Using ZTerm on my Mac to tune with UTEC...
Ok so here is the deal. I don't really want to go out and buy a cheap laptop to tune my UTEC when I have a brand new MacBook Pro here. Anyhow I bought a Keyspan USB to serial adapter which I know works for sure and I downloaded ZTerm which can be found here http://homepage.mac.com/dalverson/zterm/
Anyhow the only thing I am confused on right now is how I can do the text capture and text upload for the map and logging on the UTEC. I can't figure out a way to do that with ZTerm but it's easy on HyperTerminal but that is obviously only for Windows.
PumpinIron is offline   Reply With Quote
Old 10-11-2007, 05:03 PM   #2
Sko
Member#: 90396
2005 Legacy 2.5i
Brilliant Silver Metallic
I'd sugjest using bootcamp and installing XP or Vista, then run Parallels or VMFusion while in OS X to run your Windows stuff. I'm currently running Vista on my Macbook without problems, I mean I've ran into a few issues but a simple search and I've been able to fix everything.
Sko is offline   Reply With Quote
Old 10-21-2007, 02:37 PM   #3
Houdini
Member#: 51379
Sedona Red
I wound not suggest that at all - Windows is not needed. Serial IO is trivial - install minicom - its free, open source, and will meet all your needs for the UTEC.
http://turin.nss.udel.edu/archive/minicom-2.2.pkg.zip
If you have any questions or need help let me know.
Houdini is offline   Reply With Quote
What version of Windowz should I get to run on my Mac? Capt Crunch Off-Topic 24 01-19-2008 06:58 PM
Gaming on my Mac - Now you're playing with power GodWhomIsMike Off-Topic 10 09-13-2007 12:36 PM
update on my 2.5l swap with break in tune sonic rx Built Motor Discussion 8 04-27-2006 11:29 PM
Finally got my car tuned with Utec SonicYelloWRX New England Impreza Club Forum -- NESIC 3 06-12-2004 10:32 PM
Can i use my current ecu tune with a new turbo Turbo Tin Can Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 08-08-2002 10:20 PM
