Old 09-30-2007, 07:35 PM   #1
HoRk HuNtEr
Member#: 158064
2006 IMPREZA SEDAN
GRAY
Talking Please Help Guys - Trying to find wheel/tire size for Egyptian Impreza
HEY YO GUYS
PLEASE I WANT TO ASK U
what's the maximum tyre size that can be installed on a 17' rims in for an IMPREZA R ?
REALLY I DONT HAVE R
BUT I HAVE TS
1.6L
U KNOW THE TAXS IN EGYPT
AND I WANT TO ADD
17 INC RIMS
ALSO IDK
WHAT TYRE SIZE SHOULD I USE !!
HoRk HuNtEr is offline   Reply With Quote
Old 09-30-2007, 08:00 PM   #2
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
you will have to tell us the rim WIDTH and OFFSET
and also whether an Egyptian TS a wagon or sedan and what year / chassis code
...and fyi 17' = 17 FEET... " = inches
...... and quit with the fonts and justification and funnies - it's plain ANNOYING
UkNuck is offline   Reply With Quote
Old 09-30-2007, 08:28 PM   #3
HoRk HuNtEr
Member#: 158064
2006 IMPREZA SEDAN
GRAY
I WILL TRY TO ANSWER U UkNuck
my stock rims is 14 inc tyre 195/60
the car 2006 sedan
the chassis code i will try to find it on my lins but iam not at home now
at least soory if my fonts makes u annoying
Old 09-30-2007, 11:43 PM   #4
flyboymike
Member#: 83765
2005 WRX wagon
WR Blue
Do you mean in terms of overall outer diameter or section width? Trying to keep your outer diameter near stock is probably smart. A 195/60/14 is only 23.2 inches outside diameter. You can play with some sizing here:
http://www.miata.net/garage/tirecalc.html
As for section width, usually the widest you want on a 7 inch rim is 225, 7.5 inch takes a 235 max, and 245 on an 8 inch rim. If you're autocrossing and limited by maximum wheel width, you might be able to squeeze a little bit more on there.
I think the wheel/tire forum might have more information for you.
flyboymike is offline   Reply With Quote
Old 10-01-2007, 09:41 AM   #5
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
Hmm... 195/60R14? Like Mike says, that's a pretty short tire... I thought the Euro 1.6 got 185/70R14 which would be around 24.2in - I'm surprised RoW got a shorter tire for the base model.
To keep your speedo accurate with a 17" rim would only leave you (23.2 - 17)/2 = 3.1in of sidewall - do you really want that? How are the roads around you?
Maybe you should think about 16in instead e.g. 205/50/R16 at 24.1in total diameter will be close to 195/60R14.
Old 10-01-2007, 12:22 PM   #6
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
I edited your first post to remove all the colors and bolds and crap and edited your thread title so that it was meaningful.. Please, there are plenty of people here that will help you - you don't need to make your text huge to get help.
I'm moving your thread to Tire & Wheel.
Old 10-01-2007, 03:54 PM   #7
skydes
Member#: 141347
2005 WRX
Whoa I certainly would not stick 17'' wheels on a 1.6l Impreza
skydes is offline   Reply With Quote
Old 10-03-2007, 12:41 PM   #8
hadi10
Member#: 159208
2007 wrx 2007 Lmtd
grey
Originally Posted by HoRk HuNtEr View Post
HEY YO GUYS
BUT I HAVE TS
1.6L
AND I WANT TO ADD
17 INC RIMS
ALSO IDK
well first of all.. im from egypt too. impreza 1.6 TS comes with stock 15" rims and 195/60 r 15 .
and i have shifted to 17" rims , 205/45 r 17 which makes the car more stable than it is and looks way cooler .
and by the way , tyres in egypt is not that expensive at all. it depends on where do u search for tyres.
PM me if your need anything
hadi10 is offline   Reply With Quote
Old 10-03-2007, 07:50 PM   #9
skydes
Member#: 141347
2005 WRX
^^^By stable you mean "heavier" I bet.
Old 10-03-2007, 10:28 PM   #10
CVR STi
Member#: 127428
Masr !!!
CVR STi is offline   Reply With Quote
Old 10-04-2007, 10:19 AM   #11
hadi10
Member#: 159208
2007 wrx 2007 Lmtd
grey
heheh.. yes masr ... are you from masr?
Old 10-04-2007, 10:21 AM   #12
hadi10
Member#: 159208
2007 wrx 2007 Lmtd
grey
the 1.6 is already very heavy becaus of its small engine , i ment it handles much better with 17"
Please help! Been trying to diagnose misfire for 3 months now :( Zac86 Normally Aspirated Powertrain 3 03-28-2010 05:46 PM
need help asap! trying to find redline product Unrealgtx Southern California Impreza Club Forum -- SCIC 2 09-27-2008 05:06 PM
Trying to find a tire between the RT-615 and the P-zero M+S 02wrbrex Tire & Wheel 20 09-25-2007 01:06 AM
Correct Wheel/Tire Size for 99 Impreza jersey315 Tire & Wheel 10 02-13-2007 03:27 AM
Tire Size For My99 Impreza Wheels introspecive Newbies & FAQs 4 06-05-2006 04:51 PM
