Old 09-30-2007, 07:54 PM   #1
upjeeper
Member#: 150205
Sedona Red
Default Which carbide burrs for a port/polish job?
i'm going to stop by Airgas later this week and get some bits to do a port and polish of my tgv's and intake, maybe even my heads. Which shape of burrs do you guys recommend? there are trees, flames, cylinders, balls, etc...thanks
upjeeper is offline   Reply With Quote
Old 10-01-2007, 11:51 AM   #2
gumby647
Member#: 2532
2001 2.5RS-T
BRP
I tend to use mostly ovals and the cylinders with the rounded ends. You want to make sure to get the aluminum burrs because the steel ones will load up real fast. You'll also want some various sizes and grits of sandpaper cartridge rolls and some scotchbright x-buffs to finish it off.
gumby647 is offline   Reply With Quote
Old 10-01-2007, 12:15 PM   #3
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
ovals, acorns and small barrels are quite useful...balls can be too...unfamiliar with flames...?
don't forget your sanding barrels and flap wheel sanding bits.
Homemade WRX is online now   Reply With Quote
Old 10-01-2007, 12:53 PM   #4
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
for surface polishing, the 3M bristle discs work AMAZING...
I polished my entire intake manifold, & ported and then polished my TB with the bristle disc....as well as various other engine parts. good stuff.
I wish they made a similar product on a longer shaft for use in recessed polishing...
IllNastyImpreza is offline   Reply With Quote
Old 10-01-2007, 02:26 PM   #5
upjeeper
Member#: 150205
Sedona Red
i'm looking at getting some off the burrs that are 6 inches long for internal work to my TB and manifold. You guys didn't find you needed anything that long?
the flame shaped ones look like this
Old 10-01-2007, 02:56 PM   #6
gumby647
Member#: 2532
2001 2.5RS-T
BRP
You could use cratex points or wheels. I usually find that after sanding I can get my desired surface finish with the x-buffs. I do like to use cratex in the combustion chamber though since I feel it's easier to control and there's less chance of damaging a valve seat.
Old 10-01-2007, 03:15 PM   #7
veightkiller
Member#: 78967
2011 335i
i've been looking for one myself and i can't find one that long.
veightkiller is offline   Reply With Quote
Old 10-01-2007, 07:41 PM   #8
subaru5614
Member#: 159072
subaru5614 is offline   Reply With Quote
Old 10-02-2007, 10:41 AM   #9
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
where can I find that stuff ??
Old 10-02-2007, 10:56 AM   #10
gumby647
Member#: 2532
2001 2.5RS-T
BRP
I can usually find everything I need from McMaster Carr, Enco or MSC. Goodson and Silver Seal usually have more of the specialized engine stuff.
Oh yeah, If you are doing something small you can get Dremel cratex stuff at Lowes/Home Depot.
A good port and polish job is.... ? poormansporsche Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-25-2006 02:13 PM
which rim paint for a DIY goldie job? kaisersouse Interior & Exterior Modification 9 11-27-2005 09:02 PM
Looking for : Ported Polished VF34 and supporting mods 02scooby Private 'Wanted' Classifieds 0 07-23-2005 11:24 PM
Which Dremel to buy for EJ20 port/polishing, modding stock injectors, etc annointed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 07-15-2004 12:44 PM
port and polish job? legacy2003 New England Impreza Club Forum -- NESIC 8 01-03-2004 02:31 PM
