Old 09-30-2007, 11:54 PM   #1
Anhdalai
Member#: 146204
2000 Impreza 2.5RS
Silverthorne
Default Quick questions while the engine is out and i'm replacing the clutch/flywheel
Firstly, should you use locktite on the flywheel bolts? The next question is a bit noobish but.... the panel on the back of the flywheel, what is it's use? Can you remove this for some slight weight reduction? And the last one, are the torque specs on the flywheel bolts the same as the WRX? Thanks for any help !
Anhdalai is offline   Reply With Quote
Old 10-01-2007, 12:11 PM   #2
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
No, you don't use any locktite on the flywheel bolts. It gums up the threads and screws with the torque spec. Eight bolts at 54 ft. lbs. does the job just fine.
I don't know what your describing when you say "panel on the back of the flywheel". If you want to reduce weight you should get a light weight flywheel.
Tim Sanderson is offline   Reply With Quote
Head gaskets being replaced, what else to do while engine is out nardvark Service & Maintenance 9 04-15-2009 03:10 PM
well, the 3/20/08 tx mile list is out and I'm not seeing any names I recognize Big_Hitter Texas Impreza Club Forum -- TXIC 7 03-21-2008 10:14 AM
Ya'll are nerds, the internets is weird and i'm going to manage UR websites scaryfastskier Off-Topic 7 01-20-2007 09:10 PM
Headlight is out, and it's not the bulb! bitterWRX Electrical & Lighting 7 01-22-2005 08:30 PM
Well, the car is packed, and I'm ready to go! WagonMonster Off-Topic 89 04-12-2004 12:32 AM
