Old 10-01-2007, 01:11 AM   #1
VideoGameWrx
Member#: 68197
2005 OBP WRX
PPG + EJ257
Default Bad fuel pump? please help!
I don't want to jump to conclusions based on a log, but I can clearly tell is that it is unsafe for me to go WOT until this is figured out. I felt that the car was running lean and stumble on acceleration occassionally on WOT, but at other times it would pull hard....This is log from crappy acceleration and very dangerous AFRs
the 4th value is AFR
3rd gear
01:48:05.097,1.53,4.08,13.90,3437,17.50,16.01,88.2 4,100.00,47
01:48:05.275,1.70,5.69,14.24,3480,14.50,16.86,98.2 2,100.00,48
01:48:05.449,1.86,7.37,14.24,3488,14.00,17.82,108. 11,100.00,48
01:48:05.627,2.04,9.30,14.47,3580,14.00,19.70,123. 28,100.00,48
01:48:05.801,2.24,11.10,14.47,3698,14.00,22.15,134 .78,100.00,50
01:48:05.979,2.42,13.21,15.16,3740,14.00,30.77,148 .56,100.00,50
01:48:06.153,2.61,14.54,11.94,3801,13.00,35.11,169 .00,100.00,50
01:48:06.329,2.71,15.78,12.29,3941,13.00,35.68,172 .10,100.00,52
01:48:06.505,2.82,17.69,12.86,4017,13.00,36.99,179 .75,100.00,52
01:48:06.681,3.05,18.83,12.75,4065,13.00,42.85,209 .01,100.00,54
01:48:06.856,3.13,19.74,14.24,4157,13.00,44.23,218.98,100.00,54
01:48:07.032,3.18,20.19,14.36,4286,10.50,47.00,226.00,100.00,54
01:48:07.208,3.32,20.44,15.04,4240,10.50,48.45,239.96,100.00,57
01:48:07.384,3.31,20.59,16.19,4401,8.50,49.74,242.16,100.00,57
01:48:07.560,3.34,20.34,16.42,4481,8.50,49.76,251.42,100.00,57
01:48:07.736,3.33,20.11,17.34,4618,8.00,66.91,252.31,100.00,60
01:48:07.912,3.26,19.97,13.09,4688,9.50,65.02,248.33,100.00,60
01:48:08.088,3.21,19.86,12.06,4838,9.50,66.92,253. 24,100.00,64
01:48:08.264,3.16,19.61,11.60,4883,9.50,67.09,255. 05,100.00,64
01:48:08.444,3.16,19.39,11.25,5084,10.50,67.54,261 .52,100.00,64
01:48:08.616,3.18,19.01,11.25,5140,11.00,69.42,267 .08,100.00,68
01:48:08.792,3.13,18.93,11.37,5296,12.50,70.18,269 .45,100.00,68
01:48:08.970,3.12,18.56,11.25,5330,12.50,71.18,274 .74,100.00,68
01:48:09.145,3.07,18.33,11.25,5494,13.00,70.50,273 .30,100.00,71
01:48:09.321,3.04,18.23,11.25,5531,13.00,71.50,275 .22,100.00,71
01:48:09.496,3.01,18.29,11.25,5673,13.50,70.79,279 .13,100.00,75
01:48:09.673,3.04,18.27,11.25,5686,14.50,73.82,288 .41,100.00,75
01:48:09.848,3.01,18.37,11.25,5832,15.50,73.99,294 .54,100.00,75
01:48:10.041,2.98,18.37,11.25,5919,15.50,74.65,289 .94,100.00,79
01:48:10.216,2.97,18.20,11.37,5995,15.50,74.50,293 .01,100.00,79
01:48:10.393,2.93,18.08,11.25,6033,16.00,75.46,293 .77,100.00,79
01:48:10.568,2.89,18.06,11.25,6152,16.50,75.44,293 .77,100.00,83
01:48:10.746,2.86,17.83,11.25,6271,17.00,74.81,295 .31,100.00,83
01:48:10.920,2.78,17.91,11.25,6318,19.00,73.58,290 .71,100.00,86
01:48:11.096,2.75,18.16,11.37,6432,19.50,74.13,293 .01,100.00,86
01:48:11.272,2.75,18.10,11.25,6460,20.00,74.10,295 .31,100.00,86
01:48:11.448,2.71,18.25,11.37,6608,20.00,74.42,295 .31,100.00,89
01:48:11.624,2.68,18.22,11.37,6660,20.50,74.71,295 .31,100.00,89
01:48:11.800,2.63,3.56,11.25,6714,20.50,75.31,294. 54,100.00,89
01:48:11.976,0.87,8.16,11.25,7163,20.50,74.48,295. 31,0.00,92
However, earlier in the day here is a perfectly normal pull
4th gear
23:03:00.696,2.82,16.86,11.71,3671,13.00,50.37,176 .61,100.00,68
23:03:00.872,2.95,17.89,11.25,3689,13.00,54.25,186.57,100.00,68
23:03:01.048,3.03,18.85,11.25,3796,13.00,55.73,192.84,100.00,70
23:03:01.224,3.09,19.57,11.25,3822,13.00,57.52,196.89,100.00,70
23:03:01.400,3.12,20.07,11.25,3852,13.00,59.79,205.39,100.00,73
23:03:01.575,3.15,20.32,11.25,3947,13.00,61.21,208.95,100.00,73
23:03:01.752,3.16,20.30,11.25,3987,13.00,62.96,213.68,100.00,73
23:03:01.927,3.17,20.48,11.25,4043,13.00,64.76,215.66,100.00,75
23:03:02.103,3.20,20.59,11.25,4102,13.00,65.27,220.10,100.00,75
23:03:02.279,3.24,20.67,11.25,4136,13.00,67.00,225.16,100.00,75
23:03:02.455,3.24,20.75,11.25,4188,13.00,68.14,229.79,100.00,78
23:03:02.632,3.28,20.73,11.25,4259,13.00,68.88,234.43,100.00,78
23:03:02.807,3.27,20.63,11.25,4345,13.00,70.16,238.67,100.00,80
23:03:02.984,3.22,20.15,11.25,4328,13.00,70.21,234.00,100.00,80
23:03:03.159,3.16,19.49,11.25,4396,13.00,67.96,234.00,100.00,80
23:03:03.334,3.12,19.20,11.25,4475,13.00,68.51,233.58,100.00,83
23:03:03.516,3.10,19.01,11.25,4523,13.00,68.43,231.89,100.00,83
23:03:03.702,3.07,18.66,11.25,4559,13.00,68.06,236 .53,100.00,83
23:03:03.879,3.08,18.87,11.25,4624,13.00,69.73,238 .23,100.00,86
23:03:04.054,3.10,19.09,11.25,4670,13.50,69.60,241 .72,100.00,86
23:03:04.231,3.13,19.38,11.25,4738,13.50,72.68,247 .01,100.00,89
23:03:04.406,3.13,19.61,11.25,4798,13.50,72.91,248 .33,100.00,89
23:03:04.582,3.15,19.45,11.25,4820,14.00,73.43,256 .90,99.22,89
23:03:04.758,3.04,18.83,11.25,4848,15.00,72.20,247 .45,98.43,92
23:03:04.934,3.07,18.87,11.25,4873,15.00,74.32,255 .05,98.82,92
23:03:05.111,2.90,11.18,11.25,4977,15.50,71.86,253 .21,18.82,92
23:03:05.286,0.96,-7.35,11.25,4905,9.50,0.00,92.31,0.00,94
23:03:05.463,1.85,-9.11,12.75,4860,9.50,0.00,163.97,0.00,94
23:03:05.638,1.55,-9.73,13.67,4918,9.50,0.00,119.53,0.00,96
23:03:05.814,1.13,-10.06,25.27,4908,9.50,0.00,89.54,0.00,96
23:03:05.990,0.89,-10.38,25.27,4905,9.50,0.00,69.00,0.00,96
Any input would be appreciated....
my thoughts: change fuel filter, check fuel pump?
VideoGameWrx is offline   Reply With Quote
Old 10-01-2007, 01:19 AM   #2
VladiWrX
Member#: 145658
On my 4th scoob
and lovin it
holy batman!!!!!!!! WAY TOO MUCH NUMBERS
VladiWrX is offline   Reply With Quote
Old 10-01-2007, 01:30 AM   #3
VideoGameWrx
Member#: 68197
2005 OBP WRX
PPG + EJ257
lol sorry, 4th value is AFR, and 5th value is RPM, in the first pull I am running lean from 3-4.5k RPM, then in the second pull it is nice and rich the whole way through with the same boost levels and evrything else equal....what gives?
Old 10-01-2007, 01:23 PM   #4
benw
Member#: 103320
2005 wingless
aspen white
running some kind of injection?
benw is offline   Reply With Quote
Old 10-01-2007, 02:33 PM   #5
VideoGameWrx
Member#: 68197
2005 OBP WRX
PPG + EJ257
Yes water/meth it begins to spray at 10psi and continues to spray the same amount until I go below 10psi. I checked the filter on the nozzle a couple of weeks ago and it is clean.
Old 10-11-2007, 08:16 PM   #6
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
if you've got sufficient fuel in the tank, then you should pull the pump and inspect/clean the sock on the pickup. clean it with non chloro brake cleaner, and clean it really well. reinstall and report back.
i had similar issues a while back and the sock was pretty dirty... probably dirty gasoline. symptoms just like fuel starvation, but still plenty of fuel in the tank.
hth
ken
Old 10-17-2007, 06:22 PM   #7
VideoGameWrx
Member#: 68197
2005 OBP WRX
PPG + EJ257
thanks, it definately acts as if there is no fuel in the tank even if there is a fuel tank. And it is completely random. Maye I can get to cleaning the fuel pump this weekend, The car runs like a monster when the fuel get there, I am going to heve to start being more careful on where I fill up
Old 10-17-2007, 07:38 PM   #8
shootinsoobie
Member#: 71170
04 JBP
All Murdered Out
i looked at this and thought i was back in the matrix!!
shootinsoobie is offline   Reply With Quote
Old 10-19-2007, 10:29 AM   #9
akira02rex
Member#: 82612
'02 WRX - Sold
Now 2013 WRX
that looks like an afr reading from the oem o2 sensor, is it?
akira02rex is offline   Reply With Quote
Old 10-20-2007, 12:32 PM   #10
VideoGameWrx
Member#: 68197
2005 OBP WRX
PPG + EJ257
yes it is, i know its not very accurate but it doesnt give me an idea of rich vs lean
Fuel pump problems? Help please! big_dog Factory 2.0L Turbo Powertrain 4 08-09-2008 07:20 PM
Question on fuel pump. Please help! RicerJim Car Audio, Video & Security 1 04-09-2004 02:37 PM
Question on fuel pump. Please help! RicerJim Electrical & Lighting 2 04-09-2004 02:14 PM
Need new fuel pump! Please help! AWJunkies Southern California Impreza Club Forum -- SCIC 4 07-05-2003 10:56 PM
bad fuel pump?? any aftermarket?? pearlblack2.5rs Service & Maintenance 2 11-15-2001 02:17 AM
Message Board Statistics All times are GMT -4. The time now is 02:07 AM.
