Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 10-01-2007, 08:41 AM   #1
kike_ej20
Member#: 145440
MY96 WRX GT2835-ProS
EJ20G 2123cc!!
Default Swaybars & Drag Racing
Please, express your thoughts,opinions and/or facts based on this topic.
Thanks
kike_ej20 is offline   Reply With Quote
Old 10-01-2007, 09:49 AM   #2
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Not needed if it's a dedicated drag car. Hell, you dont even "need" them on the street if you have your struts set real stiff. Of course, the car still won't handle well.
wcbjr is offline   Reply With Quote
Old 10-01-2007, 10:13 AM   #3
kike_ej20
Member#: 145440
EJ20G 2123cc!!
I thought that on AWD cars,swaybars( stiffer/bigger ones) would help with the grip out of the line.
Old 10-01-2007, 12:20 PM   #4
rkramer
Member#: 118209
2015 WRX Limitec
swaybars do nothing in a straight line. the only time in drag racing they would make any difference is if you have a car that is prone to wheel hoping, it might help a little with that.
Old 10-01-2007, 12:31 PM   #5
RexFTW
Member#: 107179
S4, WRX
1.27 60', 9.37 1/4
I don't consider myself an expert, but I doubt they would really help at all. A swaybar resists having one side of the car rise or fall versus the other side of the car. Upon launch, the entire rear of your car will squat and the front will rise. There are no forces for the swaybar to act against. The only thing changed is you have a bit of extra weight to pull with you.
Please correct me if I am wrong.
RexFTW is offline   Reply With Quote
Old 10-01-2007, 12:34 PM   #6
sureshot007
Member#: 142405
#716 G2 OBS
no turn, no need.
sureshot007 is offline   Reply With Quote
Old 10-01-2007, 01:00 PM   #7
kike_ej20
Member#: 145440
EJ20G 2123cc!!
Why then would the V8/RWD community unhook the FSB and get a stiffer/bigger RSB for traction? ....that is so they can lift the front tires and distribute the weight where is needed.. THE BACK TIRES
read above
Old 10-01-2007, 01:20 PM   #8
Crazy D
Member#: 35927
02 wrx
Some guys I know,will run no sway on the rear..not sure how safe that is,but you really don't need one going in a straight line.
Crazy D is offline   Reply With Quote
Old 10-01-2007, 01:44 PM   #9
Antyoo
Member#: 64161
2004 WRX
read above
they do it because they make enough torque so that the the body of the car twists as it lifts the front of the car/weight transfers.
removing the fsb lets the front end lift up more naturally and in the back they use anti roll bars like this one http://chassisengineering.com/products/908.jpg
it has no flex where a sway bar would have some flex. keeps the rear end level.
subarus that makes that kind of torque are definately few and far between. so for all intents and purposes, its safe to say its a waste of time to think of how swaybars will affect your subaru in drag racing.
Antyoo is offline   Reply With Quote
Old 10-01-2007, 03:25 PM   #10
kike_ej20
Member#: 145440
EJ20G 2123cc!!
Look....they use sway bars. Go to any V8 forum and ask. I'm by no means starting a fight..I just want to know if those aftermarket SB that we use on our subies would help with the 60's.
BTW...take a look http://www.thunderracing.com/catalog...id=195&pcid=93
Looks like a SB to me
Old 10-01-2007, 03:44 PM   #11
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
A swaybar has absolutely no effect on or relation to lifting the front of the vehicle. You need to understand what a swaybar does.
If a vehicle with sway bars is going 100mph in a straight line down a highway, the swaybars are doing absolutely nothing. If a vehicle is going 15 mph in a straight line over a long speedbump, the swaybars are doing absolutely nothing. If you put the car up on 4 jackstands, the swaybars are still doing absolutely nothing. The only time swaybars will do anything is when the left and right of the vehicle are not at the same spring bound/rebound.
Old 10-01-2007, 03:53 PM   #12
remowgn
Member#: 41149
09 FXT
SSM
They use sway bars because they have solid axles. The driveshaft of the car actually twists the axle, and lifts the passenger side rear tire off the ground. For them, a sway bar prevents this from happening.
Since subarus have independent rear suspension (and they're all wheel drive for that matter) a sway bar will do jack squat.
remowgn is offline   Reply With Quote
Old 10-02-2007, 10:52 AM   #13
oneoverWRX
Member#: 74793
02 WRX
BLAZE YELLOW
I think a sway bar will neither hurt or help you at the drag strip.The only advantage i can see from removing it would be weight savings.Leaving It could help a wheel hop issue. My car pulled high 1.6s with my cusco rear sway bar still on the car. This was with 32psi in the fuzion zri tires(235/40/17) Ill let you know what i pull on radials here in a couple weeks.
oneoverWRX is offline   Reply With Quote
Old 10-03-2007, 12:59 AM   #14
dyrmz134
Member#: 127336
1995 s14.5
mostly red
There it is. Question answered
dyrmz134 is offline   Reply With Quote
Old 10-03-2007, 01:47 AM   #15
El Gato
Member#: 110648
Chapter/Region: PRSIC
2005 Hydramist 35R82
93oct 479whp 456tq
Exactly, don't be "swayed" by these people, hmmm?
El Gato is offline   Reply With Quote
Old 10-03-2007, 04:40 AM   #16
MRF582
Member#: 48219
. Always drive
the race line .
Wow, that was amazingly clever. I'm going to write that down.
MRF582 is offline   Reply With Quote
NOPI TV & Car Show/NDRA Drag Race - Phoenix, AZ 3/19-20 NOPIMAN South West Impreza Club Forum -- SWIC 14 03-18-2005 09:49 AM
First Drag Race ... :-) & :-( Question makofoto Proven Power Bragging 7 06-06-2003 01:35 AM
NHRA Drag Races at Sears Point, 9/7 & 9/8!!! B-SpecUSA Bay Area Impreza Club Forum -- BAIC 10 09-07-2002 10:05 PM
NHRA Drag Races at Sears Point, 9/7 & 9/8!!! B-SpecUSA Southern California Impreza Club Forum -- SCIC 1 09-06-2002 10:00 PM
MIR Imstar MIR Car show & Drag Race April 21! imprezawd Mid Atlantic Impreza Club -- MAIC 8 04-08-2002 02:17 AM
