Old 01-15-2002, 05:12 PM   #1
DoughtCom
Member#: 12565
1997 Swapped L Coupe
Steel Blue Mica
Default H&R Springs and KYB Struts
Hey... I need some advice from some of you guys. I got some H&R Springs, and some KYB GR2 struts. The front ones didn't really need to be compressed at all, they fit perfectly. When I got to the back ones, there was an inch gap between the top of the strut brace and the top of the spring. I called SPO and they said that the part numbers match perfectly. I called H&R and they said that the part number was right for that model car. So the only thing I'm left with is that maybe they're supposed to be like this? It just seems to me that if I were to be air born long enough, that the springs would just pop out of place and kill my tire, causing me to wreck. Let me know what anyone thinks, and if people have experienced this same situation.
Thanks in advance
Shawn (DoughtCom)
DoughtCom is offline   Reply With Quote
Old 01-15-2002, 11:39 PM   #2
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
Shawn, if you have a pic, it'd be easier to visuallize.
The spring isn't even suppose to be anywhere near a strut brace. Are you referring to the strut hat?
GTBGUY is offline   Reply With Quote
Old 01-15-2002, 11:52 PM   #3
DoughtCom
Member#: 12565
Steel Blue Mica
yeah sorry... the strut hat, is what I was referring to. I don't have any pictures yet. I went ahead and had them put on. so far it seems to be ok. Looks like everyone elses Legacy that had lowering springs put on. If anyone could let me know if it's normal for the back springs not to have to be compressed, that would be cool.
thanks
Old 01-16-2002, 09:21 AM   #4
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
I remember reading in the Suspension forum about people with a similar situation, or perhaps it was SCC...anyway...
They calculated the time you'd have to be airborned in order for the strut to decompress enough to let the spring bounce.
It's long enough that you wouldn't be worrying about your springs, but probably your life.
So, they should work just fine.
DLC is offline   Reply With Quote
Old 01-16-2002, 09:43 PM   #5
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Dave's probably right about the time factor and what not, given the time to uncompress and unseat themselves.
You really should have preload on the springs, but in your situation, there's really not alot you can do. Just try not to do too many of those rally car jumps.
Legacy777 is offline   Reply With Quote
H&R Springs on KYB GR-2 Struts? Local_Skater Brakes, Steering & Suspension 1 10-03-2006 10:43 PM
FS: H&R Springs on KYB GR-2 struts from 2000 Impreza RS nickjl NWIC Private Classifieds 2 04-24-2006 01:23 AM
WRX Wagon Springs and KYB AGX Shocks and Struts Rally_wgn Brakes, Steering & Suspension 2 10-31-2005 03:43 PM
H&R springs or Eibach springs with KYB struts? sadd16 Brakes, Steering & Suspension 9 09-24-2005 04:07 PM
H&R Springs and KYB GR-2 Install Questions Nantallen Legacy Forum 10 05-20-2004 04:13 PM
