Welcome to the North American Subaru Impreza Owners Club Wednesday March 4, 2015
Old 10-01-2007, 03:39 PM   #1
bnice01
Member#: 160619
Default EcuFlash 1.33
Has anyone tried this yet, and what verison of EcuFlash is everyone running? I have been reading that some verison with certain years have had problems.
bnice01 is offline   Reply With Quote
Old 10-01-2007, 04:14 PM   #2
VideoGameWrx
Member#: 68197
2005 OBP WRX
PPG + EJ257
I tried the new version with no luck. I had to search for a pre 1.3 version. Right now I am using 1.28. It works fine on my 05 wrx so I see no reason to change it...
VideoGameWrx is offline   Reply With Quote
Old 10-01-2007, 04:25 PM   #3
bnice01
Member#: 160619
i hear that "if aint broke dont fix it" LOL
Old 10-01-2007, 04:41 PM   #4
CGMTurboBoxer
Member#: 151972
2005 CGM STI
Melvin 2.0
I just got my tactrix cable and tried using version 1.33, i keep getting some timeout error....???
CGMTurboBoxer is offline   Reply With Quote
Old 10-01-2007, 04:48 PM   #5
bnice01
Member#: 160619
is your ignition on?
Old 10-01-2007, 04:52 PM   #6
CGMTurboBoxer
Member#: 151972
2005 CGM STI
Melvin 2.0
Of course, I get a bunch of "SSM2 INIT" listed(like 10) then connection timed out
Old 10-01-2007, 05:47 PM   #7
bnice01
Member#: 160619
see if you can download or find 1.29 verison and try it
Old 10-01-2007, 05:51 PM   #8
CGMTurboBoxer
Member#: 151972
2005 CGM STI
Melvin 2.0
yeah i've been looking for that as well.... if i do find it, will it still work with the OpenPort 1.3 cable???
Old 10-01-2007, 07:05 PM   #9
CGMTurboBoxer
Member#: 151972
2005 CGM STI
Melvin 2.0
nevermind i got it to work perfectly fine, i didn't have all my connections fully connected.... other then that it was flawless
I apologize for my stupidity.
Old 10-01-2007, 08:30 PM   #10
bnice01
Member#: 160619
awesome, glad you got it working bro
Old 10-02-2007, 01:23 AM   #11
06rexwagon
Member#: 114730
2006 WRX Limited Wag
9.8@150
Those that are having problems should uninstall and completely delete the openecu folder under program files then reinstall.
06rexwagon is offline   Reply With Quote
Old 10-02-2007, 11:04 AM   #12
bnice01
Member#: 160619
x2
Old 10-02-2007, 10:37 PM   #13
06rexwagon
Member#: 114730
9.8@150
1.33 crashes immediately if I try to read a rom from the car. Anyone have a link to 1.32? I have 1.31, 1.30 etc.
Old 10-02-2007, 11:03 PM   #14
CGMTurboBoxer
Member#: 151972
2005 CGM STI
Melvin 2.0
Once all my connections were correct it worked flawlessly for me..... also making sure the drivers are correct is somewhat important
Old 10-02-2007, 11:10 PM   #15
06rexwagon
Member#: 114730
9.8@150
Were you able to read? I've been using ecuflash for nearly 2 years and I understand how to install the drivers.
Old 10-02-2007, 11:14 PM   #16
06rexwagon
Member#: 114730
9.8@150
Also, I'm using an openport 1.2 cable.
Old 10-03-2007, 12:04 AM   #17
bnice01
Member#: 160619
that may be the problem righ there
Old 10-03-2007, 12:44 AM   #18
Nuke209
Member#: 108089
2003 WRX
NF Performance
Right Click & Save As...
ECUFlash 1.28
http://www.aznraps.com/nuke/ecuflash...sh_128_win.exe
ECUFlash 1.29a
http://www.aznraps.com/nuke/ecuflash...h_129a_win.exe
ECUFlash 1.30
http://www.aznraps.com/nuke/ecuflash...sh_130_win.exe
ECUFlash 1.31
http://www.aznraps.com/nuke/ecuflash...sh_131_win.exe
ECUFlash 1.32
http://www.aznraps.com/nuke/ecuflash...sh_132_win.exe
ECUFlash 1.33
http://www.aznraps.com/nuke/ecuflash...sh_133_win.exe
Nuke209 is offline   Reply With Quote
Old 10-03-2007, 12:45 AM   #19
06rexwagon
Member#: 114730
9.8@150
Thanks Nuke. I found 1.32 on a jump drive, but I'm going to download the other versions.
Old 10-03-2007, 02:18 AM   #20
Nuke209
Member#: 108089
2003 WRX
NF Performance
Yea, No problem
I suggest everyone grab these versions here and put it away, sometimes the new stuff doesn't work for others
Old 10-05-2007, 04:50 AM   #21
.one lane
Member#: 114528
2002 Space Shuttle
Discovery
I keep getting a "[00:35:09.371] Unable to find parent metadata wrxbase". Is anyone else getting this problem
.one lane is offline   Reply With Quote
Old 10-05-2007, 10:29 AM   #22
06rexwagon
Member#: 114730
9.8@150
I haven't seen that one. Sounds like your ecu definitions are in the wrong directory.
Old 10-05-2007, 03:16 PM   #23
.one lane
Member#: 114528
2002 Space Shuttle
Discovery
I had no problem with 1.30, but once i switched over to 1.33 I keep getting that. I even tried to copy "wrxbase" from 1.30 to 1.33 the map opened, but it was all weird.
Old 10-05-2007, 05:32 PM   #24
06rexwagon
Member#: 114730
9.8@150
Go back and uninstall 1.33, then delete the entire openecu folder under program files. Reinstall 1.33 and try again.
Old 10-05-2007, 05:34 PM   #25
.one lane
Member#: 114528
2002 Space Shuttle
Discovery
I've did several times with no luck opening an xpt map for an 02, but when I tried to open my friends xpt map for an 06 it open without a problem.
Tactrix Cable Broken or Missing Something for Ecuflash 1.41????? Phatron Open Source Reflashes 8 03-09-2009 10:38 AM
EcuFlash 1.41 Released Today - 01/29/2009 Cocoa Beach Bum Open Source Reflashes 14 02-18-2009 08:26 PM
Looking for ecuflash 1.29a download sorrowfulkiller Open Source Reflashes 3 01-12-2009 10:21 PM
Anyone have a copy of EcuFlash 1.34? JMS77 Commercial ECU Reflashes 2 11-27-2007 12:33 AM
Ecuflash 1.31.1396 unable to read or flash WJM Commercial ECU Reflashes 23 10-01-2007 07:06 PM
