Old 10-01-2007, 10:00 PM   #1
bjpeppers
Member#: 104680
Default PLEASE HELP Quick Question....
I have an 05 WRX and I spun a rod bearing. I almost went with a 2.5L block but instead bought an 04 WRX motor with 20,000 miles on it. So, the question I have is will my 05 ECU work with my 04 Motor? Also, what do you think? I already had the following mods:
1. Perrin Crank Pulley
2. Snorkle removal
3. Perrin Drop in Filter
4. Perrin UP pipe
5. Tsudo downpipe
6. Subiedude short shifter with bushings
S0, I bought the motor and the following
1. ERZ CBE
2. Samco Intercooler Hoses
3. Gripforce stage2 clutch and racing flywheel
4. Grupe N Motor and transmission mounts
Did I make a decent decision? I am thinking about using open source ECU software to flash the ECU. With the 04 motor and the 05 ECU if that worked I assume I would get the software for the 05 correct? Sorry for all the questions.....I am sort of freaking out with all this money being spent.....I hope the new motor is what the guys says it is. Anything I should be looking for when I pick up the motor? Thanks in advance. You guys are great!!!!
bjpeppers is offline   Reply With Quote
Please Help...Quick Timing belt question Sube-Doo Newbies & FAQs 18 11-09-2009 02:08 PM
Please help quick! Koni Insert question FromEvoToRS37 Brakes, Steering & Suspension 12 09-01-2007 02:49 PM
Please Help! Quick Question FromAP1toSTI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 07-14-2006 01:37 AM
Please help quick - RE92 directional tread question megatron Brakes, Steering & Suspension 3 11-25-2001 07:33 PM
Please help! Quick question! IBO Normally Aspirated Powertrain 0 09-03-2001 05:03 AM
