Welcome to the North American Subaru Impreza Owners Club Sunday March 29, 2015
Old 01-15-2002, 06:55 PM   #1
SWITCH
Member#: 4848
2002 Impreza WRX
Default Tools needed to change rear diff fluid?
I was just wondering if there are any special tools required to change the rear diff fluids for my WRX? Is there a pump that you can buy to get the oil in the fill hole? If so, where would I get one? I've never done this before but it seems like a simple enough task.
Thanks
SWITCH is offline   Reply With Quote
Old 01-15-2002, 07:48 PM   #2
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Should be about the same as the RS..
http://www.scoobymods.com/forums/sho...?s=&threadid=3
kastle is offline   Reply With Quote
Old 01-15-2002, 10:08 PM   #3
SWITCH
Member#: 4848
2002 Impreza WRX
Awesome, thanks for the link!
Old 01-16-2002, 11:51 AM   #4
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Be aware. The filler and drain bolts are extremely tight. It's bad enough they are located in a tight area under the car. I used an impact wrench gun to get them loose. Retighten the bolts to 35lb/ft of torque.
tmat3 is offline   Reply With Quote
How to refill rear diff fluid? MF-DIF Service & Maintenance 17 07-15-2006 10:47 PM
Changing rear diff fluid with less than 3K Craig02WRX Transmission (AT/MT) & Driveline 2 11-09-2004 02:43 PM
Switching to synth rear diff fluid Q IggDawg Transmission (AT/MT) & Driveline 4 08-02-2002 02:29 PM
Attn: Scooby South (need to change rear diff. fluid on Sunday) Aspen_2.5RS South East Region Forum 9 05-26-2002 10:43 PM
where and how to change my diff fluid? GregBolby Normally Aspirated Powertrain 3 11-26-2000 09:38 PM
