Old 01-15-2002, 07:28 PM   #1
Br0kWRX
Member#: 12317
Default Power steering problem
Recently I have noticed that when I am at dead stop or slowing down, the steering is much stiffer. At first it felt almost like there was something wrong with the power steering. However, If I blip the throttle, it turns effortlessly. I checked the fluid level and it seems fine. Has anyone else experienced this?
Br0kWRX is offline   Reply With Quote
Old 01-15-2002, 10:30 PM   #2
Jon [in CT]
Member#: 2992
02 WRX Sedan
Well, I haven't experienced this personally, but others have had serious power steering problems: http://www.i-club.com/forums/showthr...hreadid=106386
Jon [in CT] is offline   Reply With Quote
Old 01-16-2002, 12:09 AM   #3
subix
Member#: 7970
2002 Impreza WRX
I had the same problem but mine was a lot more pronounced. There was no power steering at idle but was fine when around 2k+. It only gets worse as time goes on.
It was my power steering pump that died, and was replaced under warrenty. Good luck finding a pump in the us. I had to wait two weeks for mine and I was lucky enough to get "dibs" on one of the two on their way in to the country.
subix is offline   Reply With Quote
Old 01-16-2002, 12:27 AM   #4
Karnage
Member#: 8628
WR Blue Pearl
Default Re: Power steering problem
Did you recently change your tires? I noticed when switching from the RE-92's to the Dunlop SP 5000's that the steering has slightly more resistance at low speeds, resistance seems a bit higher when parking though. When driving at normal speeds all I notice is ALOT more grip.
If the tires have more grip, they will be more difficult to turn compared to tires with not much grip. Of course if you haven't changed your tires then they probably aren't the source of your problem.
--Karnage
Karnage is offline   Reply With Quote
Old 01-16-2002, 09:56 AM   #5
ZMANNH25rs
Member#: 9401
. Truth is a
pathless land...
Default Happened to me
This happpened to me after I did too many AWD donuts in a field. Since we have power sterring once on the gas the steering became more like normal, but at idle it was very very hard to turn the wheel, also on the highway when coming off throtle it was tough to steer. Brought the car to my dealer (forgot to mention the donuts) and they fixed it on a warrnaty repair. They said the pump it's self was blown - what ever the hell that really means. But since then I've gone 6000 + miles and have had no problems. Bring it to the dealer, and make them FIX IT !
ZMANNH25rs is offline   Reply With Quote
Old 01-16-2002, 10:32 AM   #6
Br0kWRX
Member#: 12317
Thats EXACTLY what happened to me. I was doing donuts and as soon as i got home I noticed it.
Old 01-16-2002, 12:12 PM   #7
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
There were some posts about the power steering hoses being loose. Doing those donuts you probably lost all the power steering fluid.
LiquidForce is offline   Reply With Quote
Old 01-17-2002, 09:37 AM   #8
ZMANNH25rs
Member#: 9401
. Truth is a
pathless land...
If it was from the donuts bring it to the dealer, I told them I was making a u-turn and hit the gas too hard, with the wheel all the way cut. - Warranty Repair - yipee
As for the power sterring fluid, the resevoir was full when I brough it to the shop, the dealer said it was the pump it's self that was toast !
Old 01-17-2002, 01:13 PM   #9
subix
Member#: 7970
2002 Impreza WRX
I know that I had no leaks and didnt look like I was missing any fluid. I think there are two seperate power steering problems.
Power Steering problem ZMANNH25rs Brakes, Steering & Suspension 9 04-30-2002 05:30 PM
Power steering problem subix Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-01-2002 01:28 AM
Different Power Steering Problem? Mister Toro Warranty Issues & SOA Problems 4 11-08-2001 10:06 PM
Power steering problem ZMANNH25rs Warranty Issues & SOA Problems 4 10-17-2001 11:39 AM
Power steering problem? psoper Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-08-2001 08:07 PM
