Old 10-02-2007, 11:00 AM   #1
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
Default 2004 STI, Axis Racing Longblock and 35R Initial Tuning
Well, we finally got some of the kinks worked out on my motor and (knock on wood) it seems to be running well.
I brought the car in on Saturday to work to do some tuning and we couldn’t really get it to make any power. It was only making about 430whp on my dyno (Mustang Dyno). But the biggest thing was I was going over the knock thresholds on the Hydra. Based on the tune, I just couldn’t believe I was actually knocking…Cam2 114 leaded race gas, 11:5:1 AFR and 12* at peak torque rising to 16* by redline.
Talked to Phil at Element Tuning on Monday and he smoothed out my fuel map and bumped up my knock corrections. Wow, right off the bat, the car made 420whp with AFR’s that were a little rich (11:1), but rock solid through the entire run. It was also really rich during spool up, so I leaned out the spool up and leaned out the in boost a little (11.5:1) to get the fuel map right. Then went ahead and started adding timing. I ended up making about 470whp and 430wtq at the same boost level as Saturday.
Now here’s where it gets really interesting…..I did that at 26psi tapering to 22psi by redline. That’s right….470whp at 22psi!!! And on the heartbreaking low reading Mustang Dyno….this is well over 500whp on a Dynojet for all the dyno queen guys. Last year, with just a set of pistons in the motor, I made 510whp at 32psi. So Ron’s head/cam package is really shining with the 35R.
Major problem we are having right now is we can’t make anymore boost. So I’m going to order the wastegate helper spring in order to bump the base pressure up to 20psi, so I can hopefully make over 30psi.
Mods:
Axis Racing Stage 3 Motor with Carrillo Rods and Wiseco pistons (8.9:1 compression)
Axis Racing P&P Heads
Supertech valvetrain and +1mm valves
Kelford 278/272 non-AVCS cams
Perrin header
Perrin GT35R kit
Buschur Racing Catback
TurboXS Intercooler with custom IC pipes
Reversed Intake Manifold
WRX TGV’s
Deatschwerks 1150cc injectors
Perrin top feed fuel rails
Buschur Racing Dual Walbro System
Hydra 2.5+
Buschur Racing Manual Boost Controller
I’m sure there is more, but I can’t remember.
Anyways, here’s the graph I downloaded off the computer. Ah, the quest for power has begun!!
SloRice is offline   Reply With Quote
Old 10-02-2007, 11:18 AM   #2
dmross
Member#: 2818
2000 2.5RS
Nice!!! When can I come up and use the dyno? (and get a ride!)
dmross is offline   Reply With Quote
Old 10-02-2007, 11:20 AM   #3
F EVOZ
Member#: 134516
o2 WRX BlankitaRIP
o6 STi Blanca
nice smooth graph.....I'm assuming the motor is broken in or whatnot but what is the maximum rpm you could have taken it to? I believe 7000rpm is teasing that motor of yours lol
F EVOZ is offline   Reply With Quote
Old 10-02-2007, 02:18 PM   #4
stickman
Member#: 13890
2007 Mazda CX 7
Icy Blew
nice.
that was still on cam2 114 leaded race gas?
how come no AVCS?
stickman is offline   Reply With Quote
Old 10-02-2007, 04:18 PM   #5
SloRice
Member#: 44351
2004 Mitsubishi Evo
I'm lucky to get to use the dyno!! It's not permanent....it's just going through production...so it will get shipped out eventually.
I have about 1300 miles on the engine. Ron @ Axis says the motor is capable of going to 8500RPM. With the head/cam/turbo package I'm running, he said it should make peak power in the 7500-7700RPM range. But if you look at the graph, its making peak power at 6000RPM. So no point running it out to 7500-8000RPM until we get the boost taper situation fixed.
Originally Posted by stickman View Post
nice.
how come no AVCS?
Correct....Cam2 114 leaded race gas.
With non-AVCS cams, you get the ability to run a higher lift cam because the fear of putting the valves into the pistons with the AVCS isn't there anymore. Higher lift means more airflow, which means more power.
I'm going to try a different boost controller today after work to see if that allows me to make more boost. I also have a 20psi base spring on order for the wastegate...should be here Thursday.
Old 10-02-2007, 05:08 PM   #6
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
do you have adjustable cam gears? if so, I'd retard that exhaust cam gear a bit...
pretty good amount of power though
Old 10-02-2007, 05:36 PM   #7
burnin4
Member#: 59764
10 sec STi
10 sec Z06
those are good number! very similiar to my Axis longblock, 18psi/93octane 471/400. 1/2 tank of 93 + 5 gallons of c16 = 545/488. <--- good enough to run [email protected] (last week).
burnin4 is offline   Reply With Quote
Old 10-02-2007, 05:53 PM   #8
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Great job with this car, id be very happy with those results as Im sure you are! Goodluck with the rest of the tuning, that is s sick graph up there^
PaulRex is offline   Reply With Quote
Old 10-02-2007, 05:57 PM   #9
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Nice numbers Tim. Get that boost holding up top and thats going to be one wild ride.
Junior
Junior2JZ is offline   Reply With Quote
Old 10-02-2007, 06:26 PM   #10
SloRice
Member#: 44351
2004 Mitsubishi Evo
Thanks guys...well, off to see if the new boost controller does anything. Wish me luck!
Wild ride?? Oh yea!!....I have the 2007 3rd and 4th gears in my tranny...no shifting to 5th for me!!
Old 10-02-2007, 06:29 PM   #11
flycaster
Member#: 60142
2011 WRX
Grey
Very cool. I'm really curious to see what happens once you get the boost figured out.
flycaster is offline   Reply With Quote
Old 10-02-2007, 06:37 PM   #12
MJU1983
Member#: 14364
2003 WRX, '06 Armada
05 Vette & 05 STi (sold)
Nice man!
People just don't realize the benefits of ported heads, cam/valve train package to make their engine (air pump) a better flowing one. It makes a HUGE difference when you can run much less boost more efficiently to make more power than before with higher boost pressure.
And I can vouch for the Mustang Dyno being a low reader, god is it ever!
MJU1983 is offline   Reply With Quote
Old 10-02-2007, 09:09 PM   #13
SloRice
Member#: 44351
2004 Mitsubishi Evo
No dice on the new manual boost controller.
20 psi base spring comes in Thursday. We'll try that next and see if that helps get the boost up.
Old 10-03-2007, 10:26 AM   #14
SloRice
Member#: 44351
2004 Mitsubishi Evo
I may also buy a GM boost solenoid and hook it up to the Hydra. Talking with Tim Bailey, he has some good base maps for the boost tables in the Hydra and says it works really well.
So if the MBC doesn't work so well, I'm trying that next.
Old 10-03-2007, 01:02 PM   #15
kharris4
Member#: 46018
2003 wrx
silver(mostly stock)
what kind of knock voltage were you getting when it was knocking?
kharris4 is offline   Reply With Quote
Old 10-03-2007, 01:11 PM   #16
SloRice
Member#: 44351
2004 Mitsubishi Evo
My original knock threshold map peaked out about .6 volts. Phil bumped them up to a max of .8 volts. The general noise of the car is right in the .55-.7 volts, so I'm probably going to bump the new threshold map down to .75 volts.
Old 10-03-2007, 02:35 PM   #17
WebMasterP
Member#: 121062
2006 STi [STU Trim]
World Rally Blue
What exhaust headers and what's the size hotside did you get on the 35R?
WebMasterP is offline   Reply With Quote
Old 10-03-2007, 02:40 PM   #18
SloRice
Member#: 44351
2004 Mitsubishi Evo
The info is all up in the original post...but....Perrin header, Perrin 35R .82ar turbo kit and Buschur Racing catback.
Old 10-03-2007, 02:52 PM   #19
modaddict
Member#: 95840
sold to a good bud
awaiting next car
nice Tim!!!!!!!!!!!!!!!!!!!
modaddict is offline   Reply With Quote
Old 10-03-2007, 03:06 PM   #20
WebMasterP
Member#: 121062
2006 STi [STU Trim]
World Rally Blue
Ahh, I didn't know the extent of the Perrin kit (didn't know it came with the headers). Thanks and sorry.
Old 10-03-2007, 03:39 PM   #21
SloRice
Member#: 44351
2004 Mitsubishi Evo
opps...sorry. I thought I posted Perrin headers in the mod list in the first post....i'll edit it and add them in.
Old 10-03-2007, 05:56 PM   #22
aps2fast4u
Member#: 57871
2004 WRX
13.4 @ 102
very nice!!
Good to see things coming together for ya!
aps2fast4u is offline   Reply With Quote
Old 10-03-2007, 06:07 PM   #23
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
what are you reving the block to? 8500 as suggested through Ron? How is the oil pressure up top in the rpms? Does it drop at all?
When do you see full boost by with the cams?
Couple questions, sorry! I just wanted to know since I am going to run the identical setup, just with the full-race twin scroll GT3582R with twin wastegate design, rc1000s, and aeromotive external pump...
Very impressive numbers, im getting soo excited! Can't wait for mine to be finnally finished! The only thing is, how do you not plan on shiftin into 5th even with the 07 gears. They generally top out at 117-119, if you rev to 8500 maybe you can get an extra 10mph out of it, but that's going to be cutting it close. I bet you trap 125-129 depending on what fuel you got in the tank.
D Money is offline   Reply With Quote
Old 10-03-2007, 07:57 PM   #24
MRF582
Member#: 48219
. Always drive
the race line .
what's causing the choke at high rpms? cams or smaller than ideal turbine/housing? i would think the cams should make power until 8K atleast. what are the specs on the GT35?
MRF582 is offline   Reply With Quote
Old 10-03-2007, 09:18 PM   #25
SloRice
Member#: 44351
2004 Mitsubishi Evo
D Money - I am currently only revving it to 7000RPM. As you can see, power is on the way down after 6000RPM so no point revving it higher. I'm fighting a boost taper issue and that's why it's not making big power right now. 20psi wastegate spring is coming tomorrow and hopefully that will allow me to make and hold more boost.
The graph isn't real indicative of the boost. I am making 20psi by 4300RPM and 26psi by 4600RPM. After talking with Phil, I just need to add a little more timing in from 4000RPM to 5000RPM and that will bring the torque up in that area and not make the graph look so laggy.
From 3000RPM to 7000RPM, oil pressure is rock solid at 5 bar.
As for the gearing...yea, it tops out at 118MPH....at 7000RPM. Rev it to 8500 and you are at 140+MPH.
MRF582 - at this point, there isn't anything choking the setup that I can see. The biggest issue is not holding boost....which means the engine is flowing very well.....or at least flowing better than the turbo and it can't keep up. Thats why we are switching out the wastegate spring from a 14psi spring to a 20psi spring. The setup will make peak power around 7500RPM. Once we get the boost issue ironed out, we'll figure out what the next piece of the puzzle choking the system is. It's a standard GT3582R.
FS : 2004 STI with new motor and tuned for E85 $20,000 NAZSTI SWIC Private Classifieds 3 06-15-2010 07:54 PM
05 Sti 6Spd Swap, longblock, and alot of other stuff.... triple_s1x MWSOC Private Classifieds 2 04-01-2010 12:03 AM
FS: Axis Stage 5 Shortblock, Axis Race heads and MUCH MORE!!! mxturboracer86 Engine/Power/Exhaust 36 03-27-2009 08:12 PM
Are silver 2004 STI BBS 17x7.5 and Gold 2004 STI BBS 17x8? subierider Tire & Wheel 10 01-20-2009 05:23 AM
Ecutek Easy ECU race gas and pump gas tunes on Stage 1 STI - Dyno Flash Dyno Flash Proven Power Bragging 4 11-01-2006 11:09 PM
