Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 10-02-2007, 10:37 AM   #1
ted dibiase
Member#: 94752
2003 wrx
wrb
Default does anyone else have problems with their hybrid?
About a year ago my 2.0 liter blew up, so I swapped in a 2.5 liter short block and mated it to my 2.0 liter heads. It has never really run right. I get boost creep, it doesn't idle right, it feels jerky and/or shaky. I feel like I need an EWG to fix the creep problem, but I also feel like part of my problems could be in trying to mate that head to that block. I'm looking for a simple fix to a complex problem I guess. Has anyone else had these types of problems? How did you fix it or did you? Would it make sense to get and STi head, or would cams work just as well? I would like to have good factory like power. I'm not interested in making 800 hp, I just want my car to run right and to have enough power. What all would be required to make it more like a factory tuned/engineered EJ257? Obviously the head, but what else? How are people controlling AVCS? Is it time for me to just get full stand alone EM? This is so ****ing frustrating... I wish I would have just rebuilt my 2 liter.
ted dibiase is offline   Reply With Quote
Old 10-04-2007, 01:41 AM   #2
Sko
Member#: 90396
2005 Legacy 2.5i
Brilliant Silver Metallic
Stock ecu? Sounds like it just needs a reflash.
Sko is offline   Reply With Quote
Old 10-04-2007, 02:17 AM   #3
STiBottom
Member#: 127041
02 WRX
Midnight Blue Pearl
Don't get discouraged. I have had some problems with mine with the random leaks and constant monitoring of the whole system but it is worth it. What you might try doing is going somewhere that is known to be great at tuning subarus and see if they can smooth things out for you. Also you might want to check your suspension for the "shakes" could be the clutch though. I don't know without a more accurate explanation. The heads on the wrx are really limited by the cams however they do improve the spooling time of some turbos over the STi cams. I see full boost on my VF-39 a little earlier than a stage II STi. If done right then the hybrid can be really fun and it can teach you a lot about cars in general.
STiBottom is offline   Reply With Quote
Old 10-04-2007, 10:07 AM   #4
oneoverWRX
Member#: 74793
02 WRX
BLAZE YELLOW
yes a hybrid can be very fun. The only problems i have had so far have been traction related.
get a tune and see what happens.
oneoverWRX is offline   Reply With Quote
Old 10-04-2007, 10:22 AM   #5
ted dibiase
Member#: 94752
2003 wrx
wrb
I have been tuned numerous times with my AP. I was over-boosting so I ported the 16g and it helped a little. I recently purchased some STi heads, but I'm not sure if that will fix the problems.
Old 10-04-2007, 11:55 AM   #6
Member#: 106514
So with a 2.5L you are adding a .5L of displacement, which means it is a bigger engine, which means you have more exhaust gas energy.
Did you or your tuner change out the boost pill size to a larger pill? This will allow the wastegate to open a little sooner and lessen or get rid of your boost creep issue.
- J.
Jeremy@Cobb is offline   Reply With Quote
Old 10-04-2007, 02:26 PM   #7
ted dibiase
Member#: 94752
2003 wrx
wrb
Good info Jeremy. I know the tuner didn't change the boost pill size, but I'm using a GM boost solenoid. Does the pill size still have any bearing?
Old 10-04-2007, 02:39 PM   #8
cm1wrx
Member#: 33413
03 WRX
The pill should be removed when using the GM boost solenoid. You should have run all new vacume line when installing it. New line= No Pill.
cm1wrx is offline   Reply With Quote
Old 10-04-2007, 04:53 PM   #9
ted dibiase
Member#: 94752
2003 wrx
wrb
That is what I thought.
Old 10-07-2007, 08:21 PM   #10
JMK508
Member#: 115420
Its like a STI.....
but it doesn't break
Who is tuning your car. THey should know little things like taking the pill out when going with the GM.
JMK508 is offline   Reply With Quote
anybody else have problems with their vizio flat screens? wrxej205 Off-Topic 39 04-06-2010 08:40 AM
does anyone else have problems with blowing hoses?? wrxstistunna Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 08-23-2004 06:47 AM
Does anyone else have issues with their H3 foglight bulbs? obyone Interior & Exterior Modification 9 11-08-2002 09:55 PM
Anbody else have problems with their car @ 5K RPM's?? (DTC P1544 related?) redobs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-06-2001 04:39 PM
('93-'01) Anyone else have problems with carparts.com Tex-WReX Impreza Forum 8 07-21-2001 02:05 AM
