Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 10-02-2007, 01:38 PM   #1
chosen_cartel
Member#: 151620
2003 WRX
Default Anyone have an opinion on modifying stock wrx injectors?
Here is a link I came across....
http://www.teamscss.com/Subaru%20WRX...ctor%20Mod.htm
Has anyone had experience with this or heard any good or bad stories?
chosen_cartel is offline   Reply With Quote
Old 10-02-2007, 01:55 PM   #2
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
You will get mixed opinions. Plenty of people run them with no problem.
It will change the spray pattern and people say it messes with the atomization but I have not heard of it being a problem.
There are tons of threads on here about modified injectors, do a search and I bet you will get all the opinions you can handle. I know the search engine sucks but sometimes it is way quicker.
Smoby is offline   Reply With Quote
Old 10-02-2007, 01:58 PM   #3
Black-Falcon
Member#: 106318
16 Cadirrack
ATS-V
iirc the Destchewerkz (or however the hell you spell it) are modified stock injectors, flow matched too. I think they're good if you don't want to spend big bucks on injectors like PE's or something like that.
Black-Falcon is offline   Reply With Quote
Old 10-02-2007, 02:37 PM   #4
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
Yes they are Deatschwerks are modified stockers, and alot of people run them with no problem.
You decide against buyin my pinks chosen? I PM'd you back with my info but havent heard from ya
v8eaterWRX is offline   Reply With Quote
Old 10-02-2007, 04:00 PM   #5
Poweredbysnail
Member#: 74753
2003 Wrx 2.5Lw/gt30r
Team Snail
Poweredbysnail is offline   Reply With Quote
Old 10-02-2007, 04:11 PM   #6
WgnWheel
Member#: 63605
04 Wrx Wgn TimeAtk
10 Golf TDI, 08 Stang GT
i run the deatschwerks. probably the best modded injectors out there. all flow tested, maintains the stock spray pattern(big thing to watch for with others modded ones) and come with flow charts.
WgnWheel is offline   Reply With Quote
Old 10-02-2007, 04:49 PM   #7
intercoolerontop
Member#: 72148
2010 Ford Raptor
RAWR
i run the deatschwerk 750cc injectors that matched within 2cc of each other.
intercoolerontop is offline   Reply With Quote
Old 10-02-2007, 04:56 PM   #8
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
Kingpin used to do this and did a write up on here a while back. If they thought it was a good idea then I wouldn't do it.
Old 10-02-2007, 04:57 PM   #9
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
The deatschwerks, I am pretty sure they enlarge the existing holes in the cap correct?
Old 10-02-2007, 05:33 PM   #10
Silver Ra
Member#: 123143
03 wrx 08 forester
98civic k24/k20 02 Rsx
i got the 850's
Silver Ra is offline   Reply With Quote
Old 10-02-2007, 05:56 PM   #11
WgnWheel
Member#: 63605
04 Wrx Wgn TimeAtk
i think they use new caps?
Old 10-02-2007, 06:23 PM   #12
dozer54321
Member#: 116437
Deatschwerks ftw, im running 650's im not sure if travis remembers or what it exaclty is but with vf22 we werent even hittin 65% idc's
Deatschwerks drills out the outer ring of holes if i remember correctly and keep the inner ring factory, but i am most likely wrong
dozer54321 is offline   Reply With Quote
Old 10-02-2007, 06:26 PM   #13
sunnyniazi
Member#: 136438
RIP: 2004 WRX STi
WRB/G, 322whp/330wtq
Yeah don't do it, it's a waste, horrible for tuning, better off paying a little more for the real thing than cutting corners, I know people that did and regret it.
sunnyniazi is offline   Reply With Quote
Old 10-02-2007, 06:46 PM   #14
hrmax
Member#: 37216
2004 STI
I am using the Perrin modified injectors and haven't had any issues.
hrmax is offline   Reply With Quote
Old 10-02-2007, 06:59 PM   #15
desmo750
Member#: 111256
1992 Legacy Turbo
don't call me white...
It's a waste to buy injectors! (unless of coarse you need 1000cc or bigger) Why pay hundreds of dollars for something you already have and can easily modify
desmo750 is offline   Reply With Quote
Old 10-02-2007, 07:07 PM   #16
hrmax
Member#: 37216
2004 STI
The main issue with doing them yourself is that when they are modified, the discrepancy in flow rates between them can be increased but if you buy a set that has been flow tested and matched you won't have that problem.
Old 10-02-2007, 07:51 PM   #17
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
^^^ True
You realize that is the same link the thread starter gave?
Old 10-02-2007, 09:03 PM   #18
gormonk
Member#: 98960
1978 brat (fo realz)
red
you do realize that most of the guys here in AZ are running modified injectors right? i dont think i've heard of anyone out here having anything go wrong with their modified injectors
gormonk is offline   Reply With Quote
Old 10-03-2007, 01:34 AM   #19
dozer54321
Member#: 116437
i think he meant modding them yourself not the flow tested modded, if he was talking about the Deatschwerks injectors he would be a bumbling idiot who deserves to be put in a home for people with "special" care
ps. anyone know a good place thats hiring?
Old 10-03-2007, 09:29 AM   #20
desmo750
Member#: 111256
1992 Legacy Turbo
^^^ True
Yeah I realized that after I posted
Anyways, you can modify your own injectors and have them flow tested for alot less than buying the Deatschwerks. It just makes good sense if you're on a budget. I wouldn't call it "cutting corners", it's taking advantage of something that will save you a decent amount of money and give you the same results.
Old 10-03-2007, 09:44 AM   #21
hrmax
Member#: 37216
2004 STI
Even if you flow test them you may still have the same problem. What if they flow test as having a 5% difference in flow? You have a set of injectors you can't use. The only way this would work is if you have a few sets you modified and had them all flow tested. Then you could match them up better. You could always recoup your costs of the additional sets by selling them which I have seen quite a few people do.
Old 10-03-2007, 01:46 PM   #22
WgnWheel
Member#: 63605
04 Wrx Wgn TimeAtk
i don't remember the deatschwerks being that expensive? properly modded injectors are a big deal. i've seen results from someone doing it themself and it wasn't pretty. i'm sure there's plenty of others that have done it right, but it's not a chance i'd take.
Old 10-03-2007, 02:28 PM   #23
dozer54321
Member#: 116437
when i got them with a core return 650';s would set you back 220 or so with shipping etc
Old 10-03-2007, 03:17 PM   #24
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
The deatschwerks injectors are not the same as the modified ones in the link. Doing it your self you just dremel off the cap and you are done, there is no way limit fuel flow so I do not know how you would match them up unless you modded a bunch like mentioned above and matched them.
I am not sure how deatschwerks does it but they either keep the existing cap and enlarge the holes or put a new one on.
Old 10-08-2007, 07:51 AM   #25
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
Originally Posted by treefrogaz View Post
+1. 750s in my car right now.
06rexwagon is offline   Reply With Quote
Anyone have the maf scaling values for an Perrin Big MAF. Stock WRX injectors NITROS Open Source Reflashes 1 02-05-2008 06:57 PM
so does anyone have an opinion of a good upgrade from the stock brake pads? Big_Hitter Texas Impreza Club Forum -- TXIC 63 04-23-2004 12:24 PM
Cyberdyne Gauges anyone have an opinion on these? nos Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-16-2004 01:54 PM
Anyone dyno just a pulley? Or have an opinion on them? joe_white Proven Power Bragging 2 12-09-2002 11:03 PM
