Old 10-02-2007, 05:02 PM   #1
Upscale_Automotive
Vendor
Member#: 92276
2004 Subaru WRX STi
WR Blue
Default Upscale Automotive 2004 STi - GT30R, Cobb Engine, much more!
The Upscale Automotive 2004 Subaru Impreza WRX STi
DYNO RESULTS:
406.8whp @ 6745rpm
363wtq @ 4567rpm
Pump Gas - 93 Octane
No Alcohol, Meth, Water, Nitrous, etc.
MOD LIST:
Engine:
-Cobb Stage 1 Tuner Series Block
-Cobb Stage 2 STi Heads
-Cosworth Timing Belt Guide
-Cosworth Subaru WRX STI EJ25 Bore=100mm T=1.mm Head Gasket
-Cosworth Subaru WRX STI EJ25 AVCS Cams
-Cosworth Subaru EJ20/25 Engine 2002-06 Modified Oil Pump
-ARP Head Stud Kit
-APS Tumbler Valve Delete Assemblies
-Cusco Engine & Transmission Mount Set
-Power Enterprise Timing Belt
-Redline Powerpack Synthetic Fluid Kit
-Perrin Lightened Crank Pulley
-NGK One Step Colder Iridium Spark Plugs
-Black Perrin Oil Catch Can
-Red Perrin Coolant Reservoir
-Weapon R Hybrid Coolant/Washer Tank
-PWR High Performance Radiator
-Zerosports Thermostat
Fuel System:
-Power Enterprise 850cc Fuel Injectors
-Perrin Fuel Rails
-Walbro 255 LPH Fuel Pump & Install Kit
Forced Induction, Intake, and Exhaust:
-Perrin Rotated Mount GT3076R .82AR Turbo Kit
-Cobb Tuning SF Intake
-Invidia G200 Titanium Tip Catback Exhaust
-Perrin Equal Length Header
-APS Dual Vent FMIC Blow Off Valve Kit
-Perrin Front Mount Intercooler
-Swain Heat Coated Intercooler Piping
Engine Management and Electronics:
-Cobb Tuning AccessPort V2
-Perrin EBCS Universal Electronic Boost Solenoid
-PLX Devices R-500 Wideband Computer Kit w/EGT
-HKS CAMP CPU
-HKS CAMP Junction Box
-HKS CAMP EGT Sensor and Harness
-HKS CAMP Boost Sensor and Harness
-Optima Red Top Battery
Drivetrain:
-ACT Streetlite Flywheel
-ACT Street Disc Clutch Kit
-Techna-Fit Stainless Steel Clutch Line
-Kartboy Short Shifter and Bushings Combo
Engine Dress:
-Carbign Craft Carbon Fiber Alternator Cover
-Carbign Craft Carbon Fiber Radiator Shroud
-Black Perrin Radiator Hose Kit
-Samco Ancillary Hose Kit
Wheels and Tires:
-17x8 Rota Torque Wheels
-235/40/17 BFGoodrich G-Force T/A KDW(V2) Tires
-McGaurd Splinedrive Lug Nuts
Suspension:
-APR Front Strut Bar
-GT Spec Fender Reinforcement Braces
-H&R Camber Bolts (Rear)
-Tein Electronic Damping Force Controller
-Tein Flex Coilovers
Brakes:
-Power Slot Cryo-Treated Rotors
-Hawk Brake Pads
-Techna-Fit Brake Lines
Exterior:
-APR Carbon Fiber Rear Diffuser
-APR Carbon Fiber GTC-300 Rear Spoiler
-APR Formula GT3 Mirrors
-Carbign Craft Carbon Fiber License Plate
-Chargespeed CF Side Skirts
-Chargespeed Carbon Fiber Rear Caps
-Chargespeed Carbon Fiber Trunk Lid
-OEM 2006 STi Roof Spoiler
-JDM STi Type RA Roof Vent
-Seibon GD Carbon Fiber Front Lip
-Seibon RC Carbon Fiber Hood
-Seibon CW Carbon Fiber Hood Scoop
Interior:
-WRX Rear Seat
-WRX Door Panels
-WRX Floor Mats
-Sparco Monza Seats
-Sparco Harness Bar
-Megan Racing Seatbelt Harnesses
-OEM Carbon Fiber Interior Trim
Audio/Video:
-Pioneer AVIC-N1 Navigation/Vehicle Dynamics
-LCD Custom Mounted in Double-DIN Radio Location
-Pioneer GEX-P10XMT XM Tuner
-Rockford T1 10" Subwoofers
-MB Quart Q Series Component Speakers w/ Tweeters & Crossovers
-Rockford T10001bd Amplifier
-Rockford T8004 Amplifier
-Custom Trunk Enclosure
Upscale Automotive LLC
Your Source for Performance, Reliability, and Style
http://www.upscaleautomotive.com/images/UpscaleBanner468x60-ANIMATE3.gif[/IMG][/url]
http://www.UpscaleAutomotive.com
Upscale_Automotive is offline   Reply With Quote
Old 10-02-2007, 05:33 PM   #2
flycaster
Member#: 60142
2011 WRX
Grey
Right on the money, but what was the boost?
flycaster is offline   Reply With Quote
Old 10-02-2007, 06:12 PM   #3
albie1kanobi
Member#: 101607
06 Subaru STi
nice!
what does a stock sti dyno on that dyno?
albie1kanobi is offline   Reply With Quote
Old 10-02-2007, 08:17 PM   #4
dingobite
Member#: 82391
08 OBP Sti
td06SL2, 20g 299hp 300tq
wonder what idle sounds like on that thing.
dingobite is offline   Reply With Quote
Old 10-02-2007, 09:02 PM   #5
Upscale_Automotive
Vendor
Member#: 92276
2004 Subaru WRX STi
WR Blue
DYNO PLOT KEY:
RED - HORSEPOWER
BLUE - TORQUE
GREEN - PSI
GREY - AFR
Boost hits 24psi at about 5800rpm, but it sticks around about 19-22psi throughout the bulk of the curve. The average boost is 15.4psi.
Old 10-02-2007, 09:08 PM   #6
Jstyles21
Member#: 95454
2008 STI
www.CTSUBIE.com
Great Guy, Great Vender, I remember when he had his sick WRX, then bought his STI. Nice to see you on here.
Great Numbers!!!!!
Justin
CTSUBIE.com
Jstyles21 is offline   Reply With Quote
Old 10-02-2007, 09:08 PM   #7
Upscale_Automotive
Vendor
Member#: 92276
2004 Subaru WRX STi
WR Blue
Originally Posted by albie1kanobi View Post
nice!
Stock STi's generally run about 200 to 230 whp on Mustang Dyno's. There is some variance depending on the specific STi, conditions, operator, etc etc.
Old 10-02-2007, 09:18 PM   #8
Upscale_Automotive
Vendor
Member#: 92276
2004 Subaru WRX STi
WR Blue
We will post videos ASAP. Dyno videos and more.
The cams are definitely noticeable during idle and they are responsible for drawing the power out a few hundred extra RPM's no doubt.
The cams are a pain to compensate for during break-in when trying to keep the car in safe operating parameters. In order to keep all the numbers/readings in the "green" we had to deal with a tough idle and stalling tendencies. Now that the tune is fully completed, everything is broken in, and every detail is buttoned up, the idle is perfect, no stalling, nothing. We couldn't be happier with the way this STi runs. We could have just as easily gone with a GT35R rather than the GT30R, but the drivability and reliability of this STi's setup are through the roof. Everything we want in a 400whp street car.
Thanks for all the friendly comments!
Old 10-02-2007, 09:24 PM   #9
Upscale_Automotive
Vendor
Member#: 92276
2004 Subaru WRX STi
WR Blue
Great Numbers!!!!!
Justin
CTSUBIE.com
Wow, thanks for the compliments Justin.... we could handle a post or two like this over at THIS post LOL. Things are getting rough over there
Let me know if you or your team need anything! We have more lines and stock now than ever!
Old 10-02-2007, 10:44 PM   #10
flycaster
Member#: 60142
2011 WRX
Grey
Originally Posted by Upscale_Automotive View Post
DYNO PLOT KEY:
Thanks. No way could I read that image. Is the boost waiver intentional, or just a trait of that EBC? Just curious, since you usually see table-top flat boost curves with that turbo using a D-Tec or AVC-r.
Old 10-02-2007, 11:20 PM   #11
El Gato
Member#: 110648
Chapter/Region: PRSIC
2005 Hydramist 35R82
93oct 479whp 456tq
Maybe the list should be modified to what this car DOES NOT have?
DYNO RESULTS:
406.8whp @ 6745rpm
363wtq @ 4567rpm
MOD LIST:
Engine:
-ARP Head Stud Kit
Fuel System:
-Perrin Fuel Rails
-HKS CAMP CPU
Drivetrain:
Engine Dress:
Wheels and Tires:
Suspension:
Brakes:
-Hawk Brake Pads
Exterior:
Interior:
-WRX Rear Seat
-WRX Door Panels
-WRX Floor Mats
-Sparco Monza Seats
-Sparco Harness Bar
Audio/Video:
El Gato is offline   Reply With Quote
Old 10-03-2007, 01:42 AM   #12
Upscale_Automotive
Vendor
Member#: 92276
2004 Subaru WRX STi
WR Blue
I am not exactly sure why that waiver is there exactly. It may be the EBC, but it is tuned for regardless. The idea of a DTEC or AVC-R alternative is tempting however.
Old 10-03-2007, 03:54 AM   #13
remowgn
Member#: 41149
09 FXT
SSM
Nice results, but that signature is freaking annoying. The lack of signatures is one of the things I like about NASIOC.
remowgn is offline   Reply With Quote
Old 10-03-2007, 09:18 AM   #14
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Yes, lose the sig unless you are in the vendor forum.
Can we get pic of this beast?
wcbjr is offline   Reply With Quote
Old 10-03-2007, 02:30 PM   #15
redobs
Member#: 1501
2009 WRX wagon
Dark grey
Upscale: We do not allows signatures here. Please stop posting it.
redobs is offline   Reply With Quote
Old 10-03-2007, 03:01 PM   #16
Upscale_Automotive
Vendor
Member#: 92276
2004 Subaru WRX STi
WR Blue
I apologize about the signature, I was told by Nick that it was okay but I had to post it with every post individually since signatures were not enabled.
Is it just the picture that is a problem or the entire signature?
I will be sure to keep the signature limited to the vendor forum only from now on.
Old 10-03-2007, 03:03 PM   #17
Upscale_Automotive
Vendor
Member#: 92276
2004 Subaru WRX STi
WR Blue
Our Gallery at http://www.UpscaleAutomotive.com pictures of this car and lots more.
This thread is nothing but pics of this car: http://forums.nasioc.com/forums/show....php?t=1357829
Old 10-03-2007, 03:10 PM   #18
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Quick off-beat question -- how well do the APR mirrors hold up to high speeds? Do they constantly need re-adjustment at the ball-joints?
jblaine is offline   Reply With Quote
Old 10-03-2007, 03:13 PM   #19
remowgn
Member#: 41149
09 FXT
SSM
It ends up getting VERY redundant when it is included with every post in a thread, and the animated banner was a bit much. A url, phone number, etc at the bottom of the first post in the thread is pretty much the norm around here.
Old 10-03-2007, 03:29 PM   #20
Upscale_Automotive
Vendor
Member#: 92276
2004 Subaru WRX STi
WR Blue
Awesome, I really appreciate the advice. We will keep it simple like that from now on.
Thanks!
Old 10-03-2007, 03:35 PM   #21
Upscale_Automotive
Vendor
Member#: 92276
2004 Subaru WRX STi
WR Blue
The APR side mirrors are actually extremely stable. The APR side mirrors are more stable than the OEM rear view mirror (in-cabin). When the rear view mirror is vibrating too badly to see the reflected image clearly, you can look at the APR mirrors and they are stable and clear as day. There is no flapping, no rotating, no movement at all. This depends on how tight you have them tightened of course, but even as they are on our STi we can still manually adjust them by hand without using tools and they remain stable under high speeds and vibrations. The mirror housing features a rubber ring around the holes that the mounting post goes through, if that makes sense, allowing them to remain in position better as well.
2004 sti 4 sale gt35r much much more petest1 Private Vehicle 'For Sale' Classifieds 0 06-15-2008 09:25 AM
Upscale Automotive 2004 STi - GT30R, Cobb Engine, much more! Upscale_Automotive Member's Car Gallery 47 02-25-2008 01:06 PM
UR Intake/Downpipe, Aquamist 1s, USDM STi Heads, Defi, and much more ShaggyGT Private 'For Sale' Classifieds 119 06-19-2006 04:09 PM
Gauging Interest: Invidia G200, Helix Catted DP, Cobb AP, MUCH MORE all from 2004 STi Padge MAIC Private Classifieds 2 02-21-2006 09:57 PM
Another Euro shipment arrived: STi floormats and so much more.... CC-B Interior/Dressup/Audio & Security 14 06-03-2004 04:28 AM
