Old 11-12-2007, 04:11 PM   #51
AbACUZ
Member#: 101898
1905 NINETWO EX AIRO
Prodriv.Hotchkis.Stromng.
bump for more info and links added !!!
please can some one post info on the STI adjustable struts ???
Thank you
AbACUZ is offline   Reply With Quote
Old 12-17-2007, 05:14 PM   #52
RaceComp Engineering
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Ohlins fixed perch struts
Part #'s
02-07 WRX and 04 STi:
Front: SUS 5E00
Rear: SUS 6E00
05-07 STi:
Front: SUS 5F00
Rear: SUS 6F00
They can be had for under $2000 most places.
RaceComp Engineering is offline   Reply With Quote
Old 12-18-2007, 01:24 AM   #53
revnseven
Member#: 72304
2002 02 WRX Wagon
11 VW Jetta TDI 6Speed
Well as of now I have Tokico D specs with Tein H tech springs and is a decent setup for daily driving. It did seam to work ok the one time I autox'd it this year. I have RCE Wagon springs on the way to go on the struts. I've heard alot of good about this setup.
Thanks
Brian
revnseven is offline   Reply With Quote
Old 01-17-2008, 02:31 PM   #54
Steve Nastoff
Member#: 52052
03 Subaru WRX
Midnight Black Pearl
I run H&R springs with Koni strut inserts and Group N top mounts. My car is mostly street driven, though with much spirit and I feel that this is a very good combination. I would highly recomend this combination. And change your steering rack bushings to Whiteline urethane.
Steve Nastoff is offline   Reply With Quote
Old 02-13-2008, 08:43 PM   #55
BIGSKYWRX
Member#: 7958
09 GH B+
you can part #'s here for the STi bits
http://www.subaru-sti.co.jp/parts.html
Old 02-14-2008, 11:21 AM   #56
AbACUZ
Member#: 101898
thank you for that link BigSky! for some reason my web searches could not find this site , also i would post more info regarding all the struts but my japanese is a little rusty , so any niponeese out there wana translate a couple of those things so i can post part number would be great
Old 03-28-2008, 11:07 PM   #57
BIGSKYWRX
Member#: 7958
09 GH B+
something you might possibly consider editing- 4 way, 2 way, etc when talking shocks (or struts ) usually refers to the number of adjusters (rebound, compression- high/low speed), not the "clicks" or levels of adj
also I'm sure this apparent to most folks but a 4 click adj shock/strut could easily provide more range of adjustment than say a 64 click one- the range of adjustment can only be determined by a dynograph- now if the two above examples happened to provide the same range then obviously the 64 click one provides more refinement in adjustment
someday nasioc will have a dynograph (and spring tester) and we can end the speculation on a lot of these dampers
Old 04-03-2008, 12:49 PM   #58
--e
Member#: 120686
06 Saabaru
Nice thread, Aba. I appreciate the work you put into this one, and (believe it or not) it's more intelligible than a lot of your stuff I've read.
I've heard complaints of compression variance in shocks coming from Koni (and, presumably, any other manufacturer). Is it worth trying to buy matched sets? Are dynos common for these things? Should I find more important things to worry about?
Thanks, yo
--e
--e is offline   Reply With Quote
Old 04-03-2008, 02:06 PM   #59
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Koni insists that they do dyno everything before it leaves. If you call and ask they will probably tell you the same thing but if you are picky I bet you could call Lee Grimes and ask specifically for them. With Dennis Grant's article out there, they probably get this request a lot more now.
IMHO there are more important things to worry about
Old 04-03-2008, 02:52 PM   #60
AbACUZ
Member#: 101898
Thumbs up
Thanks, yo
--e
Thank you very much, Believe it or not this is the kind of research I like to do before making changes to my car, so Why not post it here and help everyone else thinking about doing it also, or for people just wanting to learn.
The fact that this is more legible than more other threads or comments is because it just sticks to the facts, and its a plain outline of specifications.
When writeing comments or just plain talking, my english limitations show up much more. < me .. hehehhee
regarding the variance in shocks, the kind of variances found (unless the is a defect) they are very minor and not affect the type of driving that we do.
If you are planing on having a track only car , then i would invest some more time and money dynoing the springs and shocks and make sure the valving is correct, otherwise IMHO this would be overkill for an everyday car.
once again thank you for your comments, AbA.
Old 11-19-2008, 03:58 PM   #61
AbACUZ
Member#: 101898
Bump for the peeps ! dont be afraid to add more data !
Im sure there is something new out there, 08 / 09 info ??
Old 12-30-2008, 10:49 AM   #62
1stockwrx
Member#: 162365
06 RSX Type S
BUMP! so i can read this later today
<---- at work
1stockwrx is offline   Reply With Quote
Old 02-26-2009, 09:13 PM   #63
AbACUZ
Member#: 101898
Uppers!!!!!
any new stuff for the 08+ ????
Old 03-04-2009, 04:30 PM   #64
Butt Dyno
Member#: 17301
is the "dark side"
Removed bumps, changed thread title (made it a little more open ended though)
Thanks again for maintaining!
Old 03-04-2009, 05:13 PM   #65
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
According to RCE, the Ohlins FPS have 25 clicks of adjustment, not 23 as the page 1 states.
My 06 WRX wagon currently has groupN tops all around, SPT wagon pink springs (USDM), and Ohlins FPS and I'm currently set to -12 f, -14 r FFH.
chimchimm5 is offline   Reply With Quote
Old 06-16-2009, 08:02 PM   #66
AbACUZ
Member#: 101898
keeping this baby alive again.. any new info on the 08's and now 09's?
thank you chim chim , updated info.
Old 10-19-2009, 06:02 PM   #67
AbACUZ
Member#: 101898
Again any new info on the 08s and 09s ?
Old 10-19-2009, 07:48 PM   #68
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
I don't think the Ohlins FPS have "Sportline" in their name, do they? I thought Sportline refers to the coilovers.
Old 10-19-2009, 07:57 PM   #69
jakedown
Member#: 111691
2006 wrx stage 2
monster tdo4,...aspen
tokico dspecs with jdm pinks...i love them !!!
jakedown is offline   Reply With Quote
Old 10-20-2009, 08:47 AM   #70
subiesoho
Member#: 164241
2007 wrx wagon
pearl white
just did them on my 07 wagon sti wagon pinks, with Group N tophats. I totally agree right setup for me.
I just need to know what camber I should be running front and rear for dd. Wagon with sedan struts, 22mm whiteline f&r swb and whiteline heavy duty endlinks.
subiesoho is offline   Reply With Quote
Old 10-20-2009, 11:15 PM   #71
romanlynch
Member#: 126684
02 wrx
PLATINUM silver baby
im running the dspecs with ground control coil over sleeves. spring rates are 325F/250R, DD i run the front struts at 3 turns from full stiff (TFFS) and the rears at 4.5 tffs. for track i was running them at 1 tffs F and 1.5 (or 2 i forget) tffs R
romanlynch is offline   Reply With Quote
Old 08-31-2010, 09:08 PM   #72
AbACUZ
Member#: 101898
Updog.
Old 07-04-2012, 03:27 PM   #73
subiewhore
Member#: 138786
05 obp wrs ^.-
rally time
Came across this website while doing some research. It lists part numbers and complete information on the sti pink struts for the legacy, impreza, or forester.
http://www.rhdjapan.com/pinpoint_res...il=All&x=0&y=0
Also, there are pink sti adjustable struts for the 04 sti.
subiewhore is offline   Reply With Quote
Old 07-27-2012, 05:07 PM   #74
AbACUZ
Member#: 101898
wow , bumped after many years ... glad the thread is still helping people
who has the info on the new stuff ???
Old 08-26-2012, 08:33 AM   #75
yerrow
Member#: 59094
04/7 wagon & fozzie
wrb/blk
anyone find the part numbers for d-specs so we can cross reference the tokico blow sale?
yerrow is offline   Reply With Quote
KONI sport (yellow)/KYB/Tokico D-SPEC adjustable shocks w/Eibach Pro-kit springs GDAryder Brakes, Steering & Suspension 8 10-30-2009 02:02 PM
wtt 06 sti bcracing coilovers for sti adjustable struts or ohlins SAMSNEED Suspension/Brakes/Handling 2 09-04-2008 05:50 PM
Tokico vs KYB and Koni? Rich10 Motorsports 73 12-19-2006 04:38 PM
Are the 04 sti struts better than kyb? or koni? AK*WRX*2004 Brakes, Steering & Suspension 17 09-27-2005 07:42 PM
What's abetter strut? new KYB AGX/Koni or 04 STIs?? USA1 Brakes, Steering & Suspension 1 05-11-2005 07:20 PM
