Old 10-02-2007, 08:15 PM   #1
bdoss123
Member#: 19958
Default 1997 GT - Steadily descreasing MPG , where to start?
Car has 129k on it.
Oil, Filter, and Air Filter changed about 1000 miles ago.
I read some posts after searching that indicated to check the fuel filter. What are other possible causes?
bdoss123 is offline   Reply With Quote
Old 10-02-2007, 08:21 PM   #2
illegal2.2
Member#: 58329
2005 Baja Turbo 5mt
Garnet Red Pearl
season change is also an issue. maybe try spark plugs, wires, pcv valve, etc..
choung
illegal2.2 is offline   Reply With Quote
Old 10-02-2007, 09:30 PM   #3
bdoss123
Member#: 19958
How many miles should I expect out of the high dollar plugs? They were replaced at ~100k.
- BD
Old 10-02-2007, 09:50 PM   #4
illegal2.2
Member#: 58329
2005 Baja Turbo 5mt
Garnet Red Pearl
what kind was replaced at 100k? was it the stock platium ones?
choung
Old 10-03-2007, 12:16 AM   #5
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
choung
copper*
fibuz is offline   Reply With Quote
Old 10-03-2007, 04:18 AM   #6
BlockerImp
Member#: 66480
2001 OBS-T
coil packs, spark plugs are a great place to start
BlockerImp is offline   Reply With Quote
Old 10-03-2007, 09:21 PM   #7
aross
Member#: 831
11 Blurple WRX
03 BH MBP
Front O2 Sensor.
aross is offline   Reply With Quote
Old 10-04-2007, 01:31 AM   #8
coathegreatone
Member#: 160867
2010 Impreza 2.5i
Spark Silver
definintely check the spark plugs and all the sensors
coathegreatone is offline   Reply With Quote
Old 10-04-2007, 05:40 AM   #9
GrayT
Member#: 160612
2008 Legacy
Satin White
Agreed on the fuel filter... sounds like it got slightly clogged and is only getting worse.
GrayT is offline   Reply With Quote
Old 10-04-2007, 02:31 PM   #10
linsavy
Member#: 11620
1997 GF4-STiV3 clone
I swapped the front o2 sensor even though there was no code and picked up 6mpg on the very next tank.
linsavy is offline   Reply With Quote
Old 10-04-2007, 10:10 PM   #11
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
Another remote possibility MIGHT be the Thermostat.
If it is stuck OPEN, it will take significantly longer for the motor to reach full operating temperature. This could actually prove even more significant in a cooler climate.
Also if you do a lot of "short" trips (say 5-10 miles or less) where the motor maybe isn't even reaching full operating temperature, the car will be running a significantly richer fuel mixture, which will significantly reduce fuel millage, and reduce the service life of both the oxygen sensor and the catalitic converter.
Jonathan is offline   Reply With Quote
Old 10-04-2007, 10:12 PM   #12
Jonathan
Member#: 4021
1999 Legacy GT Ltd
NGK spark plugs are a good idea.
Denso, Bosch, and Champion are perhaps not a very good ideas.
Old 10-05-2007, 09:30 AM   #13
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
- NGK copper plugs (I like V-power).
- New plug wires (I prefer OE)
- Fuel filter (I went with Purolator)
- PCV valve (I went with Purolator)
That's where I'd start. Then you could look at O2 sensors if you want, just get any cheap wire in sensor no need to spend high $$$ there.
The coil packs have had issues over the years on those engines with cracking, but it's usually evident by a miss at idle, so if your idle is fine... I'd be your pack is fine.
Any other issues w/ the car? Heres to hoping you don't have to do head gaskets anytime soon. Mine went at 135k. Even if they're leaking only enough to pressurize the coolant system, it can adversely affect your mileage. I was getting 22 mpg on mixed driving when the HG's were not in top shape. Now with a freshed top end and mild porting on the heads, but nothing else changed (stock exhaust/sensors) I'm getting 25-26 mpg mixed driving. which isn't bad for the EJ25D DOHC motors from what I've seen.
Jon
omahasubaru is offline   Reply With Quote
Old 10-05-2007, 10:41 AM   #14
illegal2.2
Member#: 58329
2005 Baja Turbo 5mt
Garnet Red Pearl
^ good info, as i can recall, i gotten lower mileage before my HG(headgasket) change also. bumped up a good 3-5mpg along with opening your exhaust and intake system like header back helped me 2-4mpg more.
choung
Old 10-06-2007, 12:57 AM   #15
birukun
Member#: 52801
1999 Legacy Wagon L
Green 30th Anniv.
I am at 122k, car started *drinking* gas, and now I have a CEL that says 'Bad Knock Sensor'.
Maybe yours is on its way out too.
Good luck-
birukun is offline   Reply With Quote
Old 10-06-2007, 08:19 PM   #16
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Originally Posted by bdoss123 View Post
Car has 129k on it.
What was your mileage before, and what are you getting now? Same type of driving all along I assume? Where are you located? As Chuong said, it could just be a change in the gas formulation as we start heading towards winter. (With that said, I don't know when areas shift over.)
What does "high dollar plugs" mean? Where they platinum plugs or copper plugs? I'm guessing platinum if they were "high dollar", which means they should be fine for a lot more miles on the car.
Originally Posted by aross View Post
Front O2 Sensor.
Probably the most likely culprit in my mind, although new plug wires would be the first thing I'd take care of. In almost 191k miles of very hard use I've never had a coil pack go bad, so I'd be kinda surprised if that's the problem.
I'm not sure I follow your logic here. A clogged filter would adversely effect performance if it got really bad, but I don't see how it would cause mileage to drop.
That could be, although as you said it's a remote possibility.
Good lord, what mileage are you getting now - 40mpg?? 5-9mpg better should be a good 50% improvement, which would indicate that your car was either in horrible shape before, or you're getting phenomenal mileage now!
Another one that I don't really see the connection. I've had an over-active knock sensor before, which noticeably impacted performance and even day-to-day driveability, but mileage wasn't affected at all.
Pat Olsen
Patrick Olsen is online now   Reply With Quote
Old 10-13-2007, 07:30 AM   #17
bdoss123
Member#: 19958
Wow, thanks for all the replies guys. I didn't check the thread until this morning.
Yes platinum plugs were installed around 100k, so I would hope they are fine.
Driving style/area has been the same, so I wouldn't think that would have changed my mileage. I'm in NC, bad mileage started about a month ago when the weather was still warm.
I used to get 23-25MPG and am now getting more like 19-22. It's only bothering me because my 1993 F250 Diesel is getting as good if not better mileage than the Sube.
Any way to tell if the HG's are going? I sure hope not, as this car probably isn't worth a whole lot more than that repair, lol.
Again, thanks for all of the replies.
- BD
Old 10-14-2007, 09:43 PM   #18
calgearhead
Member#: 133745
1998 Lifted Outback
Green + Dirt
Front O2 Sensor.
Wouldn't it throw a CEL if going out? My mileage has dropped significantly (25 miles + to the tank) since my 800 mile journey on the highway, and could have sworn I had EVERYTHING above mentioned replaced LESS THAN 10k miles ago.
calgearhead is offline   Reply With Quote
Old 10-14-2007, 11:45 PM   #19
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
I actually had an O2 sensor die on me (verified by OBD2 datalogging) with no CEL.
Old 10-15-2007, 03:26 PM   #20
emyselfandi
Member#: 83701
Good luck-
funny mine did the same at 125K... cheap and easy problem to fix though. Good threat. I've had reduced mileage since hitting 165K. I think it's b/c im in stop and go traffic and not rollin on the highway (moved into the city). The front 02 sensor sounds like good maint. though.
emyselfandi is offline   Reply With Quote
Old 10-16-2007, 06:18 PM   #21
Radio Flyer
Member#: 374
'98 2.5 GT Wagon
Rio Red
I recently had a drop in mileage to 18 mpg from the usual 21. When I checked the air filter, noticed that there was a small hose disconnected from somewhere. After poking around for a bit, i found what looked to be an empty barb for a small hose (attached to a doohickey [technical term] on the strut tower and attached the hose to that.
Next tank, mileage was back to normal. The hose was completely hidden from view until I had lifted the filter cover.
Another possibility could be the gas. I had been buying gas from Sam's Club for years. And then my economy really started to tank. At 15mpg, I was starting to seriously consider selling my car. Following a friend's suggestion, I filled up with gas from Diamond Shamrock. Instantly, I was back to 21 mpg. Saving a nickel per gallon was costing me 4 gallons...
Just my 2 cents...
- Eric
Lil' Red '98 2.5 GT Wagon - Pics
Radio Flyer is offline   Reply With Quote
Rooky to Mods Needs to Know Where to Start? Blue Meanie Newbies & FAQs 40 11-10-2011 12:29 PM
So I'm ready to start my own business, but have no idea where to start. Protege Menace Off-Topic 27 07-30-2008 01:44 PM
I want to get started racing! Where to start? wayne_rx Motorsports 27 12-23-2004 03:00 AM
I want to build a rally car... but I don't know where to start. majglow Motorsports 25 04-24-2002 12:55 PM
Where to start? 2001 Subaru Legacy GT Chris Popovich Newbies & FAQs 4 01-17-2002 05:49 PM
