Old 10-03-2007, 04:35 AM   #1
Wilson_
Member#: 122118
2006 OBS
Steel Grey
Default will 04-07 wrx suspention fit on a 06 obs?
i want to lower my 06 obs and i found this post
http://forums.nasioc.com/forums/show...37&postcount=3
going by this post, it is saying i can bolt on 04-07 suspension, correct?
what about the sti will that work to??
i just want to be sure i buy the right parts
TIA
Bobby
Wilson_ is offline   Reply With Quote
Old 10-03-2007, 08:40 AM   #2
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
If you mean struts and springs then
04-07 WRX yes
04 STI yes
05+ STI no
In all cases using sedan suspension on any Impreza wagon including your OBS will result in reduced amounts of negative camber and will tend to make the rear sit low.
UkNuck is offline   Reply With Quote
Old 10-03-2007, 04:19 PM   #3
Wilson_
Member#: 122118
2006 OBS
Steel Grey
thank you for the explanation, now i can spend some money.
Old 10-03-2007, 11:23 PM   #4
iownaspec
Member#: 34154
1/2 jew crew
do not do this. i am fixing this mistake right now. make sure you get wagon springs. my camber was all over the place and the rear sat a good 2-3" lower than the front. make sure you get wagon springs. this was on an 05 obs with 04 sti springs.
iownaspec is offline   Reply With Quote
Old 10-04-2007, 03:17 AM   #5
Wilson_
Member#: 122118
2006 OBS
Steel Grey
ok thanks for the info, i will look for a wrx wagon set up
Old 10-04-2007, 12:40 PM   #6
Tire Rack Moderator
Member#: 1215
ext. 4362
oops wrong forum ...
Will 04-07 Stock Brembos Fit On My 09 2.5i in any way???? [FIL] Brakes, Steering & Suspension 16 03-24-2014 06:27 AM
Will WRX wheels fit on an 06 Legacy 2.5i sciff5 Tire & Wheel 4 12-07-2008 01:45 AM
Will an 04-07 STI catback fit on 02 wrx? NavyBlueSubaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-17-2008 07:18 PM
Will 17x8" Volk GT-N's fit on a 06 WRX? H22aDC2 Tire & Wheel 2 02-04-2007 12:31 PM
Will a 04 sti rear bumper fit on a 06 wrx? Sypher Interior & Exterior Modification 4 01-21-2007 05:08 PM
