Old 10-03-2007, 12:59 PM   #1
islichlorgan
Member#: 101431
2005 sti
crystal grey
Question got some fuel in my oil
hello guys
i got a build 2.5 sti engine , and my oil smell a lot like gas and my motor take oil like a 2 stroke engine , the engine as about 5000 km on it and it runs like a charm, could it be that its running so rich that gas gets into the oil and then , oil get so liquid that it burn thru the cylinders?????
thanks for your help
islichlorgan is offline   Reply With Quote
Old 10-03-2007, 01:26 PM   #2
bluesubie
Member#: 767
04 FXT
Yeah, probably. Our cars run rich stock. Try a used oil analysis. The fuel is really killing your oil.
Blackstone Labs , although their fuel report is less accurate than Dyson .
And an oil that Terry Dyson recently had an oil company "brew" just for fuel dilution in an Audi RS4 is Renewable Lubricants Bio-Synthetic Super High Performance SAE 5W40 HD .
Lots of info and debate about it on bobistheoilguy.com.
Whatever oil you use, make sure that it can withstand fuel dilution without completely thinning out and that you change it regularly.
Lube Control LC20 is also good for fuel dilution.
-Dennis
Old 10-03-2007, 02:44 PM   #3
islichlorgan
Member#: 101431
2005 sti
crystal grey
thanks , maybe just the fact of getting a new tune could help that too.
Old 10-03-2007, 03:25 PM   #4
dmross
Member#: 2818
2000 2.5RS
Check your PCV system too.
dmross is offline   Reply With Quote
Old 10-03-2007, 05:03 PM   #5
islichlorgan
Member#: 101431
2005 sti
crystal grey
could you explain me ,how could the pcv system affect that much the fact that the oil smells gaz
Old 10-03-2007, 05:07 PM   #6
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
thats why on a new motor during break in you should change your oil every 400 or 500 miles, b/c running rich will lead to fuel and oil mixture...not a big problem and make sure to change your oil right before your tune too
blowbyu24 is offline   Reply With Quote
Old 10-03-2007, 05:39 PM   #7
islichlorgan
Member#: 101431
2005 sti
crystal grey
the only thing that s bogging me , is when i start the car it spits out what look like oil and gas or whatever in my driveway , but that s only on start up
Old 10-06-2007, 12:59 AM   #8
charliew
Member#: 125304
Default gas in oil
I'm surprised your not telling us you blew the muffler off your car if it's burning that much gassy oil. Your motor won't live long on diluted oil.
Charlie
charliew is offline   Reply With Quote
Old 10-06-2007, 02:33 AM   #9
flycaster
Member#: 60142
2011 WRX
Grey
Run an oil analysis - most oil with a bunch of miles smells like it has "fuel" in it when most times it really doesn't - repeatedly cooked oil has far different smell than fresh oil. An analysis is the only way to be sure - it'll cost you $20. Just do it.
Condensation and rich-idle start. Totally normal.
flycaster is offline   Reply With Quote
Old 10-06-2007, 11:32 AM   #10
dmross
Member#: 2818
2000 2.5RS
If the PCV system is blocked up you can get oil contamination from blowby over time, more so on a motor with forged pistons and loose tolerances that's running rich.
Fuel in my oil... CHILAX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 07-21-2009 04:39 PM
got bored, snapped some pics in my lot kyle.barner Member's Car Gallery 8 05-03-2009 09:14 PM
Very poor fuel economy and gas in my oil pan phibs Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 11-26-2007 10:24 PM
I got some thieves in my neighborhood. Drink Off-Topic 33 07-02-2007 03:41 AM
I think I've got some fuel problems or ECU is screwed up. Maybe a bad sensor too(MAF) GregUnd Texas Impreza Club Forum -- TXIC 22 04-03-2003 01:23 PM
