Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2016
South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 10-03-2007, 05:07 AM   #1
C-grunt
Member#: 152713
2013 Tundra 4x4 TRD
Default Reverse gear hard to engage.
Sometimes my car does not want to go into reverse. It has A LOT of resistance at the gate. If I put it back into neutral and try again a couple times it will go right in. Am I doing something wrong or what?
C-grunt is offline   Reply With Quote
Old 10-03-2007, 05:23 AM   #2
subielvr_13
Member#: 142419
04 STI
JBP
mine does the same thing sometimes. i have been told that it might do that and that there shouldnt be anything to worry about.
subielvr_13 is offline   Reply With Quote
Old 10-03-2007, 05:31 AM   #3
wagonmasta
Member#: 52880
GGA Rev.D
reverse has a lack of synchro
wagonmasta is offline   Reply With Quote
Old 10-03-2007, 11:55 AM   #4
r0bman
Member#: 87015
Double clutch. Clutch in, put it in neutral, clutch out, clutch in, put it in reverse. As Wamper said, synchroless.
Sometimes it also helps to slip into second first, then reverse (keep the clutch in the whole time) to line up the gears.
I learned how to drive stick on a '69 GTO, so double-clutching comes natural to me
r0bman is offline   Reply With Quote
Old 10-03-2007, 12:26 PM   #5
gormonk
Member#: 98960
1978 brat (fo realz)
red
welome to subarus dude. just like above say, put in another gear first then put it in reverse.
gormonk is offline   Reply With Quote
Old 10-03-2007, 12:40 PM   #6
jvcjbl
Member#: 109112
2010 GRB STI
Originally Posted by r0bman View Post
69
69 bah.... tell them 68... blow me and I owe you one.
jvcjbl is offline   Reply With Quote
Old 10-03-2007, 12:51 PM   #7
Evil_STI
Member#: 106521
I am an ancient of
chaos. \\ t3hclap.com
OP: I had that problem as well...Alot of people get it.
Evil_STI is offline   Reply With Quote
Old 10-03-2007, 02:22 PM   #8
Crawdads
Member#: 30907
SWP GDB-G
release and then re-press the the clutch pedal
Crawdads is offline   Reply With Quote
Old 10-03-2007, 02:54 PM   #9
NO PULSE
Member#: 110733
...It's what makes a subaru, a subaru.
NO PULSE is offline   Reply With Quote
Old 10-03-2007, 03:09 PM   #10
SURPRISE_TR
Member#: 109667
2006 WRX SOUTH SIDE
REPRESENT!!
i go to second then try reverse again it usualy works...or pull forward just a **** hair and go into reverse..it's the same for all subies to have issues going into reverse though
SURPRISE_TR is offline   Reply With Quote
Old 10-03-2007, 03:16 PM   #11
intercoolerontop
Member#: 72148
2010 Ford Raptor
RAWR
go to third gear then reverse thats what works for my car.
intercoolerontop is offline   Reply With Quote
Old 10-03-2007, 05:41 PM   #12
wrxkid85
Member#: 108452
2005 Impreza WRX
Hahaha, its kinda funny. Cause sometime when it does it you're around a crowd of people. And when they hear ya clankin on reverse you get a lot of stairs.
Everyones advices is good advice. Just find what works for ya.
wrxkid85 is offline   Reply With Quote
Old 10-03-2007, 07:04 PM   #13
enigma94
Member#: 143254
2007 STi
UGM
I have the habit of going into second then reverse no matter what car i'm in, never had any problems.
enigma94 is offline   Reply With Quote
Old 10-03-2007, 07:10 PM   #14
wagonmasta
Member#: 52880
GGA Rev.D
the other thing i've found that works......
instead of bringing it straight back.... go in a semi-circular motion.....
does that make sense?
Old 10-03-2007, 07:28 PM   #15
r0bman
Member#: 87015
No.
EVERYONE. Just. Double. Clutch. It works every time.
Old 10-03-2007, 07:37 PM   #16
wagonmasta
Member#: 52880
GGA Rev.D
i do double clutch....
but also slide the selector in that way.... eh.... it makes sense to me... prob to you too if you saw it
Old 10-03-2007, 11:40 PM   #17
BugeyePB Rex
Member#: 138915
2003 WRB WRX Vf48
Tuned @ FAT by Snail Perf
Ditto.... and ditto. I'm with robman.
BugeyePB Rex is offline   Reply With Quote
Old 10-04-2007, 01:46 AM   #18
kos
Member#: 118334
2005 AW RS + 2006
Time Attack WRX
1 - R or 3 - R for me. never have had a problem.
and yall should be granny shiftin stead of double clutchin
kos is offline   Reply With Quote
Old 10-04-2007, 02:22 AM   #19
Crawdads
Member#: 30907
SWP GDB-G
guys...there is no special secret move required with the shifter.
If the car will not shift into reverse, LET OFF THE CLUTCH and then press it again, it will fall right into reverse.
Old 10-04-2007, 03:18 AM   #20
tsunamitc
Member#: 121583
2003 WRX
Sonic Yellow
^^ seriously... everythign on your car is fine man... must have just gotten the car tho, if so welcome
tsunamitc is offline   Reply With Quote
Old 10-04-2007, 08:01 PM   #21
superblkwrx
Member#: 129395
2006 OBPWRX VF39 E85
333WHP 385WTQ 21PSI SD
This is like this on ANY Manual Car. I don't care what make it is. But with Subaru it just happens alittle more often. Like they all said you just have to ge the gears lined up. Your sitting still so there is nothing to make the gears lined up. Even if you did have a syncro in first it would do nothing.
superblkwrx is offline   Reply With Quote
Old 10-05-2007, 11:42 AM   #22
racingfish
Member#: 60976
1969 LGT
FATURBO
dang u guys have reverse? i need ta get me one of those....
racingfish is offline   Reply With Quote
all gears are hard to engage huey1133 Transmission (AT/MT) & Driveline 11 07-29-2013 01:21 AM
help 1st gear sticking/hard to engage as well Rod702 Transmission (AT/MT) & Driveline 26 01-10-2010 03:35 PM
1st and Reverse hard to engage mattmx525 Transmission (AT/MT) & Driveline 2 12-15-2007 09:27 PM
Hard to Engage 1st and Reverse rich728 Transmission (AT/MT) & Driveline 11 04-01-2006 12:16 PM
Reserve is hard to engage 3 out of 5 times... Is this normal? MrP0nch0 Technical Forum Archive 23 08-29-2000 06:28 PM
