Old 10-03-2007, 05:47 PM   #1
platinumstar17
Member#: 159756
1998 wrx sti
white [email protected]
Default jdm ver sti with usdm block
i am currently workin on my version 4 sti i am putting the usdm sti block on it and doin up the internals with forged pisonts and rods and so on. what i would like to know what is a good turbo use with the ej20sti head and usdm sti block.. the car has the vf24 turbo stock on it which is only good for about 18psi boost.. i would like to know what will be a good turbo to use with this setup i want a turbo that has god drivability and spools very quick and can probaly get me into the 12 second or higher range. i was lookin at the vf34 and pe1818 what do you think of these turbos and any help will be appreciated.
thanks
p.s. whats the max boost that the vf34 can run?
platinumstar17 is offline   Reply With Quote
Old 10-03-2007, 06:10 PM   #2
ovedrivex
Member#: 116774
1997 Project GC8
if i remember right vf34 has a 25psi max but may be wrong. the vf 34 is a good turbo spools at about 3500rpm. has good midrange so its a good track turbo also good daily drive turbo.
-also vf34 can support 350awhp so that can put you in the high 11's to low 12's depending on your car setup.
ovedrivex is offline   Reply With Quote
Old 10-04-2007, 12:50 PM   #3
rustyzipper
Member#: 79175
2004 FXT
Red
Realistically , my 34 starts blowing hot hair around ~18-19 PSI I think 25 is a bit high. Race gas and maybe 21-22 is possible with some modifications and MBC, with some crazing timing could get you those numbers. IMHO
rustyzipper is offline   Reply With Quote
Bugeye on JDM Ver 8's with Pinks WhiteWRX2002 Member's Car Gallery 26 04-11-2006 11:05 PM
JDM Ver 7 Vs. USDM STi cams Surb00 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-27-2004 03:46 PM
Do JDM seatbelts work with USDM cars? redobs Interior & Exterior Modification 3 05-20-2004 02:16 PM
What fuel pump for jdm ver. 8 with mods? serious Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-21-2004 01:55 AM
JDM Ver.7 harnessfor USDM WRX to RS swap..?? Boost4U Subaru Conversions 3 11-02-2003 06:29 PM
