Old 10-04-2007, 10:48 PM   #1
piratekiller
Member#: 128262
2002 WRX wagon
Default tranny wont budge
I am try to remove my motor from my 02 wrx. I have removed all of the tranny bolts but the sob wont budge!! I've got a gap the thickness of a hacksaw blade between the top of the tranny and block but that is it.
Any help would be greatly appreciated.
piratekiller is offline   Reply With Quote
Old 10-04-2007, 10:55 PM   #2
nc25rs
Member#: 114134
00 EJ20swap-2.5RS
STM
there is a plug on the side of the trans next to the hole that the clutch fork goes into... it takes a allen socket to get it out... there is a "cluch pivot rod" that the clutch fork rides on inside there. you have to thread a bolt into it and use a pair of pliars to jerk it out.
sorry thats a crappy write up and sounds very getto but thats how u do it lol.
nc25rs is offline   Reply With Quote
Old 10-04-2007, 11:08 PM   #3
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
for a little better detail on location, its near the starter as well...well, where the starter would be
Old 10-05-2007, 01:08 PM   #4
WrXtaCy2003
Member#: 85036
2013 PBP sti ltd
05 LGT 35r 30psi..busted
along with ^^^^^ make sure the studs in the motor mounts are all the way out of the subframe too when trying to seperate
WrXtaCy2003 is offline   Reply With Quote
Old 10-05-2007, 03:16 PM   #5
norexyet
Member#: 39149
11 elantra
yea i said elantra
Put a a thin blade screwdrive in the opening and hit it with a hammer. If you pulled the pin out already that is. It is just stuck on the dowel pins.
norexyet is offline   Reply With Quote
Old 10-07-2007, 06:59 AM   #6
Rasmusson14
Member#: 77658
2004 ej207, ppg dogs
3" green, ITS ALL 4 SALE!
Block of wood and a hammer
Rasmusson14 is offline   Reply With Quote
Old 10-07-2007, 07:07 AM   #7
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
BFH all the way....
just don't crack your case
IllNastyImpreza is offline   Reply With Quote
Old 10-07-2007, 09:48 AM   #8
Homemade WRX
Member#: 33782
96 bastard child
when having a tranny frozen on pins...I've always just gotten under the car and jiggled the hell out of it...works everytime
Old 10-08-2007, 09:13 AM   #9
SBW
Member#: 38469
07 LGT spec-b
Crystal Grey Metallic
also, make damn sure you have the trans jacked up enough to have the engine motor mount stud's clear of the subframe or that "sub" ain't goin anywhere, keke.
SBW is offline   Reply With Quote
damn oil gallery plug wont budge ...... scprs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 07-16-2008 06:52 PM
boost wont budge? 2.5rsDOHC Normally Aspirated with bolt-on Forced Induction Powertrain 15 04-03-2008 09:29 AM
HELP! Replacing Rear Knuckle - Axle Wont Budge TheRedWagon Service & Maintenance 2 08-05-2005 11:13 PM
HELP! Replacing Rear Knuckle - Axle Wont Budge TheRedWagon Brakes, Steering & Suspension 2 08-05-2005 06:06 PM
('93-'01) the dealer wont budge,and i simply cant afford it!! SuBaRu-ImPrEzA_RS Impreza Forum 26 05-01-2001 12:57 AM
