Old 10-05-2007, 02:01 AM   #1
Rick Hunter
Member#: 825
2002 wrx
Default WRX JDM v8 12.4 1/4 in-car vids (realtime Utec logs overlayed)
Greets,
Here's two 1/4 in-car videos of my car overlayed with realtime Utec logs of the runs:
Ran against a stang that trapped at 112 while I ran a 12.45 @ 114.5 MPH:
High quality versions:
WRX-vs-FastStang.avi - 13.6 Mb
Another url (click Request DL Link then DL file):
http://mihd.net/2xzdmp
Low quality version here: http://www.youtube.com/watch?v=K-D_xjkUQpg
A bit smoother run 12.42 @ 114.4 MPH :
HQ versions:
WRX-vs-TurboStang.avi - 14.3 Mb
http://mihd.net/3erd2a
low quality version here: http://www.youtube.com/watch?v=nU6PCMoJu0I
All HQ vids are xvid encoded - if needed, DL the codec here: http://www.xvidmovies.com/codec/
I believe my shifting needs some TLC - either I'm too rough (1st vid) or too slow (2nd vid). Despite the use of the Utec's flat-shifting LCM, the 1st to 2nd gear shift is the toughest to get right imo (as you can see from the vids). The nose of the car noticeably dips during that important shift. How can I do it better? I'm pretty sure I could drop .2 with smoother shifts.
This time, short shifting into 5th didn't help my times nor the trap speed. Running through the traps bouncing off the 8300 rpm rev limiter sure sounded great though!
Mods:
02 WRX
JDM STi v8
JDM 6 speed non-dccd
FP Green 7cm @ ~20-21 psi
Tial 38mm EWG - UR uppipe
3" Brullen Cat'ed exhaust + custom dump-pipe muffler
TXS TMIC v1
UR 785cc
UTEC v5.8 in speed-density fueling mode
94 octane (1/2 tank)
RE-92s
temp was 27 degrees celcius (~82F)
full interior + spare
Best run thread (where I ran a 12.35 @ 115.4):
http://forums.nasioc.com/forums/show....php?t=1109576
Last edited by Rick Hunter; 10-06-2007 at 03:21 PM. Reason: added youtube LQ version
Rick Hunter is offline   Reply With Quote
Old 10-05-2007, 07:06 AM   #2
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
Cool vid. Love the UTEC overlay. Brings back old memories.
rjrutzky is offline   Reply With Quote
Old 10-05-2007, 07:52 AM   #3
simon021
Member#: 157532
2002 MY03 EJ207 E85
Dom 1.5XTR Twinscroll!
thats a pretty sweet vid with the overlay. Just barely taping the rev limiter at the end there. very nice. and good to see you taking it to a mustang.
simon021 is offline   Reply With Quote
Old 10-05-2007, 03:22 PM   #4
NITROS
Member#: 41561
04 GT3076 2.1
Stroker = Broken 3rd
very very cool, but u what looks like knocking.
NITROS is offline   Reply With Quote
Old 10-05-2007, 07:01 PM   #5
Rick Hunter
Member#: 825
2002 wrx
Thanks guys - it took me a while to figure out how to make that overlay work.
On the run vs the mustang that trapped at 112, I did knock once while launching. Yet at the end of the runs, riding the rev limiter will trigger the knock sensor (flashing CE light) in reading a false knock condition - no real knock happening up there. I'll have to work on my AFRs, seem to be getting a bit too rich at 7500 rpm and up - want to target low 11s.
Old 10-07-2007, 03:03 PM   #6
The Iglooman
Member#: 111015
2009 Audi A5
Deep Sea Blue
Damn, that's some high revs at launch. How is your clutch holding up? Love the video.
The Iglooman is offline   Reply With Quote
Old 10-07-2007, 03:32 PM   #7
WRX4eva
Member#: 103343
2004 2.5 Hybrid 6spd
Rotated Manifold/35R
And I thought I was launching high@!
I think I'm gonna try 6k launch next time... wish me luck
WRX4eva is offline   Reply With Quote
Old 10-07-2007, 04:29 PM   #8
subieracer18
Member#: 72904
yea, you should def be able to do better. i have a usdm 2.0 w/ vf39 and i made 320 whp. i did 12.6 @108 in the 1/4 w/ a 1.7 60ft.
subieracer18 is offline   Reply With Quote
Old 10-07-2007, 07:34 PM   #9
AaronWRX
Member#: 7194
2011 997.2 Turbo
very cool. how did you overlay the utec log?
AaronWRX is offline   Reply With Quote
Old 10-07-2007, 08:58 PM   #10
boostcreep05
Member#: 161166
2005 subaru
Default car
very nice vid whats next
boostcreep05 is offline   Reply With Quote
Old 10-07-2007, 10:25 PM   #11
kcook
Member#: 78074
2005 STi
shifting needs to be faster nice runs tho , sweet vids
kcook is offline   Reply With Quote
Old 10-08-2007, 09:39 AM   #12
WRX4eva
Member#: 103343
Hey Rick, mind sharing how you embeded the Datalogs on to your vid? Which software?
Old 10-09-2007, 07:04 PM   #13
Rick Hunter
Member#: 825
2002 wrx
Iglooman: The stock 6 speed clutch is holding out fine - grabs instantly. I'm also using the original R160. The RE-92s spin relatively easily on the launch which helps reduce the stress that the drive train goes through. I find that setting the launch control at a higher rpm helps build more boost at the line and avoids any bogging. The best 60' I've ever managed with a ~6700 rpm launch was a 1.765 - not that good. I could try to reduce tire pressures the next time...
Here's my quick and dirty notes I made on how to make the vids with the utec logs overlayed:
- cut original DV avi to size with AviTrimmer (freeware)
- run Disp.bat (see below) on the utec log. Tweak the sleep delay (in ms) so that the playback is running at 1/5th sec.
- Run Disp.bat and screen capture the output to an avi file with AviScreen classic (freeware)
- import the cut DV avi into AviTricks (freeware) - create UTEC log headers
- add the screen-captured Disp.avi as a movie overlay in AviTricks - size as required
- save avi (with the embedded overlay) as uncompressed avi without sound (cause AviTricks crashes while exporting avis with sound)
- export the cut DV avi's WAV via Virtual Dub (freeware)
- import the avi (with overlay) into vdubmod - load processor settings (DG smart deinterlace 2.8 + resize to 640x480)
- merge exported wav stream as AC3 into avi (with overlay).
- save as xvid with 3.5 quant settings HQ everything single pass.
(The last 3 parts could be done with Windows Media Maker - at a lower quality though)
Disp.bat:
@echo off
cls
rem timer
@for /F "tokens=*" %%a in (3-vsfaststang-ok!.txt) do (
@sleep -m 200
@echo %%a
rem timer /s
The trickiest part is syncing up the overlayed Disp.avi to the cut DV.avi - quite a bit of trial and error involved.
I'll try to make a few more vids like this.
Old 10-10-2007, 12:24 AM   #14
WRX4eva
Member#: 103343
That is simply amazing. Very nice editing.
Thank you for sharing~
Old 10-10-2007, 01:10 AM   #15
wuuusaa
Member#: 92894
2015 Wrx
can you say bye bye tranny and hello ppg.
nice vid
Old 10-21-2007, 04:35 PM   #16
WRX4eva
Member#: 103343
Any more vids recently? Do you think it can be possible to do the same w/
enginuity's data logs?
Old 10-21-2007, 08:23 PM   #17
Rick Hunter
Member#: 825
2002 wrx
I haven't had much time to edit the other vids yet. I'll try to get them out sometime next week.
As for Enginuity's logs - sure, as long as the logs can be displayed in a simple text output format separated by a common delimiter (tab, space, comma, etc), the method I used can be easily adapted to any ECU's log output.
My car is also down for the count right now, I can't build more than 8-10 psi of boost without hearing a really loud howling sound. Either the newly installed catalytic converter has melted and partially blocked the exhaust or the FP Green has had it... Will find out soon.
Old 10-21-2007, 08:44 PM   #18
STimo
Member#: 110273
450 whp 30R STI
[email protected]
Sick vids, i wish more vids were like this, itr's nice to see how the car runs through the logs while ur going down the 1/4.. Very sick..
STimo is offline   Reply With Quote
GC8 WRX in car vid on track, and 2 other vids Johnny S Motorsports 0 07-25-2008 08:01 PM
In-car vid from May 4 Solo2 Getagrip Alaskan Impreza Club Forum -- AKIC 9 05-08-2008 12:01 PM
WRX JDM v8 Swap & FPGreen EWG 1/4 12.31 @ 115.45 Rick Hunter Proven Power Bragging 43 10-26-2007 01:06 AM
Request: in car vid of thunderhill in a STOCK WRX chimchimm5 Motorsports 22 03-02-2007 08:00 PM
WRX JDM swap 12.68 @ 112.33 + vids Rick Hunter Proven Power Bragging 27 04-28-2006 05:02 PM
