Old 10-05-2007, 04:23 PM   #1
subpreza
Member#: 2940
2002 AMG C32
Black Opal
Default 04 STI FP 20g w/ meth 346hp/378 lbtq
The night before last I put my APS DR525 FMIC on the car in place of the EBAY TMIC. Yesterday I took the car to EL to have a GM boost solenoid installed and have the car re-tuned. My stock solenoid was running at 80% duty cycle and not allowing the car to boost efficiently over 20 PSI. The car went on the dyno and the new solenoid was dialed in at a much lower duty cycle and it was happy with 24 psi. After an hour or so of tweaking Brad tuned the car to make 346hp/378lbtq with @ 11.7 AFR's (88 degrees outside w/ 82% humidity. I am happy with the results and highly recommend the folks at Engine Logics!
With the Ebay TMIC and stock solenoid I was at 339hp/331lbtq
My mods:
FP 20G 7cm 2.4 inlet w/ thermal blanket
ERZ TBE
APS FMIC
APS CAI
Fuel pump
Deatschwerks 785cc injectors
Ebay inlet tube
Samco after MAF tube
Enginuity flash
SMC meth 100%
GM boost solenoid
lightened flywheel
SPEC stage 2 clutch
subpreza is offline   Reply With Quote
Old 10-05-2007, 04:30 PM   #2
TopEndPull
Member#: 126112
93.5 Toyota Supra
Red
nice numbers
TopEndPull is offline   Reply With Quote
Old 10-05-2007, 04:30 PM   #3
sidewayz
Member#: 5810
2001 S366 2.5RS
those number seem a little low. I may be wrong but for instance, I suggest you check this out
http://www.tristatetuners.com/forum/...ad.php?t=41389
http://www.tristatetuners.com/forum/...ad.php?t=41846
sidewayz is offline   Reply With Quote
Old 10-05-2007, 04:33 PM   #4
TopEndPull
Member#: 126112
93.5 Toyota Supra
Red
EL's a low reading dyno, stock sti put down 210 i believe
Old 10-05-2007, 05:33 PM   #5
subpreza
Member#: 2940
2002 AMG C32
Black Opal
Yes EL reads @ 15% lower than any other dyno. You know I have a 20G and not a Green right?
There was an 05 STI that put down 206 (stock) just the other day at EL.
Old 10-05-2007, 05:51 PM   #6
WRX4eva
Member#: 103343
2004 2.5 Hybrid 6spd
Rotated Manifold/35R
I those were good numbers, grats. Really does not matter when it comes to numbers. Take it to the track and see what it does. Good luck. Once again Great numbers.
WRX4eva is offline   Reply With Quote
Old 10-05-2007, 11:03 PM   #7
CynicX
Member#: 48199
06 WRX
Both those links are people that have FPGreen turbos. The OP has a 20g.....
CynicX is offline   Reply With Quote
Old 10-06-2007, 11:40 AM   #8
bulgarianfreak55
Member#: 135691
2004 Subaru WRX STi
333 WHP, 325 WTQ AGILE!
He probably just read FP and assumed the Green haha...aren't these numbers still a bit low considering he has meth? I know this is the FP, but I've seen Deadbolt 20Gs make 350awhp without meth.
bulgarianfreak55 is offline   Reply With Quote
FS/WTT: 04 STi FP Green, Meth, FMIC, Custom Tune, etc. 385awhp 425awtq bmwmotorsports Private Vehicle 'For Sale' Classifieds 14 10-07-2009 08:49 PM
New tune: 2006 STI FP 20g, EWG, TMIC, inlet, TGV's buckatron Proven Power Bragging 71 08-30-2009 05:17 PM
05 STI FP Green - Pump/Meth ChrisSK Proven Power Bragging 35 09-20-2007 07:33 PM
04 sti tuned with SMC Meth/water injection AZScoobie Proven Power Bragging 9 09-19-2006 09:21 AM
Cel code P0244 on a 04 sti w/ 20g chibich Factory 2.5L Turbo Powertrain 12 08-19-2006 10:40 PM
Message Board Statistics All times are GMT -4. The time now is 12:48 PM.
