Old 10-05-2007, 07:16 PM   #1
WRXINXS
Member#: 81923
2003 WRX MBP
Question will 235/40-17 rub on stock 03 WRX Sedan
Hey guys,
Just wondering if I can fit 235/40-17 tires (w/17 x 7.5 wheels) on my 03 wrx sedan without having to modify (roll) anything? Also, will there be any rubbing issues with stock suspension or down the road when I get my kyb agx setup?
Thanks,
Drew
WRXINXS is offline   Reply With Quote
Old 10-05-2007, 07:17 PM   #2
Rwu00313
Member#: 82153
2016 WRX
CWP
Originally Posted by WRXINXS View Post
Hey guys,
Thanks,
Drew
None at all....especially on stock suspension so your good to go! I run a 235-40-18 tire dropped on Tein H techs and never had a problem.
Rwu00313 is offline   Reply With Quote
Old 10-05-2007, 07:29 PM   #3
WRXINXS
Member#: 81923
2003 WRX MBP
Thanks man,
You did not have to do anything to your federwell to fit the 235 correct?
Old 10-05-2007, 07:36 PM   #4
Rwu00313
Member#: 82153
2016 WRX
CWP
Thanks man,
Nope...no fender rolling.
Old 10-05-2007, 07:43 PM   #5
WRXINXS
Member#: 81923
2003 WRX MBP
Thanks Rwu00313,
You really eased my fear, I already bought the tires and I am going to get them mounted tomorrow with my new wheels, but when they came yesterday, they looked huge compared to my 205 stockers!! Thats why I was wondering about the fenderwells.
Old 10-06-2007, 01:44 AM   #6
whateverwrx
Member#: 99653
05 WRX
i just ran 235/45/17s on my stock suspension sedan and they were awesome! RA1s they were thanks john!! no rubbing,no noise, great ride!
whateverwrx is offline   Reply With Quote
Old 10-12-2007, 03:30 AM   #7
Spec C Wannabe
Member#: 69170
Do you think it will rub the rear fender if you lower the car??
I want 235 real bad but dont want to roll the fender. I plan to lower my car too.
I have 8.0x17 inches offset+44 wheel.
What is yours?
Spec C Wannabe is offline   Reply With Quote
Old 10-12-2007, 10:19 PM   #8
PDLTURBO
Member#: 73129
2004 WRX #50ESP
San Remo Red
i run the 235/40/17 re01r's with no rubbing issues at all. and my car is lowered
By pdlturbo, shot with Canon EOS 30D at 2007-08-29
I have a set of 235/45/17 yoko ao48's that do rub, so stay with the 235/40/17.
PDLTURBO is offline   Reply With Quote
Old 10-13-2007, 01:31 AM   #9
sperry7
Member#: 110079
06 WRX
Black on Black
A lot of it depends on what kind of tire you run, they are all different. I run 235/45/17's (a little taller than stock) with a 1" drop on JDM pinks which have decently stiff spring rates and it rubs in the rear if I have anyone in the back and I throw it around a corner. I also run -2.7 front and -2.5 rear camber.
If you stick with the 230/40/17 and run a good amount of negative camber, say -2.0 I can almost guarantee you will be fine.
Good luck.
Steve
sperry7 is offline   Reply With Quote
Old 10-13-2007, 05:58 AM   #10
Spec C Wannabe
Member#: 69170
Thank you both for helping and sharing
FYI, I just tried 17x8 off44 and RE-01R 235/45/17 lowered with not-quite- stiff PSS9 (quite low, the rear tire almost tuck in rear fender). Four people in the car and drove quite hard. No rubbing at all!! He even has the rubber strip on his rear fender lip still!!
Very stange. I wonder why his wheels clear the rear fender with such fat tires??
One thing i do observe is his rear wheels have quite aggressive negative camber, -2 degrees, eyeballed. I asked him if he tried to max out the rear camber? And he said no....
Old 10-13-2007, 07:48 AM   #11
PDLTURBO
Member#: 73129
2004 WRX #50ESP
San Remo Red
Negative camber happens naturally when you lower the rear, I use camber bolts to decrease the negative in the rear.
But I'm rollin my fenders soon to prepare for bigger tires going on when summer rolls around again.
I had 235/40/17 615's before the re01r's and they did not rub either. Just to give you another tire. Some tires run a bit wider (I don't know why)
Old 10-13-2007, 04:13 PM   #12
sperry7
Member#: 110079
06 WRX
Black on Black
He has the PSS9's which are much stiffer than my springs. Mine barely rub when I have people in the back under extreme handling conditions. With coilovers I am sure it wouldn't rub at all.
Will 235/40/17 RT-615s fit on stock '06 wheels? Mr Nice Guy Tire & Wheel 29 10-11-2007 10:26 AM
Will 235/40/17 rub with GF210's on 06? ndtechie_rx8 Tire & Wheel 0 08-14-2007 01:17 PM
HELP 235/40/17 Tires on stock 04 STI rims fastXT04 Tire & Wheel 12 07-20-2005 06:45 AM
Will 235/40/17 Hankook RS-2 fit on 17x7.5? and how to double check rim width? titanium wrx Tire & Wheel 13 04-10-2005 07:15 PM
Will 235 40 17's rub? Turbotegra Technical Forum Archive 7 09-27-2000 08:10 PM
