Old 10-06-2007, 04:48 AM   #1
Loomin
Member#: 118113
98' Stagea 260RS
Autech Ver.
Default Oil pressure problems
the issue:
periodically, i need to top up the oil with half a litre of oil. (about every 2 weeks). the engine barely smokes but i do notice a little bit here and there. the other thing is HOW i notice the oil problem. while sitting at a light, my oil pressure gauge bounces between 0.5-3 kg/cm3. (metric sorry)
and when it dips to 0.5 the oil light comes on!! this is clearly a bad thing so i really have no idea whats going on. the light flashes on and off as the gauge goes up and down, but if i give it a blip of the gas and hit it to 3000rpm or so, everything returns to normal
currently running Royal Purple 10w30 w/ fram filter
heres what ive checked:
1)Not the headgasket- no oil in the coolant etc etc
2)oil level drops quite frequently, enough to need to be topped up bi-weekly
3)no visible leaks on the engine at all. (oil pan is in tact, seals seem fine to me, nice and dry)
with a level drop this drastic, you think there would be huge clouds of blue pouring out the exhaust.
Any ideas? could the oil pump be the issue?
Loomin is offline   Reply With Quote
02 WRX Oil Pressure Problem. HVAAJA21 Newbies & FAQs 5 12-06-2011 06:13 PM
Oil Pressure problem has me stumped, help! St0k3d Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 11-18-2008 12:24 AM
oil pressure problem please help me. turboboxer80 'Old School' Subaru Forum 10 06-21-2008 09:16 PM
oil pressure problems 06njsti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 01-03-2008 03:50 PM
Garrett turbo oil pressure problems... 8Complex Normally Aspirated with bolt-on Forced Induction Powertrain 14 07-29-2003 02:28 PM
