Old 01-16-2002, 01:51 PM   #1
Drivingchallenge
Member#: 12979
Thumbs down WRX 3200miles throwing CEL 4 Cylinder Mis
I have just rolled over 3200miles in my WRX. I got a CEL codes. Got out my code reader and got 4 codes. Cylinder 1-4 all giving misfire codes. I havn't run the car hard really, its had it oil change, and it happened on a dry day in the upper 50 degree range. Any thoughts are advice on this? The Dealer here has only one Subaru tech. ( Yeah one tech in the whole city) So I can't get it in for a while. What could I possibly do to fix this? I know the plugs are going to have to be checked, anything else I should check, or anything to look for? Thanks a lot.
Drivingchallenge is offline   Reply With Quote
Old 01-16-2002, 02:05 PM   #2
AndyHidley
Member#: 1031
I had thoes codes also.. As it turned out the connector that plugs on to the coils falls off easy.. check them .. they are right on top of the spark plugs , 4 of them.
AndyHidley is offline   Reply With Quote
Old 01-16-2002, 02:10 PM   #3
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
Default mis fire
The same thing sort of happened to me.
I had codes p0301 and p0303, mis fire codes for injectors.
No reason just happened on a road trip..bummer..
I asked, grilled service manager, service technician, and they
said it was one of those "things", when a mechanical failure
occurs for no particular reason. Just a batch of injectors.
what were your codes again?
Old 01-16-2002, 02:31 PM   #4
Drivingchallenge
Member#: 12979
My codes were:
0301
0302
0303
0304
So once I check all the plugs and wires, I should find my problem in there? I can't wait for the dealer to fix this.
Old 01-16-2002, 03:18 PM   #5
Jon [in CT]
Member#: 2992
02 WRX Sedan
Since the ECU is reporting that all four cylinders have misfired, I think it's very unlikely that there are loose connections at all four sparkplugs.
It might help to understand how the ECU detects misfire. The general strategy is based on crankshaft rotational velocity (reference period) variations. The ECU determines crankshaft rotational velocity using the crankshaft position sensor and camshaft position sensor. When a cylinder misfires, the crankshaft slows down momentarily. By monitoring the crankshaft and camshaft position sensors’ signal, the ECU can calculate that a misfire has occurred and which cylinder was firing when it happened.
So, if I were a tech, the first thing I'd check is that the camshaft position sensor (on the driver's side) and the crankshaft position sensor (on the oil pump) are both still bolted down properly.
The general procedure for diagnosing misfires in the absence of any other trouble code is described in this thread: http://www.i-club.com/forums/showthr...threadid=36633.
Also, some ECUs have been reflashed because they misinterpretted the camshaft position sensor signal. Misfire codes might be a manifestation of this ECU problem.
Jon [in CT] is offline   Reply With Quote
Old 01-16-2002, 03:38 PM   #6
Drivingchallenge
Member#: 12979
This might be totally wrong here but I still got to check. I don't think I had my gas cap on hard enough. That was in the morning like 8:30am. About 7:30pm I got the light, tighten cap then. Then I went home and ran code reader. You think it's related or two seperate things?
Old 01-16-2002, 03:42 PM   #7
AndyHidley
Member#: 1031
Thoes codes are not related, and you didn't get one from the gas cap.. it would have also been in the list.... it appairently was tight enough.
Old 01-16-2002, 03:51 PM   #8
Drivingchallenge
Member#: 12979
I am just trying to see what I can to keep it from going into the dealer. Like I posted before, there is only one tech in the whole city here. I would be carless for like a week they say.
Old 01-16-2002, 04:24 PM   #9
smash0r
Member#: 9676
2005 Impreza WRX STi
Crystal Gray Metallic
My car is sitting at the dealer right now with no brain. They had to send the ECU back to be reprogrammed because of a false misfire CEL.
This seems to be one of those situations where the number of causes for the error beg for a tech to check it out rather than self diagnosing
smash0r is offline   Reply With Quote
Old 01-16-2002, 05:17 PM   #10
Drivingchallenge
Member#: 12979
Yeah. It just being that we have one tech in the whole city is what buggs me, which means say he gets sick, there is no one there to work on the cars. Too them two days to install gauges and shifter.
Old 01-22-2002, 11:50 AM   #11
Drivingchallenge
Member#: 12979
Just got call from dealer. The ECU has a glitch and is getting shipped today to be reprogramed. Might not have car until after Monday.
02 wrx missfires on all 4 cylinders mattmx525 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 106 02-22-2009 10:14 AM
CEL, All 4 Cylinders Misfiring? G Langa Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 07-14-2008 02:11 PM
Throwing CEL after install of Utec stage 4 STUDAndring Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 12-13-2004 10:10 AM
My WRX is misfiring all 4 cylinders, gurgling, backfiring, and smoking... tEkkGOD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 03-25-2004 11:51 AM
CEL P0304 - Cylinder 4 Misfire Detected Evan J. Kelly Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 03-08-2002 11:10 AM
