Welcome to the North American Subaru Impreza Owners Club Tuesday May 31, 2016
Old 01-15-2002, 01:40 PM   #1
wrx182
Member#: 9531
2002 WRX Sport Wagon
Default STi Group N Tranny Mounts
Great addition to the WRX! Easy to install & VERY nice results with the tranny...All sloppy feelings are gone - good, stiff, crisp shift & when you let off the gas at high revs, that kind of swaying feeling is gone from the tranny. Got mine along with the engine mounts, which I haven't had time to install yet, from www.cobbtuning.com
wrx182 is offline   Reply With Quote
Old 01-15-2002, 01:44 PM   #2
illmatic
Member#: 3536
2015 IMS BRZ Limited
2002/2003 AW/PSM WRX
hows the NVH?
Jsy
illmatic is offline   Reply With Quote
Old 01-15-2002, 02:07 PM   #3
wrx182
Member#: 9531
NVH?
Old 01-15-2002, 02:21 PM   #4
illmatic
Member#: 3536
Noise Vibration Harshness...Will it get annoying on long drives?
Jsy
Old 01-15-2002, 02:37 PM   #5
wrx182
Member#: 9531
no way...unless you have the fan & radio off and really listen for it, you won't even be able to tell...and even then, the only time you can hear it is when you're crusing along at a fairly high rev and let off the gas - it doesn't shake or move like it used to, but you can hear the gear winding down much more...but like i said, you cann't notice it unless you've got everything off and your looking to hear it.
Old 01-15-2002, 02:51 PM   #6
Zahnster
Member#: 2918
2002 Impreza WRX
Silver Sedan
Where did you get them from? How much?
Zahnster is offline   Reply With Quote
Old 01-15-2002, 03:02 PM   #7
wrx182
Member#: 9531
$170 for the 2 engine mounts and the tranny mount from www.cobbtuning.com - great price if you compare it to others.
Old 01-15-2002, 06:58 PM   #8
lstepnio
Member#: 10972
2004 STi (fuxor3d!!)
2004 Forester X
I really want to get these, but I'm deathly afraid it's going to make too much noise and vibration. I don't mind it as much, but I would hate to have my wife say stuff like "hmmmmm, that's pretty noisy. My RSX does not make noises like that. ".
Do you have a short shifter w/ bushings installed as well? I did not think my kartboy setup added that much noise at all, a little but not too enough for my wife to notice.
lstepnio is offline   Reply With Quote
Old 01-15-2002, 11:43 PM   #9
Evan J. Kelly
Forever Scooby Newbie
Member#: 11172
2000 GC8 RS Coupe'
FlatBlack&BlueRidge Pearl
since he's all lazy and stuff... Jim's got an STI short shifter and the kartboy bushings.
come on jim... oompa-loompa!
Evan J. Kelly is offline   Reply With Quote
Old 01-17-2002, 08:39 AM   #10
wrx182
Member#: 9531
I have the STi short shift kit along with the Kartboy shifter bushings.
Dude, trust me, go for it. You'll be very happy with the results, of the tranny mounts atleast. I still haven't put the engine mounts in, and if you're worried about vibrations, those are the ones I'd worry about....But the tranny mount is noise free - go for it, it's so worth it.
I'll let you know how much, if any, noise results from the motor mounts when i install them.
Jim
www.wrx182.net
Old 01-17-2002, 11:25 AM   #11
bemani
Member#: 5673
16 Hellcat
05 LGT, 02 bug eye
Not much noise, but plenty of vibration that you can feel! Love the low frequency rumbling!
bemani is offline   Reply With Quote
Old 01-17-2002, 12:42 PM   #12
wrx182
Member#: 9531
bemani: w/ just the tranny mounts? i really don't feel any negative effects from this install....or are you talking about the engine mounts?
Old 01-18-2002, 09:22 AM   #13
lstepnio
Member#: 10972
2004 Forester X
I can understand the advantage of the transmission mounts, but I'm still a little unclear on the advantage of the engine mounts. Can someone explain?
Old 01-18-2002, 11:44 AM   #14
bemani
Member#: 5673
16 Hellcat
05 LGT, 02 bug eye
Nope, I only have the transmission mount.
Old 01-18-2002, 01:33 PM   #15
Conduit
Member#: 6162
MBP, 1st WRX Ever in FL.
The stiffer engine mounts more firmly afix the engine into position, and as you make more power this is a valuable modification. The tradeoff is more cabing noise and vibration.
You can't underestimate the value of stiffer mounts in a high power car. I have had mounts tear completely and drop the engine. This is bad
Conduit is offline   Reply With Quote
Old 01-18-2002, 01:46 PM   #16
lstepnio
Member#: 10972
2004 Forester X
So you are saying that on a stock WRX the engine mounts are not really a worthwhile mod for the masses?
Any negative effects or potential problems from having the stiffer tranny mounts w/o the engine mounts? I was under the impression that one without the other was a bad ideas for some reason?! Thanks for the clarity.
Old 01-19-2002, 08:40 AM   #17
Fast Reggie
Member#: 10625
Black - TXS Stg 4+
You shouldn't have any negative effects of running either a stiffer tranny or engine mount without the other. All you're doing it is making one or the other stay in place better under torque. I'd recommend the tranny mount first, as it will give you the most immediate benefit. With the additional vibration comes a satisfying click, especially with a better shifter and bushings.
I would suggest stiffer engine mounts for a stock car are unnecessary. That is assuming the stock ones are a good balance between vibration and rigidity. All you'll likely get with the stiffer mounts is more vibration, for marginal benefit. That said, I have changed them on other high power cars and new vibration wasn't bad, especially with V8s. Not so good changing them on a 4.2 XKE.
IMHO, I would not even begin to consider stiffer engine mounts until on the order of 100 additional hp on this car, and then it depends on how you're using it. Routine hard shifts, like regularly drag racing or ...., might want to do it earlier. Think I'm at least there in hp, and still have not changed the engine mounts. The added daily vibration, already enough through the tranny, isn't worth the benefit for the rare trip to the track.
My $.03.
Reggie
Fast Reggie is offline   Reply With Quote
Old 01-22-2002, 09:23 AM   #18
lstepnio
Member#: 10972
2004 Forester X
Good reply, thanks for taking the time. I think I'm going to order those tranny mounts.
Old 01-22-2002, 10:39 AM   #19
bobgrice
Member#: 10627
2002 WRX Sedan
Platinum Silver Metallic
I will report that, after installing the STi engine and tranny mounts, my car feels great. Especially the transmission. I can't really tell much difference with the engine mounts, although I'm sure they're doing their job. I don't detect any additinal NVH from them.
The transmission shifts are cleaner and crisper. It really feels different. I have the STi short shifter, Kartboy bushings, the new STi tranny mount and also just replaced tranny fluid with Redline 75W90NS.
What a difference! Easy, cheap mods that really make the car more enjoyable.
bobgrice is offline   Reply With Quote
2007 WRX TR wit STi group N tranny mount lennyTR Car Part Reviews 5 05-28-2007 03:29 PM
STI Group N tranny mount rcracer Drivetrain 6 12-26-2006 10:11 AM
STI group N tranny mount ryan j Private 'For Sale' Classifieds 1 07-25-2006 04:26 PM
STi Group-n tranny mount & OEM all weather mats for Sale Sfsti Private 'For Sale' Classifieds 2 03-29-2005 06:19 PM
WTB: STi Group N Tranny Mount... shoooter_j Private 'Wanted' Classifieds 1 04-07-2004 11:20 AM
