Old 01-16-2002, 02:09 PM   #1
japriljr
Member#: 12521
2003 silver gtp
03 yellow srt-4
Default up-pipe & warranty
Would installing a aftermarket cat-less up-pipe void my warranty on the turbo if something were to break in the future?
japriljr is offline   Reply With Quote
Old 01-16-2002, 02:24 PM   #2
jesse370
Member#: 12147
2005 g-35
ivory pearl
If what ever part you install is proven to have caused the problem your claim will be denied. It will not void your warranty.
jesse370 is offline   Reply With Quote
Old 01-16-2002, 02:27 PM   #3
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
Default Re: up-pipe & warranty
Probably. While I sorta doubt it will harm the turbo, Subaru could argue that the increased exhaust stream caused more stress on the turbo. I also suspect the added heat in the rear cats (they now have to burn more of the left over fuel) would be a reason for Subaru to not pay for their repair. And they could try, in theory, to not allow claims on the entire engine/tranny/drivetrain under the idea that the modified turbo response caused more stress on the entire system.
Having said that, I'm still considering doing it to my car.
Alan is offline   Reply With Quote
Old 01-16-2002, 03:34 PM   #4
Julian
Member#: 1182
MY00 RS
BRP
As stated above, it depends on what breaks and the circumstances surrounding it. You could always replace it with the stock uppipe if you ever had to bring the car in for service if they give you any hassles. But, on the flip side, you're modifying your, so you shouldn't play if you're not ready to pay.
Julian is offline   Reply With Quote
Old 01-16-2002, 11:59 PM   #5
Kenneth2000
Member#: 6375
2004 STi
Java Black Pearl
Just curious, does anyone know if the Japanese spec, Australian spec, or otherwise have 3 cats in their systems? Like ours?
Do all foreign countries have as strict emissions like CARB?
What I'm getting at, is if this same engine & setup is used in other countries where the stock WRX has higher performance, wouldn't it also be due to having fewer cats, well, and probably diff. fuel.
If that was the case, I'd find it hard to believe that Subaru would try to blame an engine failure on removing a CAT, I could see them voiding the emissions warranty though.....
Kenneth2000 is offline   Reply With Quote
Old 01-17-2002, 08:30 AM   #6
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
I believe that the JDM spec WRX has only 2 cats and No "precat" in the upipe, and i wouldn't doubt that the remaining cats are less restrictive than ours..
I'm not sure about every country but i know that U.S. standards for emissions are higher than Japan right now..i don't know specifics
PaulRex is offline   Reply With Quote
Old 01-17-2002, 10:19 AM   #7
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
3 cats for everyone. That was the whole idea - that this be a "world spec" car.
The emission standards are actually pretty similar - US Tier 1 I believe is a little tighter on cold CO. The 3 cats were also needed for latest EU emissions.
The cat in the up-pipe only improves emissions while cold. Once the car is warm it does much less.
Glenn
ANZAC_1915 is offline   Reply With Quote
Old 01-17-2002, 02:32 PM   #8
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
So JDM and AUS and European spec. WRX's do have a cat in the uppipe?
Old 01-17-2002, 03:29 PM   #9
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
For MY01 onwards (new body style), yes.
WTB: turbo xs up-pipe & down-pipe Kazzer360 Private 'Wanted' Classifieds 1 06-07-2006 05:10 AM
Up-pipe & Boost controller, will they void warranty? ChristophWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-02-2002 12:18 AM
Up-Pipe & Down Pipe installed... Interesting noises... Leak? rlavalle Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 06-12-2002 12:14 PM
WANTED ASAP: Stock WRX Up-pipe & Header "Crossover" Pipe clsmooth71 Bay Area Impreza Club Forum -- BAIC 0 03-08-2002 12:07 AM
WANTED ASAP: Stock WRX Up-pipe & Header/"Crossover" Pipe clsmooth71 Southern California Impreza Club Forum -- SCIC 0 03-08-2002 12:05 AM
